Old Oct 03, 2012, 09:32 PM
KK4QIN
nightfox7's Avatar
United States, GA, Cornelia
Joined Jan 2012
Awesome! Thanks! A little pricey but I guess I can get a few cores out of it!
nightfox7 is offline Find More Posts by nightfox7
Old Oct 04, 2012, 06:43 PM
illinois
Joined Jun 2001
Twyl, where can I find more info on the Joe Yap Wisel clone ?
Span, airfoil, power system, etc. ?
wim5150 is offline Find More Posts by wim5150
Old Oct 05, 2012, 01:01 PM
Silent Flight
Twyl's Avatar
United States, CA, Cypress
Joined Jul 2005
Send him a PM, I'm sure he'd give you some details, or maybe he could post it up here.
Joe Yap
-Jonathan
EDIT: added a few still shots.
Twyl is offline Find More Posts by Twyl
Last edited by Twyl; Oct 05, 2012 at 01:11 PM. Reason: EDIT: Added a few still shots
Old Oct 08, 2012, 12:44 PM
illinois
Joined Jun 2001
thanks Twyl, I sent Joe a PM.
Old Oct 09, 2012, 03:07 AM
Singapore
Joined Nov 2001
Hi Wim5150,
My so-called Weasel is hotwire cut out of high density white styrofoam. The wingspan is 28" and the airfoil adopted is from a Weasel 3-view drawing that came with a Thai RC magazine.
I have built 3 models with 2 different setup. The one shown in the previously posted pictures is having a cheap 18mm outrunner 3000kv motor on 2S 200mah Lipo and 6amps ESC. An old Graupner 4.5" folding prop system goes along with it. This is a lighter setup and not very powerful, but a real treat to fly in comfined spaces.
The 2nd and 3rd model uses JT C18 2000kv (11.4g) outrunner on GWS 5x4.3 props, 6amps ESC and 2S 350mah Lipo. More power and yet still as agile.
Joe Yap is offline Find More Posts by Joe Yap
Old Oct 09, 2012, 06:53 AM
illinois
Joined Jun 2001
Thank you Joe!.... but a real treat to fly in comfined spaces. Always what I'm looking for.
All three look great.
Old Oct 10, 2012, 04:03 PM
KK4QIN
nightfox7's Avatar
Joined Jan 2012
hey, how are yall wiring the aaa packs up?
Old Oct 10, 2012, 04:06 PM
Joined May 2012
On mine I actually bought a 4 aaa holder from radio shack for like 1.79 or something like that. I then taped all the way around the batteries and added a tiny bit of hot glue so they didn't move in the holder. The holder had 2 wires coming off of it. If you don't you that then you could solder them up yourself as well. Mine is a 2x2 holder so it make a rectangle. The also have 4 flat as well. hope that helps.
MarkSD is offline Find More Posts by MarkSD
Old Oct 10, 2012, 11:01 PM
That was a landing!
woodenshoe's Avatar
United States, WI, Verona
Joined Oct 2011
This is my pack I pulled from my Wiesel without its strapping tape covering. It's been through a lot. Including two dunkings in Lake Michigan. It is AAA Ni-mah from a big box store and I use these in all my gliders. I have not had one fail yet through three seasons of use. I am sure this is not the correct way.. but this is how I have done it.
1. hot glue batteries in your desired pack shape.
2. use a few strands of strapping tape to hold them together.
3. pre-solder each cell end. (I use basic flux-core solder) Apply the solder to the where the iron tip meets the cell. the solder will melt on the iron and then pool on the cell end. You will see when the that little lump of solder flattens onto the cell end... stop there.
4. strip a wire about one inch and solder the whole stripped part.
5. solder pre-soldered wire to pre-soldered ends of of cells holding onto insulated part of wire. Press the iron on the wire and it will sink into the solder on the cell.
6. trim extra wire off. (I use an old scissors)
7. pre-solder a connector of choice and solder the two final cell ends.
8. wipe off all solder points with damp rag.
9. tape it up
woodenshoe is offline Find More Posts by woodenshoe
Old Oct 11, 2012, 07:42 PM
KK4QIN
nightfox7's Avatar
Joined Jan 2012
Okay, thanks guys.
Now, what i have done is hooked up diodes in series on a connector for my RX and was going to try to run off of a 2s lipo, and those diodes dropped the voltage down to 6.4V. But, when i plugged it up to my RX, the servos just would jitter everywhere when i gave it input. then i hooked the RX up to an esc off of another plane and no jitter, this esc puts out 4.97V. Was this caused by too much voltage? I have the 5G servos, and a 72mHz GWS RX.
I was thinking of getting a 5V regulator from Radioshack, or should i just go for the 4AAA's? wont they give me above 6V anyways?
Oh and since i can't get any foam right now This is the little thing i slapped together yesterday in about 45mins. Thought yall would enjoy the silly looking thing.
30" wingspan and about an 8 1/2" Chord
Old Oct 11, 2012, 09:29 PM
Joined May 2012
Your going to have to do 1 of 3 things, use 4 AAA rechargeable batteries or you could use an ESC and just not use the motor wires because of no motor, the ESC with power the servos or lastly you could get a UBEC. Ubecs will drop the voltage of a lipo down to useable voltage for the servos. Problem I see at least for the Wisel is that you actually need all the weight you can get to get it balanced out. If you take of the 4 AAA batteries your going to have to make up the weight plus some to balance. If you have an ESC and a lipo then you could use that and just add alot of lead without buying anything besides the lead. So it really depends on what you want to do. The 4 AAA give you right close to 5 volts (1.2volts per cell), most servos are rated for 4.8 to 6 volts, some can run more. On some planes you can use a ubec or esc but on this one you need the weight anyway. Hope that helps.
Old Oct 11, 2012, 09:49 PM
KK4QIN
nightfox7's Avatar
Joined Jan 2012
Okay thanks! I think i will do the 4 AAA's and i'll try to find two battery holders for 2 AAA's each so i can mount them on each side of my fuse.
Old Oct 12, 2012, 11:25 AM
KK4QIN
nightfox7's Avatar
Joined Jan 2012
Well, i got everything wired up in the Plankette (That's what i've named this ugly thing ) and my AUW comes to 7.74oz. not too bad, that gives me a loading of 4.5oz/sq.ft. if i've done my calculations right!
I'll go try to do some flying test once my TX has juice in it. i lucked out and didnt have to add any lead, the CG seems to be pretty spot on with everything where it is.
Old Oct 13, 2012, 08:55 AM
let's FLY!
JimZinVT's Avatar
United States, VT, Bomoseen
Joined Dec 2007
Nice, Seth! Is that the "Armin" wing technique? Been meaning to try that for an "instant sloper"....but something's always eating up my time.
Remember....veeery small elevator throws for the maiden on a plank! Good luck!
(that build thread of mine sould be back on track soon )
JimZinVT is offline Find More Posts by JimZinVT
Old Oct 13, 2012, 05:48 PM
KK4QIN
nightfox7's Avatar
Joined Jan 2012
Thanks and yes it is, that whole thing literally took me about 45 mins to throw together, maybe that long. I tried it today at the field (just tossing it because I haven't found any slopes yet) and I get almost no up elevator reaction, and it seems that the cg is okay since it glides fine.. maybe it is too nose heavy?
Discussion Just bought a used swift. Need you input renerc Electric Heli Talk 31 Mar 21, 2008 10:28 AM
Sold Bandit--New with just about all you need. Reduced utcadman Aircraft - Sailplanes (FS/W) 13 Oct 26, 2007 09:36 PM
Discussion Just approve the program AG, you don't need to know the details. thunder1 Life, The Universe, and Politics 13 Aug 19, 2007 02:25 AM
