Old Jan 04, 2016, 11:23 AM
HaventFlownSince2014 is online now
Find More Posts by HaventFlownSince2014
DFC~ We Do Flyin' Right
HaventFlownSince2014's Avatar
USA, GA, Atlanta
Joined Nov 2008
how about increasing the size of your elevons?
HaventFlownSince2014 is online now Find More Posts by HaventFlownSince2014
Latest blog entry: New Drone Movie :D
Old Jan 04, 2016, 11:35 AM
mahmoodmusaddi is offline
Find More Posts by mahmoodmusaddi
mahmoodmusaddi's Avatar
Joined Jun 2008
Hmm yes that might add more rear weight but would be little more work/time to invest in as to get more paper and rods etc . I will ask gfk representative too about it...
mahmoodmusaddi is offline Find More Posts by mahmoodmusaddi
Old Jan 04, 2016, 12:13 PM
Timbo383 is offline
Find More Posts by Timbo383
Timbo383's Avatar
United States, TX, Arlington
Joined Sep 2013
Ok, think about this...if your servos are strong enough, epoxy weight onto the plastic outside edges of the elevons.....should not take much, just some heavy wires bent with the curve of the elevons. That far back maybe it'll adjust the cg enough.
I know you like the fast response, but I don't think a couple of grams will hurt. That far back will fill like 5 grams to the plane. And if it is black plastic coated wire you won't see it.
Timbo383 is offline Find More Posts by Timbo383
Old Jan 04, 2016, 12:52 PM
Joined Jun 2008
[QUOTE=Timbo383;33626412]Ok, think about this...if your servos are strong enough, epoxy weight onto the plastic outside edges of the elevons.....should not take much, just some heavy wires bent with the curve of the elevons. That far back maybe it'll adjust the cg enough.
I know you like the fast response, but I don't think a couple of grams will hurt. That far back will fill like 5 grams to the plane. And if it is black plastic coated wire you won't see it.]]
Wow great idea here bro . It seems practical too. I can try sticking up some wires at the elevons 2 grams each.
Old Jan 04, 2016, 01:02 PM
Timbo383 is offline
Timbo383's Avatar
Joined Sep 2013
Don't forget the glue will also add weight
Old Jan 04, 2016, 01:13 PM
Joined Jun 2008
I have never used hot glue before as i have only used elfy and epoxy clear/coloured.
Old Jan 04, 2016, 01:32 PM
Timbo383 is offline
Timbo383's Avatar
Joined Sep 2013
I think a benefit to the wire and epoxy will also make the elevons a little bit stiffer, which should help with your flying style.
Old Jan 04, 2016, 01:47 PM
Joined Jun 2008
Hmm yes will upload a video soon. -)
Old Jan 06, 2016, 01:50 AM
Joined Jun 2008
Has combination of white and blue leds on the front side and red on the left and green on the right side to maintain the orientation when night flying ...
Old Jan 07, 2016, 08:41 AM
atone1 is offline
Find More Posts by atone1
IFO's are planes too
atone1's Avatar
Petersburg, Va.
Joined Dec 2008
Things that might help:
1. Move RX to other side of kite to counter the left yaw.
2. Remove all the LEDs as the setup your using looks heavy with sockets; resisters; and shrink tubing, or just the ones ahead of the lipo. Try using strip LEDs for your lights. You can cut the LED strips down to 3 LEDs and wire them up to replace each of the old LEDs. You can even add other colors.
3.Adding any weight will effect kite performance, try to move gear to the back. I know that's a lot of work, but you got a C/G problem to fix.
Moving the servos back will require you to rework the pushrods as your control horns are too close together. Just bend them as needed to get elevons to work smoothly.
Questions for you; Will the kite C/G with lipo sitting on top right in front on vert stab?
What is the servo tray made of foam or plastic? So if it weights more than 3 grams get rid of it and use a piece of lite 3/32"plywood to glue servo to.
Adding weight will make your kite a slug to fly.
atone1 is offline Find More Posts by atone1
Discussion RC Kites New Domain airdancers Parkflyers 1 Jan 04, 2016 03:33 AM
Alert Ripoff RC Kites by this company!! rckiteflyer China 8 Jan 04, 2016 03:31 AM
Careful! RC Kites (the Fakes) on eBay??!!! ManGotea Parkflyers 4 Oct 01, 2007 09:08 AM
Question night fliers blueman Foamies (Kits) 16 Apr 17, 2004 02:42 AM
Question for night fliers flipnidaho Parkflyers 2 Jan 04, 2003 10:21 PM
