Old Jan 03, 2016, 11:01 AM
limey12 is offline
Find More Posts by limey12
United States, FL, Cocoa Beach
Joined Apr 2013
Boom is 558mm
limey12 is offline Find More Posts by limey12
Old Jan 03, 2016, 03:29 PM
DizzyDuck is offline
Find More Posts by DizzyDuck
United Kingdom, Banstead
Joined May 2013
Nice install , Spose the r/e servos could have gone side by side and the whole thing slid a bit further forward but tbh yours is exactly the same layout as mine.
Rather than nose weight I would have gone for a larger battery.
Let's be honest 260g ain't exactly lardy !!
Or as I'm going to try on my next one, shortening the boom slightly
dave
DizzyDuck is offline Find More Posts by DizzyDuck
Old Jan 03, 2016, 03:48 PM
limey12 is offline
Joined Apr 2013
I think you are correct just had something in my mind so gonna fly it anyway. I think shortening the boom is a good idea but not to much ,you and Mickey know what you are doing so I'll wait to see the results of that. Thanks for all your help.
Old Jan 03, 2016, 03:54 PM
limey12 is offline
Joined Apr 2013
P.S. Can't wait to come fly with you guys
Old Jan 06, 2016, 10:53 AM
briano4za is offline
Find More Posts by briano4za
Avid Flyer
South Africa, GP, Randburg
Joined Sep 2015
Composites 101
Dumb question I guess but the Rohacell foam core in the wings how is it shaped to go in the mold with composites?
briano4za is offline Find More Posts by briano4za
Old Jan 06, 2016, 10:56 AM
samc99us is offline
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
Wrong place for that question (this thread), actually it is pretty well documented on the forums if you search. Short answer is it is milled on a CNC router. Long answer is, well, very long. Look up tom43004's dlg tail build, he has several videos on uchannel that show the process as well. Not for the faint of heart btw, I have far more invested in tooling than what buying a few top of the line planes would cost year on year.
samc99us is offline Find More Posts by samc99us
Old Jan 06, 2016, 10:35 PM
Avid Flyer
Joined Sep 2015
With the Storm wing joining and glass reinforcement how does one keep the finish as neat as possible because with some models you don't notice it?
Old Jan 06, 2016, 11:13 PM
samc99us is offline
Aurora Builder
Joined Nov 2003
The models you don't see the seam on are joined in the molds. Essentially the wing is built as one piece, the glass reinforcement (I prefer 1k carbon here for durability and to backup the bolt holes a little) is done during build. I just spent a week building my mold jig to accommodate this and it isn't 100% perfect.
Graham's method is smarter frankly; easier to build, easier to ship and the only downside is a little extra work on the customers end and even that is mitigated with the silicone jigs he sells!
Old Jan 07, 2016, 12:57 AM
Avid Flyer
Joined Sep 2015
If I did'nt do such a good glassing job Sam would it be safe after removal from the jig to do some sanding on say just the the top to improve asthetics ?
Old Jan 07, 2016, 09:57 AM
samc99us is offline
Aurora Builder
Joined Nov 2003
No, not really. What you would likely be sanding is through the glass to get rid of a delamination bubble (basically air trapped between the glass wrap and the wing). Just take your time and all this is really better done once with the help of someone that has done it before.
Old Jan 10, 2016, 02:09 AM
JoeCube is offline
Find More Posts by JoeCube
Woodinville, WA
Joined Jul 2009
Moved the pull string to the innermost hole on the horn and the 3114 still doesn't center for the elevator. Still can't get my Storm balanced well with a double centering elevator. My wallet hopes the third servo will do the job. Got any suggestions? I hope not to pay over $25.
Joseph
JoeCube is offline Find More Posts by JoeCube
Old Jan 10, 2016, 02:16 AM
roydor is online now
Find More Posts by roydor
In F3J size does matter!
roydor's Avatar
Israel
Joined Nov 2006
I highly recommend the Airtronics 94800, it's cheep, accurate and very reliable. I have it in most of my models on the elevator and love it.
But before you order a new servo, did you verify your lines aren't twisted?
try removing the wire and restring the elevator. I use a piano wire to insert the string, I use a drop of CA to attach it to the piano wire and then slip the piano wire from the back end all the way to the front without twisting it. This way it is run straight. If your wires are twisted around one another, nasty things tend to happen, especially on the elevator.
Roy
roydor is online now Find More Posts by roydor
Old Jan 12, 2016, 03:03 PM
Avid Flyer
Joined Sep 2015
Aileron Control Wire Flex
To reduce flexing of the aileron wires at the horns Mickey recommends forming a JB Weld tube over the hole for the wire to seat on. If one ignores the placement of JB Weld tubes will the probable resulting wire flexing cause the hole in the horn to enlarge?
Old Jan 12, 2016, 03:31 PM
mnowell129 is offline
Find More Posts by mnowell129
Mickey from Orlando. Really.
Joined Nov 2004
Possible, but I don't do it for that reason. I do it so that the small piece of wire that is turned 90 degrees can't bend. This in effect holds the end of the wire straight, preventing it from buckling. This reduces the chance of flutter due to the wire buckling in the gap between the fuse and the horn.
mnowell129 is offline Find More Posts by mnowell129
Discussion Graphite Fully Moulded Marshallman Thermal 3 Dec 31, 2006 08:09 AM
For Sale Majko Fully-Moulded R/C Electric Sailplane 1.6 meter fearoflemmings Aircraft - Electric - Airplanes (FS/W) 4 Nov 11, 2006 10:03 PM
Discussion New all moulded DLG project jantel Composites Fabrication 16 Sep 29, 2006 03:32 PM
New Product HET Fully Moulded Sniper E-Flight Product Announcements 0 Feb 28, 2006 05:56 AM
8 foot carbon fully moulded Bluto kawika Slope 15 Apr 08, 2005 12:31 AM
