Old Oct 31, 2015, 07:01 AM
bobbysbrother is offline
Find More Posts by bobbysbrother
United States, NC, Chapel Hill
Joined May 2013
Originally Posted by Nergall View Post
I just buy the 24" @ Sign Warehouse - much larger choice of colors, and its easy to cut in half.
Maybe an obvious question, but how did you cut it in half? Did you unroll a certain length and then cut it from the roll, then cut that separate piece exactly in half with some kind of table cutter that will accept 24" wide media?
Reason I ask is because, at least for the case of the Silhouette Cameo, the media you are cutting must be true and square in the machine or you risk having the pinch rollers walk off the edge on a long cut. That's why thus far I have had sign warehouse make the 12" cuts for me.
As for choice of colors, and at least in the case of oracal vinyl, I find they don't offer any more choice than other vendors. In fact, I'd argue not only does expressions vinyl carry the same complete oracal color line - for type 651 vinyl - but they also carry some specialty vinyls like fluorescent for example, which I have yet to find anywhere else. And all of this is ready to go at 12" width. The main down side with them is they are not the cheapest source fur vinyl, but nonetheless there are times when I find it advantageous to buy from them.
bb
bobbysbrother is offline Find More Posts by bobbysbrother
Old Oct 31, 2015, 02:00 PM
coreman is offline
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
Have you guys looked up sign shops in your area. That is how I found my current supplier (Supplies Unlimited) who is about an hour from me. They carry 60" rolls and will cut it to size and length on the spot. I've been very happy with the Oracal 651 I get there and it's nice to know I can pop over for any colors I don't have on hand. I was even able to get some 4"-6" roll ends cheap and use them for accents of colors I don't typically need.
As for transfer tape, there are two types I've tried. there is the one that looks like masking tape which works fine but I prefer the clear/translucent one that is like a frosted tape because it's easier for me to verify placement. I haven't used either wet
coreman is offline Find More Posts by coreman
Old Nov 01, 2015, 12:36 AM
Nergall is offline
Find More Posts by Nergall
Nergall's Avatar
United States, GA, Lilburn
Joined Aug 2009
bb
I use a hack saw! The most outer layer gets a little messed up at the edge, but the rest of it is fine and works just fine in my Silhouette. I think a bandsaw would be best, if you had one big enough.
You are probably right on competing vendors. I was only referring to the fact that Sign Warehouse has a very limited 12" supply.
Nergall is offline Find More Posts by Nergall
Old Nov 02, 2015, 01:28 AM
fcox04 is offline
Find More Posts by fcox04
Joined Aug 2013
I ordered my Cameo V2 the other day and anxiously awaiting for it's arrival. I also order a lot of vinyl and tape from Sign warehouse. It's also about an hour drive from where I live.
I have a lot of planes that can use some trim that I just didn't want to pay for through my local sign shop.
Can't wait to get started and use all you guys tips.
Frank
fcox04 is offline Find More Posts by fcox04
Old Nov 02, 2015, 05:35 AM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
When cutting something like this, wrap a strip of masking tape or transfer tape around the cut line and that will take the brunt of the abuse because then the top layer of vinyl is no longer the top layer
Old Nov 02, 2015, 09:53 AM
Nergall is offline
Nergall's Avatar
Joined Aug 2009
It doesn't do enough to worry about. I'm rarely cutting right up to the edge anyway, and one can adjust the feed rollers in a little for the starting bit. But, thanks for the tip.
Old Jan 21, 2016, 02:15 PM
babathehutt is online now
Find More Posts by babathehutt
babathehutt's Avatar
United States, CA, Granite Bay
Joined Mar 2013
I got a Cameo II for Christmas and a 48" Extreme Flight Edge. I used the Cameo to cut an entire scheme out of Ultracote. Here it is so far. It's almost done, just waiting on the motor so I can mount the cowl and the bull decals on the cowl. I was impressed with the performance of the machine, and with a new roll of Ultracote, cutting was easy and accurate. I used Gimp to edit and Inkscape to make vectorized images of each layer, and the stock Silhouette Studio software to measure and cut. I used a 13x24" piece of poster board from the Dollar Tree as a carrier. Blade depth was 1 and pressure was set to vinyl. Puppy tax at the end too
babathehutt is online now Find More Posts by babathehutt
Sold Roland Stika 15" Vinyl Cutter FASTALJR Aircraft - General - Miscellaneous (FS/W) 5 Sep 12, 2011 05:25 PM
Discussion Vinyl cutter for decals etc.. The End Painting and Finishing Tips 3 Jan 16, 2009 06:47 PM
Vinyl cutter for making airbrush masks? mluniewicz The Builders Workshop 6 Mar 21, 2005 04:13 PM
Is there an economical radial mount for the AXI 2808 series? papasmurf Power Systems 1 Jan 24, 2005 08:05 PM
Need software for a stika vinyl cutter scp85 tbstep Aircraft - Electric - Airplanes (FS/W) 2 Jan 27, 2003 12:43 PM
