Old Feb 05, 2016, 04:15 PM
FloridaFlyBob is online now
Find More Posts by FloridaFlyBob
FloridaFlyBob's Avatar
United States, FL, Fort Myers
Joined Nov 2011
My father used to tell me, "Wish in one hand and spit in the other, see which one fills up first". Not sure how's that relevant, but I thought I'd throw it out there anyway.
FloridaFlyBob is online now Find More Posts by FloridaFlyBob
Old Feb 05, 2016, 04:28 PM
Liberty10 is online now
Find More Posts by Liberty10
Yin & Yang
Liberty10's Avatar
United States, VA, Sterling
Joined Jul 2011
That's not the way my mother said it. She clearly knew spit would be hard to hold so she used what comes out the other end.
Liberty10 is online now Find More Posts by Liberty10
Old Feb 05, 2016, 04:44 PM
ryane67 is online now
Find More Posts by ryane67
Can it fly? I'll try and see!
ryane67's Avatar
United States, MI, Orion Charter Township
Joined Mar 2013
Are you sure he said spit? or did you mean to substitute another letter for the "p"
ryane67 is online now Find More Posts by ryane67
Old Feb 06, 2016, 04:55 AM
Joined Nov 2011
Lol, no I was taming it down a bit, it wasn't spit, but it began with s.
Old Feb 16, 2016, 02:26 PM
mgosson is online now
Find More Posts by mgosson
United States, NY, Syracuse
Joined Jun 2008
Servo Suggestion
I'm pretty much through the major parts of the build and had to skip the servo installation due to ZERO inventory of the Hitec 7245.
I've written to Hitec requesting an approximate ETA for the HS-7245MH servo but no reply yet.
The only viable solution I can come up with is a few alternatives, please give your 2 cents on my options.
My flying will be limited to "light" 3D and more precision flying. I have yet (probably never will) become very good at 3D.
1 - Hitec, HS-7235MH, 50 oz. torque $60.00 ea.
2 - Spektrum, A5060, 98 oz. torque $60.00 ea
3 - JR, DS3421, 65 oz. torque $89.00 ea.
mgosson is online now Find More Posts by mgosson
Old Feb 16, 2016, 02:59 PM
bryansifsof44 is online now
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
There is always the 5245 or savox has a comparable HV servo... Can't remember the numbers
bryansifsof44 is online now Find More Posts by bryansifsof44
Old Feb 16, 2016, 03:16 PM
Somethin' Extra is offline
Find More Posts by Somethin' Extra
**** this ****
Somethin' Extra's Avatar
Joined May 2013
Kst ds-515mg
Somethin' Extra is offline Find More Posts by Somethin' Extra
Latest blog entry: <vent>
Old Feb 16, 2016, 04:12 PM
Papa P is online now
Find More Posts by Papa P
Joined Jun 2013
I have the 5245s in my Extra, and for my flying skills ( similar to what you want to do ) work perfectly fine. The Extra also was my first 60" E/F plane, so it has been flown the most, and have never had an issue with them
Papa P is online now Find More Posts by Papa P
Old Feb 16, 2016, 04:26 PM
ryane67's Avatar
Joined Mar 2013
Originally Posted by Somethin' Extra View Post
Kst ds-515mg
These and Savox SV-1250mg are both excellent affordable high voltage servos.
Savox http://northwestrc.com/Savox-SV-1250...ic-_p_203.html
KST https://alofthobbies.com/kst-ds515mg...h-voltage.html
Old Feb 16, 2016, 04:36 PM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
The 7245MH are certainly better, but I had the 5245MG in my Extra for two years, my MXS for three years and both those sets have been serviced and are now in my Edge and Yak. They work really well and are the way to go if you are on a budget.
This is an old video of my first Extra, but it used the 5245MGs. If you are going to fly harder than this you might need better servos, but like this the 5246MGs were fine. They held up fine and performed well.
No Title (5 min 31 sec)
Doc Austin is online now Find More Posts by Doc Austin
Old Feb 16, 2016, 05:31 PM
Joined Jun 2008
Thanks for the input fellas.
My first choice is the Hitec 7245, but with no no ETA in sight I have no idea if and when they will arrive. I called Extreme Flight and they shared my frustration about the lack of availability for the 7245's.
I ended up ordering (4) Hitec HS 5245MG from Horizon, $36.00 each, no freight.
Old Mar 02, 2016, 08:45 PM
Joined Jun 2008
Parts ID
The parts were included in the 60" 300 EXP kit.
Can you please help me identify the items in the picture attached. I have an idea where the white adapters go, I believe it covers the landing gear. Also can you please explain what the black hose does and what's with the balsa. I have no clue.
Old Mar 02, 2016, 09:09 PM
Gregertman is offline
Find More Posts by Gregertman
United States, IL, Glenwood
Joined Nov 2013
The black hose goes on the white landing gear cuffs. It keeps the cuffs from scratching or poking a hole in the covering. The balsa pieces are to make baffling to direct air twards the motor. It attaches to the motorbox.
Gregertman is offline Find More Posts by Gregertman
Old Mar 02, 2016, 09:46 PM
Joined Jun 2008
Okay,
Old Mar 02, 2016, 11:56 PM
_OZ_ is online now
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
Check out this video starting at the 2 minute mark. It shows how the fairings go on. The only thing I do different is to use Black or Clear RTV instead of epoxy. My reason for doing this is to make the landing gear easier to remove and if you damage the landing gear it is easy to remove the fairings and be able to reuse them .
Extreme Flight 104" Extra Assembly Video #2 - Fuselage (19 min 4 sec)
_OZ_ is online now Find More Posts by _OZ_
Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video hercdriver7777 3D Flying 2620 May 08, 2016 03:30 PM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 249 Apr 16, 2012 10:46 AM
Help! D-60 build thread Chronic DS'er Dynamic Soaring 3 Jun 23, 2011 10:04 PM
Sold Extreme Flight 58" Extra Ready To Fly (GA) traderdave2 Aircraft - Electric - Airplanes (FS/W) 11 Apr 26, 2011 05:33 PM
Video EXTREME FLIGHT RC EXTRA 300EXP in Action! EXTREME FLIGHT Electric Plane Talk 1 Jun 10, 2009 08:45 PM
