Old Feb 02, 2016, 08:39 PM
changosurf is offline
Find More Posts by changosurf
Joined Aug 2011
Originally Posted by rocketscience View Post
Some of the caiprinha guys did the winglet mod because that plane came with 2 sets of winglets. You were supposed to use velcro and be able to swap them out. But the velcro made them really flimsy and it didn't work well. The nylon and screws works well and really not much extra weight.
I basically followed this. Scroll almost to the bottom.
When inserting the nylon, insert perpendicular to the tip edge.
http://birdman1goescaipirinha.blogsp...-post.html?m=1
Originally Posted by gionir View Post
I use screw on winglets mainly for transporting the wing during hikes:
http://www.rclab.info/2015/04/custom...ong-range.html
I just used common sense in placing the M3 nylon nuts in the wings, maybe 20 to 30 mm from the edges.
To be honest I cannot feel the shift of CG, but that maybe comes from the fact that I fly with a blunt section which changes everything anyway.
I am really happy with the outcome, and never had a problem with this configuration.
thanks guys, I ended up performing this mod with some short nylon studs and light metal M3 screws. Seems to have worked out great, and now I don't have to worry about screwing up on the winglet design since I can easily change them out
I just hope they hold up in rough landings and don't strip out the threaded nylon stand-off from the foam. I used goop to glue the stand-offs.
changosurf is offline Find More Posts by changosurf
Old Feb 02, 2016, 08:41 PM
Joined Aug 2011
might be a dumb question, but can anyone help me get an idea of what the 'angle of attack' should be for 'level flight' on a popwing?
I'm trying to calibrate auto-level on my flight controller, and I need to figure out how many degrees of up-pitch I need in order to keep the wing flying level. I've got it mocked up, and it looks like it might be around 5-10 degrees, but I'm not sure...
Old Feb 02, 2016, 09:12 PM
Grantham Kid is offline
Find More Posts by Grantham Kid
Chasin' that Neon Rainbow
Grantham Kid's Avatar
Australia, QLD, Grantham
Joined Oct 2012
All you can do is.... What looks good probably is.
It is trial and error and will usually fly quite OK anyway. Fly it and adjust it later when you see how it reacts.
Possibly 10 degrees, but depends on your downthrust angle as well.
What type of FC have you got that needs calibrating?
Grantham Kid is offline Find More Posts by Grantham Kid
Old Feb 02, 2016, 09:45 PM
Joined Aug 2011
naze32 FC running baseflight.
ok, I'll try 10deg and see how it goes. It *seems* to look about right
Old Feb 02, 2016, 11:03 PM
rocketscience is online now
Find More Posts by rocketscience
Not a six pack
rocketscience's Avatar
USA, IL, Chicago
Joined Jul 2008
You know how to trim this in between flights? If it's too much I'd recalibrate but if it's just a little.. land, disarm, throttle forward, then right stick to trim the direction you need. If u have a beeper you will hear confirmation. It takes about 4 beeps to even notice a change in the air. If.no beeper the light on the naze will flash.
rocketscience is online now Find More Posts by rocketscience
Old Feb 03, 2016, 12:21 AM
Joined Aug 2011
thanks, yeah, I know how to use the stick command to trim it Actually, I'd be using the ezgui app, but the concept is the same.
Basically, I'd like to try to get it close enough so that I don't have to mess with it too much at the field. I set it to approx 10 degrees via the baseflight configurator app. We'll see how it goes...
Old Feb 03, 2016, 01:40 AM
Not a six pack
USA, IL, Chicago
Joined Jul 2008
Yeah I took a guess with my skipper xl and in self level it wanted to do a nose dive. So I had to recalibrate with a battery under the nose and it was much better. Easier to just land and recalibrate honestly.
Old Feb 08, 2016, 12:24 PM
powerstroke01 is online now
Find More Posts by powerstroke01
powerstroke01's Avatar
USA, CA, Ahwahnee
Joined Sep 2004
For my mini popwing....
What kinda glue can i use to repair a tear on the hinge for the aileron? Or tape maybe? And what about where the motor mount meets the foam? Hot glue?
powerstroke01 is online now Find More Posts by powerstroke01
Old Feb 08, 2016, 04:01 PM
Joined Oct 2012
Use Blenderm tape for your hinges and hot glue around your motor mount.
Old Feb 08, 2016, 04:23 PM
USA, CA, Ahwahnee
Joined Sep 2004
Thanks!
Question Techone models?? lectroglide Scratchbuilt Indoor and Micro Models 5 Aug 07, 2011 02:54 PM
Sold Techone Energy EPP Foamy Wattsup23 Aircraft - Electric - Airplanes (FS/W) 9 Mar 31, 2011 04:28 AM
Sold Techone Piaget 3D EPP New in box $45 shipped! Lindy757 Aircraft - Electric - Airplanes (FS/W) 2 Mar 18, 2011 12:01 AM
Discussion TechOne F3P??? cglynn Indoor Pattern/F3P 6 Mar 11, 2011 02:24 PM
Question techone malibu 2 or techone aeolus? genesis96 Indoor Pattern/F3P 16 Jan 19, 2011 02:02 PM
