Old Jul 19, 2016, 02:28 PM
llasov is offline
Find More Posts by llasov
Penny. Penny. Penny
llasov's Avatar
United States, MD, Reisterstown
Joined Dec 2012
Foam Factory Hot Wire Cutter
I'd like to try a build. I will be using Dollar Tree Foam. Has anyone used the Foam Factory Hot Wire Foam Cutters?
llasov is offline Find More Posts by llasov
Old Jul 19, 2016, 03:02 PM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
I've heard that a hot wire cutter won't work if you leave the paper skins on the Dollar Tree foam board . I just use a new razor blade .
balsa or carbon is offline Find More Posts by balsa or carbon
Old Jul 19, 2016, 03:18 PM
llasov is offline
Penny. Penny. Penny
llasov's Avatar
Joined Dec 2012
Rats. Tried the Exacto knife. I did a lousy job (not too bad on straight lines).
Old Jul 19, 2016, 03:26 PM
Joined Aug 2010
A fresh new blade makes a difference - and practice .
Old Jul 19, 2016, 04:13 PM
Granted is offline
Find More Posts by Granted
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
Don't try to do curved cuts, a bunch of straight cuts taking off the high points works better. Sand the curve smooth if needed.
Granted is offline Find More Posts by Granted
Old Jul 19, 2016, 05:13 PM
wirbech is offline
Find More Posts by wirbech
Pushing the Limits of FFF
wirbech's Avatar
United States, CA, Sierra Madre
Joined Jun 2005
That is correct, if the paper is left on the DT foam the HW cutter will not work. I use the DT foam all the time as templates for wings and curved fuse sections.
wirbech is offline Find More Posts by wirbech
Old Jul 20, 2016, 07:04 AM
flypaper 2 is offline
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I use the Olfa cutters with the slide out blades. Thinner and sharper than the Exacto. Break the end of the blades off when they get dull. The foam seems to dull any blades in a short time.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Jul 20, 2016, 09:10 AM
OutcastZeroOne is offline
Find More Posts by OutcastZeroOne
"Fly, yes... Land, No"
OutcastZeroOne's Avatar
United States, CA, Santa Cruz
Joined May 2005
No Hotwire cutter will cut foam and paper at the same time. The only way to cut with a hot wire is bare foam. But you can easily peel the paper off, then glue a new coating paper back on. Just keep in mind that the paper may shrink a bit from the glue drying and curl the foam. Lots of threads here on how to cover foam.
OutcastZeroOne is offline Find More Posts by OutcastZeroOne
Old Jul 21, 2016, 12:07 PM
Bob_B is online now
Find More Posts by Bob_B
Flys Like A Brick
Bob_B's Avatar
Washington, MI
Joined Nov 2010
I can use an exacto blade until it is worn away to nothing. The trick is that i have a sharpening stone on the table to touch up the edge often. Very often.
Never try to make the cut with just one swipe of the blade. First cut mostly top layer of paper, second mostly foam and third is the rest of it. Never try to cut with the blade straight up and down, always with blade angled to the foam. Even with the paper off, it is better to do multiple cuts.
if you ever get any MPF foam, you will love it as it cuts like butter compared to DTF.
Oh yes and as Balsa or Carbon said .........Practice
Bob_B is online now Find More Posts by Bob_B
Old Jul 22, 2016, 02:53 PM
llasov is offline
Penny. Penny. Penny
llasov's Avatar
Joined Dec 2012
MPF ? I googled it. Is this what you are referring to?
http://www.modelplanefoam.com/
Old Jul 22, 2016, 03:25 PM
Bob_B is online now
Flys Like A Brick
Bob_B's Avatar
Washington, MI
Joined Nov 2010
Yes that's it. There is also a thread on rcgroups about it. It came out as a replacement when blue fan fold foam got hard to get. It's basically all I use. About 6 millimeter thick with no paper or plastic coating. Another reason I like it, is that the fellow that sells it, only lives a few miles away from me.
now that I am at my computer and not on my phone.....
Go to the site you had and click on "about us" and it gives you some different links and a little of the history.
The company is run by "Springer" here on RCG, who also does "One Sheet Kits"
Bob
Old Jul 22, 2016, 04:14 PM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
MPF is what we have as a Depron alternative !
US made Right here in the Midwest aka Michigan
Deprons' maker and the EU have LET US DOWN !!!
So, as a consequence, I support MPF, totally !
Bob
Hoosier Cutout Service
birdofplay is online now Find More Posts by birdofplay
Old Jul 25, 2016, 09:27 PM
jonquinn is offline
Find More Posts by jonquinn
USA, PA, Westmoreland Co.
Joined Aug 2008
Is there a substitute out there right now (in the USA) for depron in thicknesses other than 6mm? Particularly 3mm, or maybe even some thinner material.
I am aware of MPF, but as far as I know they only supply in 6mm.
jonquinn is offline Find More Posts by jonquinn
Old Yesterday, 08:23 AM
T_om is offline
Find More Posts by T_om
The Junk Man
Jacksonville, Florida
Joined Jul 2006
The easy way to end up with foam of whatever thickness you desire is to make a hot wire cutter and slice it yourself.
You can get VERY thin slices if you like. The one I show here is 1 mm and was sliced from Dollar Tree stuff.
Tom
T_om is offline Find More Posts by T_om
Old Yesterday, 01:31 PM
saucerguy is offline
Find More Posts by saucerguy
saucerguy's Avatar
United States, WA, Yacolt
Joined Dec 2005
Showing my hot wire cutter. Its big enough to cut off 4 foot sections of foam and I added an adjustable tension bar for cutting up smaller pieces so I only need one hot wire cutter for any job.
I buy full sheets of eps, 2" stock gets me about a dozen or much more planes out of it depending upon the scale. I have tons of laminate "Formica", on hand for making jigs and patterns with. Its a little tricky getting used to cutting out the pieces with a hand held but once you are used to it, its a breeze.
I used stainless steel fishing leader on my other ones, this one uses stainless steel crafts wire. I tried guitar strings in the past, i barely got a few cuts out of them before they broke, i also heard of some people using piano wire.
saucerguy is offline Find More Posts by saucerguy
Best Wire for Hot Wire Foam Cutter andyg Foamies (Kits) 23 Jun 01, 2016 10:28 AM
For Sale 4 axis cnc hot wire foam cutter, PC, gecko, software Dallas TX speedyb_tx Aircraft - General - Miscellaneous (FS/W) 5 May 29, 2016 10:20 AM
Discussion Hot Wire Foam Cutter powerlinemanco Foamies (Scratchbuilt) 10 Jan 14, 2016 04:59 PM
Discussion Hot wire foam cutter problems TarikAgcayazi Foamies (Scratchbuilt) 5 Dec 11, 2015 04:33 PM
where to get wire for my hot wire foam cutter tinsink Foamies (Kits) 47 Jun 03, 2004 02:09 PM
