Old Jan 16, 2009, 05:46 PM
Jungmeister 55
simano's Avatar
Orlando Herndon, Florida, United States
Joined Sep 2002
Hobby Lobby WACO-Cabane Strut Mount Modification_
The Hobby Lobby WACO YMF5 by Pelican is by far one of the most beautiful RTF foamies I've seen. As such, I couldn't pass the opportunity to get one on a great sale at a local Hobbytown USA.
I'm very pleased with everything about this model...that is...except the cabane strut attachment at the fuse.
Pelican decided to glue a plastic tab to the foam and use that as a pad to screw the cabane stuts to the fuse.
Well, this method is flawed to say the least. Just on my thjird flight the same day I maidened the plane, the pads came off the foam and I found mydelf flying the plane with just the outboard interwing struts holding the top wing from fglying away!!!!...
(Continue)
simano is offline Find More Posts by simano
Old Jan 16, 2009, 06:06 PM
Jungmeister 55
simano's Avatar
Joined Sep 2002
So, I devised this clever modification to securely mount the cabane struts to the fuse.
In fact, this mod will securely attach the top wings of any foamy biplane, regardless of wether the struts mount at an angle...like the WACO...or, straight up...like the GWS Tiger Moths...
STEP 1:
Drill two holes all the way thru the fuse to accept a wood dowel.
STEP 2:
Cut the dowel end at an angle that matches the fuse.
STEP 3:
Drive the dowel all the way thru and mark the other end with a pen
STEP 4:
Cut the dowel at an angle but don't complete the cut all the way thru so there's enough dowel to hold when you drive it thru the fuse.
STEP 5:
Apply a little bit of ELMER's white glue or equivalent to the dowel where it will contact the fuse and insert the dowel thru the fuse.
STEP 6:
Trim the dowel flush with the fuse.
STEP 7:
Mark and drill the holes for the cabane strut.
STEP 8:
screw the wing to the fuse and go fly!!
I hope this mod will help make flying the WACO...and other biplane foamies enjoyable as it should be!!.
Gerry.
Old Jan 17, 2009, 05:50 AM
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
Very clever indeed Gerry. I thought this was especially smart.
Trim the dowel flush with the fuse. So you don't have those ugly dowels sticking out.!
taekwondo is offline Find More Posts by taekwondo
Old Jan 17, 2009, 12:43 PM
Jungmeister 55
simano's Avatar
Joined Sep 2002
Thanks Henry!!...it seems like you're the only one who's seen this thread...it is a flaw on this model and I hope that others will take notice like you did in order to keep the top wing where it belongs!!...
Gerry.
Old Jan 17, 2009, 06:37 PM
Account closed
Joined Oct 2002
Gerry!!
That's great detail and very cleaver manner to re-enforce those struts!
Hope to see you in the morning!
Carlos
guapoman2000 is offline Find More Posts by guapoman2000
Old Jan 17, 2009, 11:19 PM
Jungmeister 55
simano's Avatar
Joined Sep 2002
Originally Posted by guapoman2000
Gerry!!
Carlos
Thanks carlos!!...the Waco should be back in the air early tomorrow am!!.
Gerry.
Old Feb 15, 2015, 03:23 PM
United States, MI, Fife Lake
Joined Feb 2015
Great Idea. I'll be doing that to my waco.
billdoyle is offline Find More Posts by billdoyle
New Product Waco YKS-6 ARF in 1/8 scale by Pilot 1/Hobby Lobby Thomas B Scale ARF/RTF 720 Aug 17, 2014 04:01 PM
For Sale Hobby Lobby "Waco" R.T.F. realtimerecon Aircraft - Electric - Airplanes (FS/W) 5 Nov 28, 2008 07:32 AM
Discussion Hobby Lobby V-Diamond motor mount itspat Pusher Prop Jet Models 0 Jan 04, 2007 10:36 PM
Discussion Hobby-Lobby ABS V Hull Motor Mount Help CRabkin Racing Boats - Electric 5 May 26, 2006 11:05 AM
