Old Apr 11, 2014, 01:26 AM
Full Scale Pilot
Haleymon's Avatar
Antarctica
Joined Aug 2007
Mini-HowTo
Embedded FPV in a Blade 350 QX
Hi All,
I just finished the maiden flight of my newly custom modified Blade 350 QX.
This required a great deal of testing and modification to the body and battery tray if your not VERY comfortable with a dremel, xacto and soldering iron don't try this at home;-)
I have all the FPV equipment inside the body of the aircraft.
It runs perfectly, GPS locks quickly, i have tested it out to 600 feet (LOS), solid signal using Fat Shark Attitude V2
8 min flights with GoPro attached
10 min FPV only
using stock battery
I HIGHLY recommend the carbon fiber rotor mod before doing this as I don't trust even the "B" blades.
This mod works and works WELL
If you have questions feel free to ask.
Good flying
Dave
Haleymon is offline Find More Posts by Haleymon
Old Apr 11, 2014, 11:29 AM
Joined Jul 2011
So tell me u get gps lock with out shielding the gopro? What mah is ur battery ur using.
Exavior1221 is online now Find More Posts by Exavior1221
Old Apr 11, 2014, 04:36 PM
Full Scale Pilot
Haleymon's Avatar
Antarctica
Joined Aug 2007
2.0 System Software and if its not already done, move the GPS and antenna from the top of the battery tray and attach the GPS on its side to the battery tray by the battery opening. Put the GPS antenna with double sided tape on top of the speed controller of motor3. Be sure to position the GPS antenna with the correct side up. All new Blade 350 QXs are being shipped this way.
Battery is 2200 mah
Dave
Old Apr 11, 2014, 04:56 PM
Joined Jul 2011
Thanks I'm gonna try that.
Old Apr 23, 2014, 08:14 PM
Joined Jan 2014
1st off, nice install of the Tx. Have you had any issues with overheating the FPV tx? It gets pretty hot.
C6SUMMER is offline Find More Posts by C6SUMMER
Old Apr 30, 2014, 10:30 AM
Joined May 2012
Haleymon, do you have any pics to go along with what you described?
BBQflyer is offline Find More Posts by BBQflyer
Old Apr 30, 2014, 01:37 PM
SPOOOOOOON!
Joined Oct 2006
Here are the directions from Horizon Hobby's website:
http://www.horizonhobby.com/pdf/BLH7...date_FW2.0.pdf
kj
kmj73us is offline Find More Posts by kmj73us
Old Jul 06, 2014, 04:52 PM
jesses151's Avatar
Goshen, OH
Joined Aug 2010
jesses151 is offline Find More Posts by jesses151
Discussion Blade 350 QX Mod thread / FPV / Customization / DIY Tehota Multirotor Talk 19 Apr 23, 2014 08:10 PM
Discussion Is anyone using FPV on Blade 350 Qx? 82ndRCFLYER Multirotor Talk 24 Apr 12, 2014 11:24 AM
Discussion Blade 350 QX FPV mods VintageSlots Multirotor Talk 5 Apr 11, 2014 04:28 PM
For Sale Blade 350 QX Brand New In Box!!!! TheBeastTamer Aircraft - Electric - Multirotor (FS/W) 1 Oct 07, 2013 09:41 AM
For Sale Blade 350 QX Brand New In Box!!! TheBeastTamer Aircraft - Electric - Multirotor (FS/W) 3 Oct 05, 2013 10:02 PM
