Old Sep 11, 2014, 06:41 AM
Joined Jul 2014
Hitec HS-65mg servo extensions.
What's up guys? I am new to ARF PLANES and have a quick question. I am building a 3DHS 41" EDGE 540 and using HITEC HS-65mg servos with a castle 50a lite ESC/ AR610 rx and 3s 11.v 2200 mah battery. I was wondering what type of servo extensions I should use to get the most out of my setup and for the servos to function properly with these particular servos . Do I use light weight, standard, or heavy duty extensions with these servos? I have been flying 3d for a while now but just foamies BNF / PNP's. Any input or suggestions would be great. Thanks guys.
Kevin
3DYAK1 is offline Find More Posts by 3DYAK1
Old Sep 11, 2014, 07:11 AM
Addicted to 3DHS and EF
3Daddict's Avatar
ohio
Joined Oct 2010
this is what I like to use in all my birds http://www.3drcparts.com/20awg-silicon-wire-extensions/. A bit of overkill on a 41'', but that will not hurt anything.
3Daddict is offline Find More Posts by 3Daddict
Old Sep 11, 2014, 08:01 AM
AKA Amraam
Newcastle, England
Joined Feb 2007
On a 48" size or smaller, I just use regular JR/Futaba extensions. The ones with the clips are the best as you just add abit of tape or heatshrink to secure it.
Plane Hazza is offline Find More Posts by Plane Hazza
Sold Used HiTec servos - HS-65MG, HS-5065MG, HS-82MG kz4q66 Aircraft - General - Radio Equipment (FS/W) 5 Apr 21, 2014 06:53 PM
Found Looking for Hitec HS-65mg servos ohmygod Aircraft - General - Radio Equipment (FS/W) 1 Oct 15, 2013 11:51 AM
Sold Like new Hitec HS-65MG Mighty Metal Gear Feather Micro Servo thundercl58 Aircraft - General - Radio Equipment (FS/W) 5 Oct 11, 2013 09:35 AM
Sold Hitec Servos -- HS-65MG and HS-225MG split_s Aircraft - General - Radio Equipment (FS/W) 1 Oct 03, 2013 08:20 PM
Sold 2 NIP Hitec HS-65MG Servos, 1 NIP HS-65HB, 1 NIP HS-65MG Gear Set chadtyro Aircraft - General - Radio Equipment (FS/W) 1 May 04, 2009 09:09 PM
