Old Aug 28, 2014, 03:34 AM
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
New Product
UMX FVP Vapor from E-Flite
FPV Vapor RTF W/ Goggles
Key Features
Completely built, flight ready airframe
Spektrum™ VS1100 ultra micro FPV system
Fat Shark Teleporter V4 headset with digital head tracking
Full-color QVGA 320 x 240 LCD headset displays
SpiroNET circular polarized antenna system
150mAh 1S 3.7V Li-Po battery and USB 1S Li-Po charger
760mAh 2S 7.4V Li-Po headset battery and AC charger
Ultra-lightweight, film-covered carbon fiber airframe with modular construction
Spektrum 3-channel DSMX® receiver/ESC/Servo unit
Fully proportional throttle, elevator and rudder control
4-channel 2.4GHz DSMX transmitter
No FCC license required
Overview
If you’ve ever imagined yourself in the pilot seat of a great flying RC airplane, the E-flite® FPV Vapor® model can make your dream a reality. Poised at the optimal point on the aircraft, a tiny video camera sends full-color, real-time action back to you on the ground. The view is so immersive that you’ll feel as though you’re actually sitting in the pilot’s seat of the model airplane. Plus, the FPV Vapor ultra micro aircraft is small enough to enjoy in many large indoor spaces, such as a gymnasium or even outdoors in your own backyard. The ultra-lightweight design, combined with its efficient motor system, allows the airplane to have outstanding handling even when it’s flown at slow speed. Which means you can experience First-Person View Flight virtually anytime and anyplace.
You can have the Ready-To-Fly version up in the time it takes to charge the batteries. The Spektrum™ VS1100 ultra micro FPV system is fully installed on the airframe and a Fat Shark Teleporter V4 headset is included. The only thing you have to do to experience FPV flight is charge the batteries.
Fully Assembled Airplane
The UMX FPV Vapor features a completely built, flight ready airframe that’s ultra-lightweight with film-covered carbon fiber construction and modular components that make any necessary repairs easy to complete. The airplane comes equipped with an all-in-one Spektrum 3-channel DSMX receiver/ESC/servo unit.
FPV System
The UMX FPV Vapor has the Spektrum™ ultra micro FPV camera already installed. It’s a 2-in-1 camera/transmitter unit that features a circular polarized antenna for superior range performance and is powered off the E-flite ultra micro 150mAh 1S 3.7V 25C Li-Po flight battery included.
FPV Headset
The RTF version of the UMX FPV Vapor includes the feature rich Fat Shark Teleporter V4 FPV headset. Worn like a set of goggles, inside the headset is a pair of full-color QVGA 320 x 240 LCD displays that receive a wide field of view from the camera onboard the Vapor FPV. The included 5.8GHz SpiroNET circular polarized antenna system has amazing reception. Best of all, the Teleporter V4 FPV headset includes 2-axis digital head tracking that senses your head movement to deliver an even more immersive view point.
Flight Transmitter
The RTF version includes a 4-channel 2.4GHz transmitter with Spektrum™ DSMX® technology that delivers fully proportional throttle, elevator and rudder control.
Batteries and Chargers
The RTF version of the UMX Vapor FPV includes all the batteries you need to fly as soon as possible, including the AAs for the transmitter. The Fat Shark Teleporter V4 headset operates from a 760mAh 2S 7.4V Li-Po battery for long play times and can be recharged using the included AC charger. Both the aircraft and airborne FPV system operate from the same ultra micro 150mAh 1S 3.7V 25C Li-Po battery that can be recharged with the included USB 1S Li-Po charger.
Motor & Propeller
The proven UMX Vapor FPV micro electric drive features a brushed 6.0mm coreless motor that’s geared to efficiently power a 140mm x 45mm propeller. The transparent propeller allows the image quality to be less obstructed.
Product Specifications
Wingspan: 14.8 in (376mm)
Overall Length: 15.3 in (389mm)
Wing Area: 79.0 sq. in. (5.10 sq. dm.)
Flying Weight: 24.0 grams (0.84 oz)
Motor Size: Micro Electric
Radio: MLP4DSM 4-channel DSMX transmitter (included)
Prop Size: 140mm x 45mm
Speed Control : Brushed ESC (included)
Recommended Battery: 3.7V 1s 150mAh LiPo Battery
Experience Level: Intermediate
Recommended Environment: Indoor/Outdoor
Is Assembly Required: No
Needed to Complete
Nothing! Everything you need to get in the air is included in the box. Just charge your battery and you're ready to fly!
ChuckTseeker is offline Find More Posts by ChuckTseeker
Old Aug 28, 2014, 04:26 AM
Torx's Avatar
Memphis, TN
Joined Apr 2007
first.
looks awesome, has to have a nice price tag too.
we can use the fatsharks with other fpv models too. should be a nice entry to fpv for alot of people
the camera/video tx module looks very compact and light, should be fun to take off and mod onto other planes/micro quadrotors
Torx is offline Find More Posts by Torx
Old Aug 28, 2014, 05:58 AM
United Kingdom, England, Melton Mowbray
Loving this - any idea when it will be available in the UK?
chris jones is offline Find More Posts by chris jones
Old Aug 28, 2014, 06:04 AM
Mac Smith's Avatar
Joined Jun 2012
Originally Posted by Torx View Post
first.
Weight for the FPV vapor will be 24 g,
The Night Vapor had 17gr, so the difference will be the compibed of the heavier 150mAh Battery ad the Cam/Tx module.
I'm too lazy to do the math at this time though.
There will also be a BnF version minus the (flight)Tx and the glasses.
The cam/tx unit will be available seperately (although with a platic casing as opposed to the naked version on the Vapor),
as will the glasses, and both together as an "Ultra Micro FPV Set".
This is certainly a game changer, although the fatshark in the bundle is a very "budgety" version with only 320x240px.
I'm curious what range it will have and what else Horizon has in store now that they have set ther minds on FPV.
Hand me my popcorn.
P.S.
I love how they labeled it "Experience Level: Intermediate", which may well be true as it's quite heavy for the Vapor platform.
Mac Smith is offline Find More Posts by Mac Smith
Old Aug 28, 2014, 06:12 AM
Mac Smith's Avatar
Joined Jun 2012
No official date yet whatsoever, but my informed optimistic guess is end of October/mid November.
Old Aug 28, 2014, 09:07 AM
Even that isn't fast enough
United States, OK, Edmond
Joined Sep 2004
$450 RTF
http://www.horizonhobby.com/products...adset-EFLU6600
why_fly_high is online now Find More Posts by why_fly_high
Old Aug 28, 2014, 09:08 AM
Joined Sep 2013
Could be worth getting this just to stick the gear in a UM warbird. Will need a second Mustang! Be great in the Trojan too.
Here's the HH vid I just found.
FPV Vapor UMX mit Fat Shark System von E-flite (1 min 52 sec)
schuey19 is offline Find More Posts by schuey19
Old Aug 28, 2014, 09:25 AM
https://www.youtube.com/watch?v=-JLtsfHPPAQ
You can get the gear without the bird!
Old Aug 28, 2014, 09:40 AM
wayfaringdreamer's Avatar
United States, PA, Middletown
Joined Sep 2011
Kind of a crazy idea putting fpv in a vapor!
Would rather see them put it in a larger plane that can take wind a bit better.
wayfaringdreamer is online now Find More Posts by wayfaringdreamer
Old Aug 28, 2014, 09:42 AM
Joined Sep 2004
Seems like the new cub coming out with SAFE technology would be the perfect candidate.
Old Aug 28, 2014, 09:43 AM
Joined Sep 2011
Probably timed this for the winter in door flying season.
Old Aug 28, 2014, 09:46 AM
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
interesting how this cannot be touched by FAA's future regulations as long as its flown indoors. i commend HH on their novel thinking.
cmdl is online now Find More Posts by cmdl
Old Aug 28, 2014, 09:51 AM
Joined Sep 2013
Goggles on their own, not with camera/Tx. BnF has no Tx or goggles, but camera is on plane. So buy the whole shebang, and have a vapor to float in the house. Here in Aus we'll be paying so much for it (as we do with everything) that it will only be worth it if you get the RTF with the goggles (Those who have no FPV gear).
Old Aug 28, 2014, 10:20 AM
You're killin' me Smalls
BrownEyedFool's Avatar
United States, NJ, Hillsborough Township
Joined Sep 2011
needs to be available on the night vapor as well, since the calm air of dusk and night time is much nicer for the vapor.
BrownEyedFool is online now Find More Posts by BrownEyedFool
Old Aug 28, 2014, 10:54 AM
Joined Sep 2004
With infrared camera option.
Sold Turnigy Nanotech 300mah 2s UMX + E-Flite 200mah UMX + Charge Cable electricrc68 Aircraft - Electric - Batteries & Chargers (FS/W) 3 Nov 17, 2013 08:17 PM
Sold E-Flite UMX SBACH 342 and some extras flyhighview Aircraft - Electric - Airplanes (FS/W) 0 Sep 23, 2013 08:47 AM
Sold E-Flite UMX SBACH 342 flyhighview Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Sep 19, 2013 09:15 PM
Sold E-Flite UMX SBACH 342 flyhighview Aircraft - Electric - Airplanes (FS/W) 0 Sep 18, 2013 08:29 AM
