Old Mar 30, 2015, 10:34 AM
Australia
Joined Nov 2009
my latest video from my vector equipped quad. loving the retracts now clean 360 pans from the gimbal
basin (2 min 52 sec)
custards1 is offline Find More Posts by custards1
Old Mar 30, 2015, 04:17 PM
Bobuilt01's Avatar
Joined Feb 2015
Is there anybody out there using the DX6i radio with the vector on a quad?
Bobuilt01 is offline Find More Posts by Bobuilt01
Old Mar 30, 2015, 04:55 PM
United Kingdom, Scotland, Aberdeen
Joined Mar 2010
https://www.youtube.com/watch?v=wHan...ature=youtu.be
Very nice Marty
NEAGRON is offline Find More Posts by NEAGRON
Old Mar 30, 2015, 05:08 PM
HIGHOCTANE32's Avatar
Joined Dec 2013
I have. Why you trying to figure out how to get more modes? I set it up so I had 2D hold, 2d no hold, Loiter and RTH. Involed using 3 switches. Mode, mix and flaps. 2D hold and no hold on mode switch, loiter on mix and RTH on flaps. All 3 towards me was RTH..simplified as I could think to make it. Might be a easier/better way but it worked just fine. I still have it if you need to settings.
HIGHOCTANE32 is offline Find More Posts by HIGHOCTANE32
Old Mar 30, 2015, 07:01 PM
Bobuilt01's Avatar
Joined Feb 2015
Yes I sure could use some help. Lets chat Please
Old Mar 30, 2015, 07:21 PM
Bobuilt01's Avatar
Joined Feb 2015
yes please. Lets chat.
Old Mar 30, 2015, 08:04 PM
Joined Dec 2013
The DX6i is at my shop, I'll get the settings off of it tomorrow. I had them written down..but I guess I tossed the paper. I Responded to your PM also.
Old Yesterday, 07:38 PM
United States, AR, Lockesburg
Joined Feb 2012
I am wanting to take some performance measurements on my tricopter with different props, batteries and prop loading. One thing I wanted to measure was top speed. To make the test repeatable I was thinking of setting the RTH speed high and let the vector find the top speed of the Tri. Never tried to get the vector to achieve and unattainable speed. Anyone see a problem with this.
Petrie is online now Find More Posts by Petrie
Old Yesterday, 07:41 PM
United States, CA, Pleasanton
Joined Feb 2013
Won't it just fly into the ground when it can't maintain the altitude? My vector definitely loses altitude if I pitch it forward too far.
Noircogi is online now Find More Posts by Noircogi
Old Yesterday, 07:44 PM
Joined Dec 2013
Sounds like a bad idea to me on multiple levels lol..for starters what if something happenes and you really need to use RTH? Do you really want it to come screaming in a max speed? Why not just fly it and review the logs after the fact if you are worried about not being able to monitor the GPS speed while flying max blast?
Old Yesterday, 07:47 PM
Joined Dec 2013
I would hope the vector would choose the fly home alt over the speed..but like I said above..trying to do this is likely a bad idea. Let us inow how it works out if you try it. Personally Id just fly and look at the logs for the data.
Old Yesterday, 10:36 PM
Joined Feb 2012
Your right the logs sound like a much safer plan. However, I was planning to do it all LOS. Someday might have to try it anyway now to see who can fly it faster.
quadcopter007fpv's Avatar
United States, CA, Riverside
Joined Feb 2012
will the vector work with ppm on the range link , is there a difference between sppm and ppm ?
also is there a way on V tail setup to have the ailerons connected to the vector so that a Y harness is not needed and thus the ability to program flaps in the radio ?
quadcopter007fpv is online now Find More Posts by quadcopter007fpv
Old Yesterday, 11:30 PM
It's Just a Hobby!
Sudsy's Avatar
Joined May 2012
First Quad Setup with Vector
I am setting up my first quad copter with Vector.This Quad previously had an APM 2.5 and I am replacing it with the Vector. I have a couple of questions....(oh yea I changed the motor number assignments from the APM setup)
1. How should I set up my Mode switches? I have two switches and am going to try to see if I can set up a third switch on my er9x transmitter. With the two switches now I have setup the three way switch as main Mode switch and the Aux switch (2 pos switch). I have them set as follows:
(3 way)
3= 2D + sub
2= 2DH
1= 2D
(2 way)
2= RTH Test or Loiter (depends on 3rd switch setup)
1 = loiter or Polar Mode (same as above)
Switch 3 (if I can figure it out)
2=RTH test
1= not used
The plan as I see it.
Take off with both switches down (pos 1) and after establishing steady flight I can switch the 3 way up to pos 2 and have 2DH. If I go to position 3 it will be Loiter with the sub mode still down and if I need RTH test I can switch both switches up.
I am going to try to figure out how to move the RTH Test to a third switch, the throttle cut switch and make it so I have to turn that switch to the Up position for RTH Test and maybe set up the other position to Polar. Or I could also setup the third switch to RTH Test and Not Used for the other position and make the Aux switch Loiter and Polar. That would make that switch like a dedicated RTH Test switch with Mode switch in 2D + Sub.
There seem to be many ways to do this and all I want to do first is get the thing to fly normally.
This is on a F450 Quad with NTM 28-30 800kv motors and Simon K 30 amp ESCs. FrSky X8R rcvr and er9x running on a 9x transmitter.
Sudsy
Sudsy is online now Find More Posts by Sudsy
Discussion Why are we up in arms about quad over flights, but not about this? branflakes Multirotor Talk 5 Jan 25, 2015 08:18 PM
Discussion Dreaming about Multi Rotor setup : Multi+GoPro+eagle tree everything? crashtested Aerial Photography 10 Apr 05, 2014 06:46 PM
Discussion a good interview about gun control and why we carry ... logan5 Life, The Universe, and Politics 8 Jan 08, 2013 06:43 PM
Discussion I just had the wildest dream about FPV jhroof FPV Talk 0 Sep 04, 2012 09:55 PM
Discussion Pitch curve, we talk about anything and everything scale heli here cap231ex Scale Helicopters 1633 May 17, 2012 01:50 PM
