Old Dec 10, 2014, 04:52 AM
bigheadfpv is offline
Find More Posts by bigheadfpv
Joined Jul 2012
New Product
SKY-N2000 FPV 5.8GHz 2000mW 32Ch A/V Transmitter with display
http://i00.i.aliimg.com/photo/v0/601...0mW_32Ch_A.jpg
http://www.bigheadfpv.net/product/60...h_display.html
Welcome to enjoy the Skyzone wireless AV transmitter. SkyZone products have forged a reputation for quality and reliability and are tested and developed by FPV pilots for FPV pilots.
The SKY-N2000 Transmitter packs a whopping 2000mW of ultra clean 5.8GHz power! A must for those looking for longer range and locked in video. The N2000 can transmit a full range of 32 channels and comes with a clean pre-wired harness, itís perfect for any long range aircraft!
The N2000 boasts an impressive new feature, the transmitting band and channel can be changed remotely by the user with a 3 position switch on their radio. This means you can quickly change to a clear band and frequency should you encounter interference on your existing channel.
Features:
128x64 super bright color digital display with High Brightness Contrast , clearly visible under the sun
Channel and Frequency clearly visible on screen
Output power 2w, distance no less than 2Km with 2dbi Omni directionalantenna
2Ch video input, Remote channel switching via spare channel on RC transmitter
Support 2-6S battery and low battery alarm
Battery Voltage display
Screen Display: Current/Temperature/PA Power detection
Packing Accessories List
1 x 5.8G 2000mW transmitter
1 x Stock dipole whip antenna
1 x Power in harness
1 x Power out Video out Audio out harness
bigheadfpv is offline Find More Posts by bigheadfpv
Old Dec 10, 2014, 10:45 AM
bandito66 is offline
Find More Posts by bandito66
Joined Apr 2006
Is it possible to order an item directly ?
bandito66 is offline Find More Posts by bandito66
Old Dec 10, 2014, 04:35 PM
Joined Jul 2012
yes. Of course. What's the shipping address?
Old Dec 22, 2014, 01:52 PM
hexyMoth is offline
Find More Posts by hexyMoth
"Porkins"
Canada, BC, Victoria
Joined Jun 2014
Hi, this looks like a great product. I love the integrated switching and OSD capabilities. I've been waiting for someone to do it. Question: Is the transmission strength configurable? Can I drop it down to 600mw, 200mw, if I'm flying closer and don't want to strongarm the band? Also, I don't see the weight in grams anywhere on seller's sites. Can you provide that?
hexyMoth is offline Find More Posts by hexyMoth
Old Dec 25, 2014, 01:49 PM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Hello,
Does the product have antenna protection? I mean if it burns out when works without antenna?
Firatp is offline Find More Posts by Firatp
Old Dec 25, 2014, 09:08 PM
Joined Jul 2012
The antenna must be connected before power the transmitter.
Old Jan 12, 2015, 06:36 AM
soccerj4y is offline
Find More Posts by soccerj4y
soccerj4y's Avatar
United States, VA, Chesapeake
Joined Aug 2013
What is weight and dimensions on this?
soccerj4y is offline Find More Posts by soccerj4y
Old Jan 27, 2015, 11:07 PM
cronicash is offline
Find More Posts by cronicash
Cronicash
New Zealand, Bay Of Plenty, Rotorua
Joined Dec 2014
Weight of this is around 50-60 grams.
Dimensions of the N2000 are L 65mm x D 38mm x H 25mm.
Runs just as warm as the fatshark Tx next to it in the picture. Active cooling is very quiet with next to nil vibration.
Transmission strength is not configurable by buttons but by supply voltage. 6.5v = 27dbm, 12v = 30dbm & 28v = 33dbm
cronicash is offline Find More Posts by cronicash
Old Feb 03, 2015, 03:51 PM
Tas sky pirates is offline
Find More Posts by Tas sky pirates
Joined Apr 2014
I got mine in the mail yesterday. weight is 64 grams without wires or antenna.
will be doing more testing and a video in the coming days.
I have a Bix3. not sure where it will be placed as yet. i'm thinking in the fuse with a sma cable to the antenna a bit higher up from cockpit
Tas sky pirates is offline Find More Posts by Tas sky pirates
Old Feb 09, 2015, 04:53 PM
Joined Apr 2014
OK. so i learned a few things.
FIRST: this unit does not have reverse polarity protection.
SECOND: it has the same plugs as ImmersionRC, with one distinct DIFFERENCE!!!!!! the + & - are reversed. so if you try to use it as a part of your EZOSD setup, dont. or at least dont just plug it in. puff goes the smoke.
that is the end of my review, until i either figure out how to fix the blown circuit (if i can even find it), or i get a new one.
Old Feb 09, 2015, 09:30 PM
gbmarsh is offline
Find More Posts by gbmarsh
Wait...what?
gbmarsh's Avatar
Canada, BC, Abbotsford
Joined Sep 2010
Why on earth would anyone want or need 2000mw on 5.8ghz?
Get some good antennas and use 200-600mw and fly as far as you want without all the excess energy wasted on heat. Not to mention blasting out this much RF energy is going to play havoc with other electronics.
Cheers,
Geoff
gbmarsh is offline Find More Posts by gbmarsh
Old Feb 10, 2015, 12:26 AM
Joined Apr 2014
lol i usually rock the 600mw immersion, but i got asked to give this a review. in theory it is a great product. the built in video switch, that fact it is very simple to change channels (ie it says 5800, 5805, 5810... etc etc), it is very handy IMO. i really like the built in screen. Also, i had planned to use it to cause havoc during flying battles with the switchable video channels. oh well.
Old Mar 02, 2015, 04:24 PM
rewen is offline
Find More Posts by rewen
Canada, ON, Oakville
Joined Jan 2015
I purchased one of these recently. New to FPV. We'll see how well I make out with it..
rewen is offline Find More Posts by rewen
Old Mar 03, 2015, 01:38 PM
rewen is offline
Joined Jan 2015
I saw mention of it sending battery over OSD or something? Did I just misinterpret this? Sounded like it could overlay the battery voltage without an additional OSD module. This would be awesome..
Old Mar 09, 2015, 10:05 PM
rewen is offline
Joined Jan 2015
Does this translate to different mw output? I am confused
Discussion 5.8GHz 32CH A/V 600mW Transmitter (TS832) WBFlyer FPV Talk 6 Sep 12, 2014 01:38 AM
Found 5.8GHz 32CH A/V 600mW Transmitter (TS832) G-unit FPV Equipment (FS/W) 2 Jan 11, 2014 10:14 PM
For Sale 5.8G 600mW 32CH A/V Transmitter 32CH A/V Receiver (RX) RP-SMA fpvhobby_mandy FPV Equipment (FS/W) 2 Dec 18, 2013 09:32 AM
For Sale FPV 5.8G 600mW 32CH A/V Transmitter 32CH A/V Receiver (RX) W/ LED Channel fpvhobby_mandy FPV Equipment (FS/W) 6 Oct 11, 2013 03:06 AM
