Old Oct 15, 2014, 05:46 PM
Joined Dec 2008
Xenon I got this recipe from someones build here on Rcgroups and it really works well - 50/50 combo of Daps fast and final light weight filler and Durhams rock hard putty . I had the same issue with the glue ridges . The filler combo really works well . You won't regret it . The Daps is user ready and the Durhams is a powder you mix first until you have a thick pancake batter , then mix with the Daps . Do yourself a favour and get a Dremel Sander , if you don't already have one ..
pencon is online now Find More Posts by pencon
Old Oct 15, 2014, 05:47 PM
I don't like your altitude
Stupot46's Avatar
Joined Sep 2011
Originally Posted by xenon20 View Post
Thanks for your links guys. Stupot the stuff you linked to looks fairly similar to the 'big boy' stuff I have been lent, I wonder if it might be worth trying a combination of this and / or lightweight spackle, and some WBPU. I will run some tests as I have these materials to hand.
Nice one ! will report back.
The filler works fine by itself.Spackle is water based(I think)so I doubt it will mix.
Stupot46 is offline Find More Posts by Stupot46
Old Oct 15, 2014, 05:50 PM
Joined Dec 2008
Originally Posted by cetorca View Post
NO, it's a KFIR C10, Own design and steep learning curve on foam work. I've always been a Balsa ribs guy but started foam since I bough a CNC hot wire machine.
Kfir is an awesome looking Jet , looks improved from the Mirage .
Old Oct 15, 2014, 06:02 PM
Joined Dec 2008
I did an experiment with one of the canards and covered it with white Weld Bond glue and newspaper , let it dry and then a coat of WBPU . Very light and very strong . Might just go this route with the whole thing . It'll be a paper mache Saab . Sticks very well to this kind of foam . If any of you guys have experience with the minwax water based stuff , is it better to go a couple of coats and then sand ? I only have one coat on and it is a little lumpy looking .
Old Oct 20, 2014, 10:44 AM
Germany, RP, Nittel
Joined Sep 2014
Had a little accident with mine, hitting a small metal pole, hidden in the grass, at high speed. I had a roll of carbon laying around, so lets make the new wing out of that. It has live hinges made of aramid fiber for the control surfaces, which I still need to cut free. The canards have elevators now as well, also hinged the same way. I haven't decided yet where to put the servo's for them though.
SanderHG is offline Find More Posts by SanderHG
Old Oct 26, 2014, 02:55 PM
Joined Dec 2008
Funny how any pole in a flying area always seems to be a magnet to be hit
Old Oct 27, 2014, 01:44 PM
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Absolutely!
Eric B.
AirX is offline Find More Posts by AirX
Old Nov 28, 2014, 07:06 PM
jurgen01's Avatar
Mexico City
Joined Apr 2007
I sanded after each coat when I did the Viggen and after 4 coats the weave of the fiberglass still shows if you look closely. I used spackle to fill but I'm not very happy with it. It is very light but it seems not to stick very well when you come to very small imperfections like the fiberglass weave.
In my actual project I only passed the sandpaper (320) ever so slightly to remove any rough spots, applied 4 coats without spackle and it looks a lot smoother . Then just after 2 coats of spray can primer the surface looked very nice with no weave visible. But it's not a mirror finish still because lots of small details start to show.
Now I have applied like 6 coats of primer using automotive filler after each coat and sanding it all down again to the base coat and I'm getting close to the mirror finish. I have thinned the filler to be quite thin, let a drop fall on the low spot and then smoothen it out with my fingertip.
Lots of work, but pays off.
jurgen01 is offline Find More Posts by jurgen01
Old Nov 29, 2014, 09:52 AM
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
Just a suggestion. Mix Talcum powered (baby powder) with the WBPU to a consistency of thick pancake batter and apply over the FG weave. It sticks great and fills/sands easily. It turns out super smooth and smells nice doing it
Lt599 is offline Find More Posts by Lt599
Old Nov 29, 2014, 10:31 AM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
LT is right on-- some baby powders use cornstarch-- it won't mix at all .
if it were me I'd give it a thinned coat of epoxy finishing resin. Not much more weight, stronger, more ding resistant, and a superb finish-- It will need to be wet sanded with 400-600 grit paper, however.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Nov 30, 2014, 05:34 PM
Skunkwork's Avatar
Norway, Oppland, Vestre Toten
Joined Feb 2014
Thought I give you Viggen fans a little treat. I took these pictures 3 years ago when I visited Sweden with the Norwegian army They also had one standing ready to take off on the apron in Swedish, green splinter camo that day, one of the few still flying.
Added some pic`s of the little Draken for you Saab Draken builders. This could be a cool edf project. enjoy
Skunkwork is offline Find More Posts by Skunkwork
Old Dec 01, 2014, 11:59 AM
Joined Dec 2008
Great pics Skunkworks , must have been cool to see it in person ..
Old Dec 01, 2014, 12:41 PM
Skunkwork's Avatar
Joined Feb 2014
Thanks Pencon. We where at the nearby shooting range and after we were finished we went to the small museum at the location. Actually on the way home to norway I saw another Viggen on a pole just beside the highway when leaving Gævle city.
Old Dec 02, 2014, 12:29 PM
Joined Dec 2008
That two seater looks great . Mine"s been on hold a while now . $$ is tight this year it seems . Hope to get back to it once I buy a few parts , landing gear is going to be next , but that could be in spring next year .
SAAB VIGGEN KITS or PLANS Sluf7 Fuel Jet Talk 14 Jan 04, 2012 11:30 AM
Saab Viggen 37 Sluf7 Electric Ducted Fan Jet Talk 11 Oct 20, 2008 09:45 AM
Saab J-37 Viggen FoxBAT138 Electric Ducted Fan Jet Talk 42 Dec 01, 2005 12:10 AM
SAAB JAS Gripen & JA 37 Viggen Built up from Plans anywhere Sluf7 Electric Ducted Fan Jet Talk 2 Jun 25, 2004 08:11 AM
Scorpio saab viggen and fantex andrea Electric Ducted Fan Jet Talk 44 Nov 04, 2003 01:55 PM
