Old Nov 25, 2014, 02:19 PM
JM66's Avatar
United States, OH, Rosemount
Joined Jul 2011
Kevin....When I run a castle 10 amp ubec I'll run a Y connector lead .. plug in the bec and esc lead to the Y side and run the other side( Single connector) into my throttle channel on the receiver or any other available free channels.
Note: If you have an esc that has an internal bec you have to disable it or bypass it, so you will need to cut the red wire or pull it out of the plug on your esc lead and then plug it into the Y connector .
JM66 is offline Find More Posts by JM66
Latest blog entry: German Luftwaffe pilots
Old Nov 25, 2014, 04:20 PM
Swindon, Wiltshire, England
United Kingdom, England, Swindon
Joined Dec 2013
Thanks jm66 that makes a lot of sense.
kevin osman is offline Find More Posts by kevin osman
Old Dec 09, 2014, 07:45 PM
Joined Jan 2014
quick question here for you? I was looking at a way to speed up my 1400mm fms zero the zero has the same motor and 70 amp esc do you think I can run that 15x8 on it (going to paint the spinner all black) I might also get a 75 or 80 amp esc if needed thanks for any help
axerhand1976 is offline Find More Posts by axerhand1976
Old Dec 10, 2014, 08:48 AM
This area for rent
Vestal, NY
Joined May 2006
these guys will know better than i, but i believe the new prop has reduced pitch. that will slow you down. you want to do the zip tie mod, that will speed you up. i never did it so one of the other guy will have to tell you where it is in this thread.
Joe
paladin-34 is offline Find More Posts by paladin-34
Old Dec 10, 2014, 05:48 PM
Most people are stupid!
dambit's Avatar
Australia, QLD, Gold Coast
Joined Oct 2011
Also, the Zero is a different scale (smaller) to the 190 and the larger props will not only look silly, but may cause problems on the ground.
If you want to go faster, get a smaller prop with higher pitch.
dambit is offline Find More Posts by dambit
Old Dec 15, 2014, 02:04 PM
Yes it was Abby Normal
Joined May 2012
Gents, The FMS 1400mm ME Bf109f share the same PAEP Gold 4250 580Kv motor and ESC as the 1400mm Zero.....however the Bf109 Spinner back plate is much larger than the 1400mm Zero and each of the blades are farther out from the motor shaft....this makes the Bf109 prop a 15x8x3.
I am not sure what size our FMS 1400mm Zero 3blade prop is for sure yet.
Some of the earlier version of these planes came with a 4250 540Kv motor.....which may have contributed to the discovery of shimming the props to help create more thrust due to the higher pitch.
Anyway - the spinner/prop assembly are vastly different respective to each plane.
I would agree - if you want more speed from the 580Kv motor.....try the shim mod to the stock props 1st or try flying with a smaller size but higher pitch two blade prop & assembly.......I think moving to 5s on these motors are a no go and in fact we have a strong message from the manufacture NOT to operate on 5s.
You might do well to jump onto the FMS 1400mm Zero webthread to glean a little more info:
http://www.rcgroups.com/forums/showt...+Zero&page=403
Then this thread regarding motor and prop set ups...this is your gold mine here:
http://www.rcgroups.com/forums/showthread.php?t=2136362
TwistedGrin
TwistedGrin is online now Find More Posts by TwistedGrin
Discussion fms warbird owners thread warbird_cowboy Electric Warbirds 123 Dec 08, 2014 07:33 PM
Discussion FW 190 1400mm by FlyFly ...wow it's NOT FMS! jbc Electric Warbirds 222 Nov 12, 2014 02:29 PM
Discussion FMS FW-190 800mm range flyball Electric Warbirds 130 Nov 02, 2014 12:38 PM
New Product FMS 1400mm FW-190 Part II Tommy D Electric Warbirds 647 Jul 26, 2012 04:23 PM
Video Formation Flying - FMS Stuka, Hobbico FW-190, Velocity-RC T-33s, and Tsunamis bwoollia Electric Plane Talk 0 Oct 23, 2011 03:45 PM
