Old Aug 09, 2014, 02:39 PM
Joined Aug 2014
KD175 issue
I followed the instructions here to mod a kd175 and was successful. Added a switch, super slow speed fan 1k resistor and pot, ovp and pot. Successfully running at 14.4v
I bought a second kd175 from the same place and did the same steps. For the life of me I can't get the voltage higher then about mid 13's. I even went as low as 15 ohms between D3 and D4. I measured the first supply's pot and it took 44 ohms to get it at 14.4v. I removed the ovp jumper and it didn't make a difference.
Any thoughts? I wonder if the calibration of the second psu is somehow different then the first. I tried moving the big pots a small amount one way or the other and it didn't change anything (VR200, VR201, VR601). All the connections seem tight.
pierre1 is offline Find More Posts by pierre1
Old Aug 10, 2014, 12:29 PM
satgod's Avatar
United States, KY, Hardin
Joined Jun 2011
Originally Posted by k2roo View Post
Hi all,
I have taken on this project to save some coin, however I need a little assistance. I have read through this forum a little but I am unsure if I am able to connect the power leads in the format I have chosen.
I have 1 set of leads powering a PL8 and the second set will be connected to a banana plug board on the outside of the case. Could somebody please tell me if my format is acceptable and correct? I also have a SPDT I will be connecting with a servo extension lead, I know the correct pins to attach it to on the proliant but I am unsure what color wire to connect to which pin on the switch.
Any help would be appreciated
I had picked up 2 of these about a year ago and they make a ton of power but the fans sound like miniture jet engines, there is a resistor fan mod for them but I have found that the DSP1200FB is a much nicer supply to use.
Two in series with ground isolation mod give my PL-8 charger more than enough power to charge anything I throw at it
Even the big 6s 5800mah packs for my 750 heli
satgod is offline Find More Posts by satgod
Old Aug 12, 2014, 08:48 AM
Joined Jan 2014
Drilling through PCB
Hi! Quick question, can i drill through the positive and negative pin on the pcb so that i dont have to solder? Making the binding post pointing up instead to the back?
I have the Dps 1200 fb
Description: Drilling PCB
Thanks!
SadikPOGI is offline Find More Posts by SadikPOGI
Old Aug 12, 2014, 06:16 PM
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Thanks!
Nope. That is a multi-layer board and there are other lines sandwiched in between these. I found out the hard way. Lucky for me it still worked but I feel I got lucky. I did not install the binding post but soldered directly after seeing the shorts I caused and then fixed (3 hour job).
Rick
rampman is offline Find More Posts by rampman
Old Aug 14, 2014, 09:43 AM
Joined Jan 2014
Got it! Thanks
Old Aug 18, 2014, 09:29 PM
Emress
sirbow2's Avatar
United States, SD, Rapid City
Joined Nov 2011
If anyone ever gets a PS-6301-1 i made this handy image.
sirbow2 is offline Find More Posts by sirbow2
Old Aug 19, 2014, 12:12 AM
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Thanks.
I posted a link to this on the sticky reference thread.
John
jj604 is online now Find More Posts by jj604
Old Aug 22, 2014, 08:25 PM
Joined Aug 2014
Hi,
How to turn then on IBM AWF-11DC-1400w ?
costefan is offline Find More Posts by costefan
Old Aug 23, 2014, 01:16 PM
Joined Aug 2014
Compaq ESP 100 series
hello
any one know how to get a Compaq ESP 100 serie to start up with the pin connections
thanks if some one knows
Raypikeman is offline Find More Posts by Raypikeman
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
