Old Jun 02, 2016, 03:14 PM
exf3bguy is offline
Find More Posts by exf3bguy
United States, CA, Sacramento
Joined Oct 2011
In need of ideas
While getting ready for this weekends TD contest I assembles my Muller Cobra to make some adjustments on the flaps. I noticed I have a dead aileron. On closer look the servo is dead. I plug in a new servo and all it does is cycle from one extreme to another. I plug the servo directly into the RX and all is fine. After some probing with a multi meter it would appear that the wire within the wing has developed a short. When the signal wire and positive wire are probed at the same time I am reading connectivity instead of an open. OK so the wire has to be replaced. The question is how? The wire seems to be glued in place. This is a veneer sheeted foam wing. The only solution I can think of is to sharpen a long brass tube and try to cut a new hole through the core. Does anyone else have a better suggestion?
exf3bguy is offline Find More Posts by exf3bguy
Reply With Quote  (Disabled)
Old Jun 02, 2016, 03:21 PM
jtlsf5 is offline
Find More Posts by jtlsf5
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
Shawn,
Cutting a long hole with a brass tube is a pain. If you're going to do it, file a few notches in the boring end of the tube and cut your way in.
My preferred method, since you will be replacing the wire would be to burn a channel. This is cleaner, but takes some time, jigging, and practice. You could do this ~ 1/2" away from the existing channel, then access on either end.
If you like, I'd be glad to do this chore with/for you, understanding your hand issue. Give me a call (I'll pm my number).
JT
jtlsf5 is offline Find More Posts by jtlsf5
Old Jun 02, 2016, 03:22 PM
dephela is offline
Find More Posts by dephela
What's wrong with heavy?
dephela's Avatar
USA, CT, Hamden
Joined Oct 2002
Yes, the wires are locked in the foam, no large open channel for them to run through on a Muller wing. Put a flat tip on a piece of music wire and drill it up the wing? Gonna be tough, that's a long run.
dephela is offline Find More Posts by dephela
Old Jun 02, 2016, 03:26 PM
Kiesling is online now
Find More Posts by Kiesling
San Diego
Joined Aug 2004
Burning a channel is probably the way to go like Jim said. Taking him up on his generous offer is probably a good idea. It isn't hard to do, but experience helps - especially since you will be doing it on a finished wing.
Tom
Kiesling is online now Find More Posts by Kiesling
Old Jun 02, 2016, 03:29 PM
Avaldes is offline
Find More Posts by Avaldes
Avaldes's Avatar
United States, CA, San Luis Obispo
Joined Aug 2006
Mueller wings were a pain because of the way they buried the wires in epoxy. I would have to think that the short must be at either end and not in the middle of the run. Perhaps you can chip away some of the epoxy and find the offender?
Otherwise Jim has the right idea. Those furniture wings sure were beautiful!
Avaldes is offline Find More Posts by Avaldes
Old Jun 02, 2016, 03:36 PM
exf3bguy is offline
Joined Oct 2011
Thanks guys, spoke with JT and am headed over to his place.
Old Jun 02, 2016, 05:39 PM
jtlsf5 is offline
jtlsf5's Avatar
Joined Jul 2007
The deed is done. New channel burned cleanly just ahead of the old wire location, centered in thickness. Opened up access at servos bays and strung new wires. Shawn should have this flying again in short order, just needs to do a little soldering.
JT
Old Jun 02, 2016, 10:59 PM
exf3bguy is offline
Joined Oct 2011
Thanks to JT the job is complete. Both aileron and flap wires have been replaced, I found a 4 pin header that was a good match to what is installed into the fuse. The sailplane is charging right now waiting for tomorrow's practice session. Big thanks to JT.
Old Jun 03, 2016, 09:37 PM
airporter is offline
Find More Posts by airporter
United States, IA, Urbandale
Joined Oct 2002
JT IS the guy. A good friend is beyond value.
One thing to perhaps make the job easier if it's ever needed to be done again - use the old wires to guide the brass tube for the new hole.
airporter is offline Find More Posts by airporter
Old Jun 03, 2016, 11:34 PM
exf3bguy is offline
Joined Oct 2011
I thought about that but the original wires are right up against the wing sheeting and I would have been cutting through a mix of epoxy and foam. I could just picture the tube coming through the sheeting.
Discussion Need ideas. Build or buy. bullgoose Scratchbuilt Multirotors 3 May 19, 2016 07:59 PM
Discussion New plane, need ideas Dale Sawchuk Electric Plane Talk 1 May 18, 2016 01:31 AM
Discussion No idea whats wrong. Need Tips Darkflawd Multirotor Electronics 1 Apr 07, 2016 10:33 AM
Discussion Need ideas on a plane carrier for my scooter Capt Ed Electric Plane Talk 1 Mar 28, 2016 07:09 AM
Discussion Need ideas for 1300mah 3s bobbyblank Foamies (Scratchbuilt) 9 Oct 07, 2015 09:28 PM
