Old May 11, 2016, 12:28 PM
harrier81 is offline
Find More Posts by harrier81
Pedro Salomón
harrier81's Avatar
Joined Apr 2005
Maintainance for a 4 stroke OS 70 Surpass I
Hi Guys:
I have this engine wich is disasembled for cleaning pourpouses as i got it from ebay but dirty and sticky, i managed to move propeller fut feels with no compression so i decided to open it.
I can´t take the piston pin out of the piston, so i can´t continue with disasembling it. i just took out the plastic cap in piston pin wich is pretty stuck to the piston.
What do you recommend to take the pin out? can I heat the engine?, any liquid WD-40?, glow fuel?, paint thinner?.
I am driving crazy with this
harrier81 is offline Find More Posts by harrier81
Old May 11, 2016, 03:57 PM
706jim is offline
Find More Posts by 706jim
Canada, ON, Thunder Bay
I recently overhauled a couple of gummed up OS engines. Heat will help loosen the stuck wrist pin. If you removed the plastic end pad, you can try inserting a tapered nail set into the center hole in the pin. That eventually worked for me.
706jim is offline Find More Posts by 706jim
Old May 11, 2016, 07:42 PM
Cougar429 is offline
Find More Posts by Cougar429
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
Heat is good, but you should also introduce a cleaning agent, as well.
Methanol is the basis of the original fuel and works well, even if left to soak at room temp. Depending on choosing to warm it up, flammability can present problems so there is another method we have used for decades.
If you have a crock pot dunk the bits in glycol and heat it for a while. This is toxic so two rules: Do it outside or in a well ventilated area and never use that pot for food prep ever again.
You would be surprised at how well this works. As little as 30 minutes can take a clogged, congealed or one with burnt oil and make it look new.
I found a pot at a resale shop for $8. The glycol can be filtered and reused so the price should be manageable, especially if used often. I rebuild numerous engines for myself and friends so it works out.
Along with some recommendations one warning
A) Glycol is not harmful to any gaskets or rubber O-rings or seals, so should be O/K if engine mostly left intact.
B) You will want to open the case, easiest by removing the rear cover.
C) DO NOT rotate the crank until this has been soaked. Even hardened lube can damage the bearings if left in the races. Wait till it has been soaked first. It will likely free up the ring, as well, so you can remove it to clean inside the groove.
D) If the bearings are good you need to rinse the engine of remaining glycol and try and get any contamination out. You will need to treat the bearings and any other ferrous bits with oil immediately after drying as corrosion can begin rather soon. It also helps lube any moving bits.
Now the warning: When the parts are removed from the pot they can be extremely hot, so try to avoid direct contact. I made a screened cage with a handle to place all the pieces in and can pull them out and rinse without risk of burns.
Now to servicing the engine. OS have removable heads so you can take a closer look at the valves and seats. Most often the exhaust will be the one with the most carbon or burn lube so that is the most likely to have some caught between the valve and seat. Ensure everything is clean and free.
I find bearings are one of the most vulnerable so most often replaced. If the engine has not been taken care of or stored properly they can be damaged in ways that may not show up till later. A good check can make life a lot easier.
These engines have a higher parts count, but if properly serviced can be completely torn down and reassembled relatively easily. Proper cam timing is the most critical. There are some good resources with pics and instructions if you require.
Where are you located?
Cougar429 is offline Find More Posts by Cougar429
Old May 11, 2016, 10:50 PM
boothg-3 is offline
Find More Posts by boothg-3
texas
Joined Feb 2010
It is good to see a good and straight forward reply with the pertanent info he op asked for
boothg-3 is offline Find More Posts by boothg-3
Old May 12, 2016, 11:22 AM
Pedro Salomón
harrier81's Avatar
Joined Apr 2005
Hello Cougar429 thanks for your detailed explanation, will try this with the engine and then see if the piston pin comes out. I am located in Puebla, Mexico.
Please, send me those resources as one pic is worth thousand words...jeje.
Cheers.
Pedro
Old May 12, 2016, 07:26 PM
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
No problem. Even if the previous poster was being sarcastic, figured if the info was no help to you, may have been useful to anyone else finding this thread.
Here are a couple of good threads:
http://www.rcgroups.com/forums/showthread.php?t=863308
http://www.rcgroups.com/forums/showthread.php?t=1865757
Old May 12, 2016, 07:31 PM
boothg-3 is offline
texas
Joined Feb 2010
No sarcasm was intended , I was glad to see an honest post , used to that datsunguy and his buddies trashing such threads
Old May 12, 2016, 07:40 PM
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
No problem and all too true. See too much of that.
Old May 13, 2016, 07:02 AM
I TOBOR is offline
Find More Posts by I TOBOR
I TOBOR's Avatar
Joined Feb 2007
http://www.osengines.com/parts/xr34700.html
Here is a parts list for the Surpass II, I don't know how closely they are related if at all. Manual too.
http://manuals.hobbico.com/osm/34000-manual.pdf
Cougar, the big brown truck is dropping an OS .95v here today. I'll report, it'll be a few days, I am re-charging the AC system on my truck today and leaving for Missouri to fish for a week tomorrow. Sometimes fun gets in the way fun.
I TOBOR is offline Find More Posts by I TOBOR
Old May 13, 2016, 07:12 AM
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
See, that's why you want an amphib or two. Fill in the time between filleting.
Old May 13, 2016, 07:16 AM
I TOBOR is offline
I TOBOR's Avatar
Joined Feb 2007
Walleye's are good, we're going to Stockton Lake we usually stop at the Bass Pro shop in Springfield on the way.
The .95v should fly a pretty good floater.
Old May 13, 2016, 12:36 PM
Pedro Salomón
harrier81's Avatar
Joined Apr 2005
cougar thanks for the links, fist one is great ! made me wish to have a blasting machine, great restoration results. Second one, a lot of useful info but no pics.
Cheers.
Pedro
Old May 14, 2016, 08:16 PM
Pedro Salomón
harrier81's Avatar
Joined Apr 2005
Hi Guys, well after hours of trying to get piston pin out, I decided to sacrifice conecting rod as i have a spare one. So, i dremel conectin rod and broke it in the middle very carefull way with out touching other parts.
Once piston was out i needed to use the hammer like 5 times to take the pin out, it was really stuck and gummed up.
Well, i reassambled the engine today and had a run, it is performing well in high speed but need to work on air-fuel mixure so it stays runing on low speed.
Will se if i can up load a video of first re-run today.
Cheers,
Pedro.
Old May 15, 2016, 05:13 AM
dmrcflyr2 is online now
Find More Posts by dmrcflyr2
Engine man
dmrcflyr2's Avatar
United States, FL, Largo
Joined Feb 2006
Cheers,
Pedro.
That is truly unfortunate. With the proper application of heat , oil, solvents, and patience that pin would have come out. I have yet to ever have to resort to destructive means to get a wrist pin out.
dmrcflyr2 is online now Find More Posts by dmrcflyr2
Old May 17, 2016, 03:02 PM
Pedro Salomón
harrier81's Avatar
Joined Apr 2005
Video of engine running after major surgery.
https://www.facebook.com/psalomonmx/...type=2&theater
Sold o.s. surpass 70 4 stroke motor buddertoast Aircraft - Fuel - Engines and Accessories (FS/W) 1 May 21, 2016 03:58 PM
Sold OS FS-91 Surpass, OS FS-48 Surpass, OS FS-30S Surpass 4-Stroke **Reduced** ap_rpm Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 17, 2015 09:22 AM
Sold OS 4 stroke tuned pipe for FS-70 and FS-91 Surpass nero1156 Aircraft - Fuel - Engines and Accessories (FS/W) 4 Nov 17, 2014 05:39 PM
For Sale OS 4 stroke tuned pipe for FS-70 and FS-91 Surpass nero1156 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Dec 29, 2013 11:36 AM
Sold (NIB) OS .70 Surpass II 4 stroke stafphoto Aircraft - Fuel - Airplanes (FS/W) 2 Sep 28, 2005 10:50 PM
