Old Mar 08, 2015, 01:06 PM
CC268 is offline
Find More Posts by CC268
United States, AZ, Cave Creek
Joined Aug 2011
21st Century vs. Top Flite covering iron?
Which do you guys prefer between the two of these? I like to use Hangar 9 Ultracote...
CC268 is offline Find More Posts by CC268
Old Mar 08, 2015, 04:02 PM
ZAGNUT is online now
Find More Posts by ZAGNUT
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
the 21 century iron has really nice temp control but that stupid shoe shape is totally freaking useless IMO, especially the way the bottom angles up at the tip. after trying to use it just once i butchered the thing and made a new shoe that has a sharp edge all the way around. but i didn't stop there, i also put a little handle right on top of the shoe.....and separated the electronics section from the new handle with a couple of feet of cord. works good but the cable is kinda stiff so next time i use it i'll probably just chop the cable right off and heat it by setting it on top of an old clothes iron turned upside down....cordless covering iron.
....if it ain't broke fix it 'till it is...
ZAGNUT is online now Find More Posts by ZAGNUT
Old Mar 08, 2015, 04:49 PM
ckimmey is offline
Find More Posts by ckimmey
Master of the 1 point landing
ckimmey's Avatar
United States, IN, New Palestine
Joined Aug 2011
21st century here too. You can tack down ultracote well with it set at 225F. I set it a bit higher if I am covering a sheeted area. I also use higher temp for monokote. Parklite uses slightly lower temp than ultracote.
However, the "temp" is not necessarily accurate. Test it out and see what works for you. I, personally, don't have a problem with the shape of the shoe. I really should use a sock over it too, but I never remember when I am at the hobby shop or online shopping.
I never used the TF iron, so I have no firsthand knowledge of it.
ckimmey is offline Find More Posts by ckimmey
Old Mar 08, 2015, 11:12 PM
CC268 is offline
Joined Aug 2011
It seems a lot of people have complained about the shape of the 21st Century...wondering if I should just go with the Top Flite
Old Mar 08, 2015, 11:26 PM
babblefish is offline
Find More Posts by babblefish
Yes, that is Jamie
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
Haven't used the 21st Century iron before, but my Top Flight iron has been with me for the past 37 years or so and hasen't failed me yet. Works well with Ultracote and low temp coverings. I stopped using Monokote 30 some odd years ago and gave away my stash after I discovered it turned brittle with too much exposure to sunlight, amoungst other issues it has that I didn't like.
babblefish is offline Find More Posts by babblefish
Old Mar 09, 2015, 08:01 AM
bullseye000 is offline
Find More Posts by bullseye000
bullseye000's Avatar
Aurora Municipal, Illinois, United States
Joined Jul 2002
After my old Top Flite took a dump I bought a 21st Century. The new Top Flites aren't made like they used to so I tried something different. I use 2 irons at different temps so I bought a second. Regardless of which one you go with buy yourself one of those little pocket thermometers to help set your temp. Follow the directions that came with the covering for setting the proper temps.
bullseye000 is offline Find More Posts by bullseye000
Old Mar 09, 2015, 01:29 PM
CC268 is offline
Joined Aug 2011
Hmm...so I see a lot of people complain about the shape and profile of the 21st Century iron. I have used the Top Flite iron myself and it seemed great. I am a bit skeptical of the 21st Century.
Old Mar 09, 2015, 07:26 PM
Yes, that is Jamie
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
It looks nice...
I can see how the way the nose/tip being up turned like the bow of a boat would make it a little inconvenient when trying to get into corners and such.
Old Mar 11, 2015, 04:58 PM
DGrant is offline
Find More Posts by DGrant
DGrant's Avatar
United States, CA, Clovis
Joined Mar 2004
I wouldn't own any other iron other than a 21stCentury. I actually like the shoe. I used the "TopFlite" style of iron many years ago... theres many on the market that have a very similar style shoe like the TopFlite... Royal comes to mind also for that style shoe..
When Coverite came out with thier 21stCentury iron(probably over 20yrs ago now).... I bought one and never looked back. I've been using film covering for well over 30yrs, and have had some knock-out farely complex schemes.... all done with the 21stCentury iron. I honestly think it has alot to do with the temp/thermostat stability... which is better then anything on the market right now in my mind.
I'm on the third one now, and each one has lasted several years... and if it went out today, I'd go buy another one. I might be the odd one out here on this iron, but I come from the days of using my wifes clothes iron.... and I think I'd rather use the clothes iron then any TopFlite, or any other square shoed iron.. as there isn't much diff in them.(PS.. I can get very good results from a clothes iron too..haha.).. Thing is, I can easily afford any of them... so money is definately not an issue for me.
DGrant is offline Find More Posts by DGrant
Old Mar 11, 2015, 09:18 PM
CC268 is offline
Joined Aug 2011
Do you use a sock on the 21st Century? If so, what kind?
Old Mar 12, 2015, 09:09 AM
Joined Jul 2002
The original iron designs were borrowed from the photography industry. Heat activated tape was used to mount photos and the iron generated the heat. The 21st Century iron is a big improvement over that design. I find the shape to be well thought out and it does hold the temp.
I use a sock on my irons. I've used the ones Tower sells and a couple of years ago a couple of local women would show up at the swap meets selling excellent cotton socks for about half the price. They worked the best. I have one left and unfortunately they don't appear at the swaps anymore. I've heard tell cotton baby socks work well and may give those a try.
Old Mar 13, 2015, 10:34 PM
DGrant is offline
DGrant's Avatar
Joined Mar 2004
I use a stock sock for shrinking and such about half the time if that....
I use a bare iron for sealing, as I found the iron seals much better with no sock.. and I can take advantage of the shoe shape ...
I've also found as some others have that newer Monokote doesn't adhere like the old stuff... but with a bare iron, and higher heat, I really have no trouble at all.. I just have to be careful not to scuff the film... and/or the iron.
The socks definately don't last in my experience though... so once I burn through one, I just grin and "bare" it until I get to the hobby shop.
I've not tried a baby sock.... and I'm not sure it would allow enough heat to get the results I like... apparantly others use those with success.... I on the other hand seem to do fine without.
Trim solvent on the other hand is a must... That stuff keeps everything clean including the shoe on the iron.... and Monokote sticks like no other with it... great stuff.
Old Mar 15, 2015, 08:32 AM
Trey4U is offline
Find More Posts by Trey4U
United States, AL, Daphne
Joined Nov 2009
Being cheap I've always used a white athletic sock. Push the Top Flite iron all the way in and twist the upper part of the sock around the handle. Never had an issue.
Trey
Trey4U is offline Find More Posts by Trey4U
Old Mar 15, 2015, 09:12 AM
Redtail_Customs is offline
Find More Posts by Redtail_Customs
Joined Dec 2014
I bought the 21 when they first came I still use them For me they just work better
Redtail_Customs is offline Find More Posts by Redtail_Customs
Old Mar 16, 2015, 09:42 AM
grosbeak is offline
Find More Posts by grosbeak
Illegitimi non carborundum
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
I have both the large and small Coverite irons and they work very well. I use a sock but I've stopped buying them from the store. At the moment I'm using a discarded cotton t-shirt with safety pins. I'll probably get a couple dozen socks out of that. After it's used up I'll probably switch to cotton baby socks.
Clamped to keep my hands free.
Not pretty on the back, but who cares?
Here's where it counts.
grosbeak is offline Find More Posts by grosbeak
Sold Top Flite Woodpecker Perforating Tool & Coverite 21st Century Sealing Iron Plasmajoe Aircraft - General - Miscellaneous (FS/W) 2 Feb 09, 2015 12:24 PM
For Sale 21st Century Covering Iron, Trim Iron, Hobbico Deluxe Heat Gun darejohn Aircraft - General - Miscellaneous (FS/W) 2 Sep 20, 2014 06:23 PM
Sold 21st Century Coverite Covering Iron $15 shipped CONUS paypal john-doe Aircraft - General - Miscellaneous (FS/W) 1 Feb 06, 2014 03:57 PM
Sold 21st Century Iron, Top-flite sealing iron 43.00 shipped conus only mikeochs Aircraft - General - Miscellaneous (FS/W) 2 Jun 02, 2011 09:04 PM
Wanted Coverite 21st Century Covering Iron and Top Flite Heat Gun PLATINUM Aircraft - General - Miscellaneous (FS/W) 0 Mar 21, 2006 11:23 AM
