Old Sep 11, 2014, 09:38 AM
Stuck on a rock
epilot's Avatar
Faroe Islands, Sandoy, Sandur
Joined Nov 2000
4" Zero
You may be familiar with this video on Youtube:
How to make the micro ZERO (9 min 57 sec)
I just built the Zero and test flew it in the kitchen last night. Very limited space so the best I managed was 2 circuits. It's on the heavy side at 4.15 gram AUW but the wires to the coil are thicker than they need to be and my connectors are also quite heavy. The horisontal stab could be thinner and the wing TE could be thinned down a bit as well. Something to do for the next one. Prop is from the Cheerson CX-10 quad. It has a 1mm bore so I used some 1mm heatshrink to make it fit the motor shaft. It should be painted but I might just fly this one as is and leave the paint for the next one I build.
I "Toonized" some other planes so we might build a whole squadron of these little models.
epilot is online now Find More Posts by epilot
Old Sep 11, 2014, 02:12 PM
I NEED a micro seaplane lrf!!!
fabersum's Avatar
Torino
Joined May 2007
nice work as usual..
couldn't you cartoonize an Italian fighter too maybe? :-)
fabersum is online now Find More Posts by fabersum
Old Sep 11, 2014, 06:45 PM
Stuck on a rock
epilot's Avatar
Joined Nov 2000
Done!
It's easy. Find a drawing doing an image search in Google. Open in Paint and save with new name. Open old name file in a new Paint window. Resize one of the drawings. Uncheck "maintain aspect ratio" and set horisontal to 70 (or less if you prefer). Go to the other drawing and use the select tool to copy the rudder. Paste the rudder onto the resized drawing.
Old Sep 12, 2014, 03:03 AM
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
very nice Michael! what will you be using to color yours?
on my larger version of this design, i used airbrushed acrylic paint and markers.
derk is offline Find More Posts by derk
Old Sep 12, 2014, 06:01 AM
chulian1819's Avatar
Medellín, Colombia
Joined Apr 2010
great work!
chulian1819 is offline Find More Posts by chulian1819
Old Sep 12, 2014, 07:15 AM
A.K.A sir Crashalot
methuso's Avatar
Östersund, SWEDEN
Joined Sep 2005
Michael
More info on Your eq please
What material, thicknesses and electronics ?
/Ulf
methuso is offline Find More Posts by methuso
Old Sep 12, 2014, 11:20 AM
Stuck on a rock
epilot's Avatar
Joined Nov 2000
2mm hot wire cut beaded styro, 4mm motor from Bidproduct, 20mAh Fullriver lipo, own mfg. actuator with 3x1 magnet.
I just made a new kit from 3mm Depron Aero. With some sanding it's only slightly heavier than the styro but stronger and looks nicer.
Old Sep 12, 2014, 05:26 PM
A.K.A sir Crashalot
methuso's Avatar
Östersund, SWEDEN
Joined Sep 2005
hmm... milled out depron maybe ?
Im going with 1mm sliced wallfoarm and reduced size when i get time to build again.
Old Sep 13, 2014, 03:54 AM
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
Nice work!
Weekend after this is the Maker Faire in NYC. I'm going with a friend and his kids. I'm going to keep my eyes open for affordable (or build able) XY laser or router devices. Not that I can't cut by hand but I like the idea of repeatable precise shapes and incremental changes as I refine a design.
I'll probably have to sell my Makerbot. Nice toy but it takes up prime real estate in my workspace. It's also very finicky about setup.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Sep 13, 2014, 04:20 AM
Stuck on a rock
epilot's Avatar
Joined Nov 2000
Pete, you won't save money on a laser buy building your own compared to the cost of importing one from China. Whatever you do, do not buy one of the $500 desktop lasers. They are utter crap.
Old Sep 13, 2014, 06:55 AM
Stuck on a rock
epilot's Avatar
Joined Nov 2000
Here is a picture of the Zero that I laser cut from Depron Aero. I forgot the rudder over in the workshop.
Old Sep 14, 2014, 10:55 PM
PeteSchug's Avatar
Joined Apr 2004
Thanks for the advice. The Maker Faire is huge, I hope I can see most of it before I collapse.
Making vs buying, the advantage tends to be learning a lot about the hardware. I'd rather buy than build because my space is so limited. I've been through build vs buying before and decided that a man of my age (76) should not waste time building!
That doesn't mean I'm going to buy either. But I am going to shop.
Pete
Old Yesterday, 02:13 PM
Nooflyer's Avatar
United States, MO, KCMO
Joined Aug 2005
Very nice model epilot. Can't wait for video!
Nooflyer is offline Find More Posts by Nooflyer
Old Today, 07:59 AM
Joined Jul 2012
Where can I get the plan?
rcshailesh is offline Find More Posts by rcshailesh
Old Today, 05:51 PM
fabersum's Avatar
Torino
Joined May 2007
Done!
That Macchi MC 200 came out looovely!!!
Discussion Top Flite Zero vs ESM Zero Cls044 Fuel Warbirds 46 Aug 12, 2014 01:03 PM
Sold gmade zero set of 4 103mm $40 shipped. northerngames Cars - Accessories (FS/W) 0 Apr 11, 2014 12:19 PM
Sold gmade zero set of 4 103mm $40 shipped. northerngames Cars - Trucks and Parts (FS/W) 0 Apr 11, 2014 12:19 PM
Help! Spektrum radio with YS Zero Uav 4 ddlt1 Multirotor Electronics 0 Mar 29, 2014 09:29 AM
For Sale Droidworx ADX 4 RTF Zero YSX6 pogmohoin Aircraft - Electric - Multirotor (FS/W) 1 Mar 04, 2014 12:04 AM
