Old Dec 25, 2010, 08:43 PM
rcflyn4fun's Avatar
USA, IA, Colo
Joined Jul 2009
Hitec X4 Charger Product Support
Hey Guys,
I was wondering where the software/PC interface kit is available at? I'm not seeing it anywhere. Where do we get them and how much do they cost? If they aren't available yet, how much longer do we have to wait and who do we purchase them from?
rcflyn4fun is offline Find More Posts by rcflyn4fun
Old Dec 27, 2010, 12:34 PM
Hitec service
BRENDAN LUGO's Avatar
San Diego
Joined Nov 2004
I believe we are expecting to receive this in January.
BRENDAN LUGO is offline Find More Posts by BRENDAN LUGO
Old Jan 25, 2011, 08:26 PM
rcflyn4fun's Avatar
USA, IA, Colo
Joined Jul 2009
Any word yet on these software/interface kits??? With these interface kits will there be update capabilities to be able to make firmware/software changes/updates???
Old Jan 26, 2011, 09:07 AM
Hitec service
San Diego
Joined Nov 2004
No word yet.
I dont believe the software will allow you to make any firmware updates/changes.
Old Jan 31, 2011, 09:35 AM
rcflyn4fun's Avatar
USA, IA, Colo
Joined Jul 2009
Anyway to find out for sure??? If it is able to then I would have a couple suggestions to put on the list of things to change.
Old Jan 31, 2011, 11:02 AM
Hitec service
San Diego
Joined Nov 2004
No word yet when it'll be here.
Old Feb 08, 2011, 01:59 PM
Dallas, TX
Joined Jan 2005
Is the X4 made by Junsi?
jh2rc97 is offline Find More Posts by jh2rc97
Old Feb 10, 2011, 12:32 PM
Joined Apr 2009
Hello, what is the Waranty with the x4? I looked at it on tower hobbies web site, but it did not mention any Waranty. Thanks, Robert
fasteststang is offline Find More Posts by fasteststang
Old Feb 11, 2011, 09:00 PM
massachusetts, usa
Joined Dec 2010
hi, im re-posting this here. pardon me if this is not appropriate, but i didnt get any responses for the original post and id really like some feedback on this. this is the first charger of this type ive used. (im sure its user ignorance and not defective product ;-)
hitec x4
operation:
menu/user set:
this has max amps shutoff setting and timer safety shutoff setting.
Q: when charging nimh packs (my example), should you set this to the packs rating? if so, this would mean you need to set the max mah's manually every time you change packs, even tho you have programed a preset for that pack. so to charge a diff. pack/mah rating, you would change "user set/max amps, then load preset and start charge/dischg or cycle.
Q: can you define the "auto" and "manual" charge mode with respect to peak detection, or whatever it has to do with?
when set to the default 5000(user set prgm safety setting), i have found the charge overshoots the packs mah rating.
im using a preset (load data) memory setting to charge the nimh pack.
(i have programed the memory preset to match the packs mah ratings, volts, and using default peak detection, etc...)
ex. : charge overshot a 2000mah pack and charged to 2900mah's, i stopped it at that point by hitting "stop"
im using: Hobbico HydriMax 4C 4.8V 2000mAh NiMH Square AA Rx U
charge at .200A, dischrg to 1.1/cell at .300A, default peak det., im pretty sure i used "man" charge.
much appreciate!
bradp015 is offline Find More Posts by bradp015
Old Feb 12, 2011, 12:17 AM
massachusetts, usa
Joined Dec 2010
i do have an additional question.
on the hitec charger, li ion selection is set for 3.6V per cell.
i have a fromeco 2 cell li-ion pack rated at, and instructions say to charge at 7.4V
Q: how is a 2 cell pack (7.4V) equal to 3.6V per cell? (as set in "user settings" on the charger)
thanks!
Old Feb 12, 2011, 05:59 PM
Southaven MS
Joined Mar 2002
Any updates ????
btomlinson is offline Find More Posts by btomlinson
Old Feb 26, 2011, 12:50 PM
Albany, Oregon
Joined Feb 2006
recommended power supply for Hitec X4
The recommended eFUEL PSU30A (13.8V,30A, 400W) power supply appears to be rare as hens teeth. Is there anyone out there reading this, and who understands electronics, familiar with a different power supply that is of similar or better quality that is more readily available?
Cordially CJOregon
cjoregon is offline Find More Posts by cjoregon
Old Feb 26, 2011, 12:56 PM
Albany, Oregon
Joined Feb 2006
Hitec X4 programming questions
Made friends with the Hitec X4 multicharger using the "program flow chart", for me that flow chart was the key! NOW (next step) I need to figure out WHAT values should be put into the charger program for LiFe (A123) batteries.
Specifically I have 2 sizes of LiFe, I think the larger are 2600 mah cells and smaller are 1100 mah cells wired in series of 4 cells. The charger has the following screens that need info input.
In order these are the screens I need to fill in to program the X4 Charger:
"LiFe Charge X.XA, 3.3V(1S)" ?for the A should I charge the 2600's at 5 amp? And 2 amps for the 1100's?
"LiFe Balance X.XA, 3.3V(1S)" ?I don't know what amps to input. I don't understand this function.
"LiFe Fast Charge X.XA, 3.3V (1S)" Should I make this one 5 amp and the first one something less, perhaps 3 amp?
"LiFe Storage, X.XA, 3.3(1S)" Should this be ? same as regular charge A?
"LiFe Discharge, X.XA, 3.3(1S)" What should I put for A? 1 amp?
I really like this charger once I got over being intimidated by it <grin>.
Thanks for any help! Carl in Albany Oregon
Old Apr 22, 2011, 11:43 PM
massachusetts, usa
Joined Dec 2010
no reply please... couldnt delete
Old Apr 23, 2011, 10:30 PM
massachusetts, usa
Joined Dec 2010
i noticed the charger software was posted on the hitec site....
any idea of where to get the usb adapter cable?
or how to make one?
i have a spare usb cable , but dont know the pin assignments on the x4 connector (servo connector)
New Product Hitec X4 multi charger Chuck Batteries and Chargers 31 Oct 31, 2011 05:46 PM
Discussion Is anyone talking about the new Hitec X4? Valid8r Batteries and Chargers 18 Mar 28, 2011 08:21 AM
Discussion Help with Hitec X4 mogman Batteries and Chargers 2 Dec 25, 2010 12:43 AM
Question Hitec X4 JST question -S- Batteries and Chargers 3 Dec 03, 2010 07:39 AM
Discussion Hitec X4 Multicharge aeromaniac Australia 2 Sep 05, 2010 03:29 AM
