Old Jun 12, 2015, 07:16 PM
Decroxx is offline
Find More Posts by Decroxx
Free Sarcasm!
United States, OH, Worthington
Joined Nov 2014
Question
How to cover pink foam?
What would be the best method for covering dow pink foam? I know that this question has probably been answered many times before, but so far I see packing tape and ultrakote as my only options, and neither are very appealing. Packing tape still lets the pinkness of the foam show through and ultrakote is heavy, expensive, and easy for me to botch.
Decroxx is offline Find More Posts by Decroxx
Old Jun 12, 2015, 07:33 PM
mmattock is online now
Find More Posts by mmattock
Canada, AB, Airdrie
Joined Oct 2014
Lots of guys use document laminating film and then paint it afterwards.
Mark
mmattock is online now Find More Posts by mmattock
Old Jun 13, 2015, 06:23 AM
flypaper 2 is offline
Find More Posts by flypaper 2
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
If you want it for strength and a hard finish, fibreglass and finishing resin works well.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Jun 13, 2015, 07:52 AM
Decroxx is offline
Free Sarcasm!
Joined Nov 2014
Thanks!
Old Jun 13, 2015, 08:18 AM
springer is online now
Find More Posts by springer
treefinder
springer's Avatar
SE MI
I use wbpu and coffee filters for a poor man's glassing. Others use newspaper the same way. Once the covering is on, you can paint with anything to hide the pink. I use walmart buck a can spray paint once i have covered planes.
Both of these planes are made from Model Plane Foam, so they are white to start, but after covering i sprayed with rattlecans. The spitfire is rustoleum ultracover 2x. They had the best camo match, but it went on heavy, so i had to add weight to nose to get cg back to correct location. The mustang is walmart colorplace $1/can orange and silver. It is thinner and lighter weight. You do need to watch with all coverings and paints how much the added weight shifts cg aft and compensate. I try to set my planes up nose heavy if I plan to cover them.
springer is online now Find More Posts by springer
Old Jun 13, 2015, 08:50 AM
basicguy is offline
Find More Posts by basicguy
Ayn Rand Sez.............
basicguy's Avatar
United States, MO, La Plata
Joined Dec 2014
Mike Spring, Do you have links to those planes?
basicguy is offline Find More Posts by basicguy
Old Jun 13, 2015, 09:35 AM
Decroxx is offline
Free Sarcasm!
Joined Nov 2014
How exactly does the wbpu and coffee filter method work? I couldn't find anything on it after a quick search.
Old Jun 13, 2015, 10:37 AM
c.sitas is offline
Find More Posts by c.sitas
Joined Apr 2008
Just wet the planes surface with the water base, wet the filter good and apply. Wipe off most of the excess. It helps to pre cut also.Just let it dry. Some people have had warpage problems, myself ,I have not. Careful not to overlap too much. It just takes away from the flat look.
c.sitas is offline Find More Posts by c.sitas
Old Jun 13, 2015, 12:47 PM
treefinder
springer's Avatar
SE MI
I do it a bit differently. Using a 1" nylon artist brush, lay a coat on the area i am working (as c.sitas said). Next i lay the filter on dry and pat it down. Then i lay a second coat on the filter to wet it out. Once everything is saturated, i work out wrinkles that always form. I wear disposable gloves and work the brush and finger tips to smooth. Sometimes have to pick up and rearrange, of course. It does help to pre cut to rough shape. A second coat after the first dries adds shine and smooths out the surface. It is a bit fiddly to do, but with practice goes pretty fast. One trick to avoid warping is to do both surfaces of wings and tail empennage at one sitting. Then they cure equally.
Old Jun 13, 2015, 12:52 PM
treefinder
springer's Avatar
SE MI
Basic: aha! So i tempted you again? The spit is the OSP-S and is in the "list of onesheeters so far" on my blog. The Mustang may be there too, i forget if i finished posting pdf's of it. It is really still a work in progress, i will admit.
Old Jun 13, 2015, 05:59 PM
basicguy is offline
basicguy's Avatar
Joined Dec 2014
Yes the Edge is still a work in progress. I do like your designs.
Not as worried about finish as some, At 50' they all look the same.
Have built 2 other 3D type of planes in the last two weeks that have me intrigued. They handle really different. Running the rudder is so important.
Old Jun 13, 2015, 06:59 PM
treefinder
springer's Avatar
SE MI
Yup on the Edge, if i fly at half throttle, i can use just ailerons & elevator, but as i slow down, the rudder input is important.
Old Jun 13, 2015, 10:30 PM
Bare is online now
Find More Posts by Bare
Canada
Joined Nov 2000
Losta ways :-)
1) Silkspan applied with water diluted white glue
2) Masking paper applied with watered white glue
3) Glass cloth applied with Polycrilic water based polyurethane
4) glass cloth applied with EzeKote (best of all finishes..imo)
5) glass cloth applied with laminating epoxy.
Bare is online now Find More Posts by Bare
Old Jun 13, 2015, 10:55 PM
basicguy is offline
basicguy's Avatar
Joined Dec 2014
I tried covering a wing with silkspan and white glue. As it shrunk it created a lot of warpage. Have you had this problem Bare?. The composite won't shrink appreciably but has to be pretty thin.
Old Jun 14, 2015, 07:03 AM
treefinder
springer's Avatar
SE MI
My experience is the aliphatic resin in white glue shrinks more than the urethane resin in wbpu or polycrilic as each cures.
Help! Pink Foam and Glue IHeartPlanes Scratchbuilt EDFs 15 Jun 24, 2015 09:20 AM
Question How to smooth out Dow pink foam? Decroxx Foamies (Scratchbuilt) 8 Apr 21, 2015 08:52 PM
Question Lightest Covering over pink foam? CrazyHerb Foamies (Kits) 6 Jun 09, 2006 11:12 PM
Covering pink foam Paco1001 Foamies (Kits) 2 Mar 10, 2002 06:53 PM
Covering "pink" foam! ttnissan Foamies (Kits) 7 Sep 10, 2001 03:55 PM
