Old Jul 21, 2015, 08:32 AM
AutoRacer100 is offline
Find More Posts by AutoRacer100
Joined Jul 2015
New Member with a quick question
Hi All,
I'm new to this forum and this is my first post. I'm not 100% new to this hobby.
I have one honey bee electric heli and a T-Rex heli. Both of them have been in the storage for 9 years.
Now I want to bring them out. What are the things I need to check before I want to start them up. I know the battery needs to be replaced, right?
AutoRacer100 is offline Find More Posts by AutoRacer100
Old Jul 21, 2015, 09:30 AM
balsa or carbon is online now
Find More Posts by balsa or carbon
Hot glue held together by foam
United States, WA, Vancouver
Joined Aug 2010
This is an electric airplane forum , try asking in the electric heli forum .
http://www.rcgroups.com/aircraft-electric-helis-217/:)
balsa or carbon is online now Find More Posts by balsa or carbon
Old Jul 21, 2015, 09:37 AM
BoxCar31 is offline
Find More Posts by BoxCar31
BoxCar31's Avatar
United States, NC, Arden
Joined May 2015
Batteries for certain
Originally Posted by AutoRacer100 View Post
Hi All,
Yes, replace the batteries for certain. Check with your local hobby shop regarding your radio. If it isn't 2,4 GHz, you may not be allowed to fly at some local club fields. They should be able to provide some guidance on what is allowed and if a conversion is possible from your current unit.
BoxCar31 is offline Find More Posts by BoxCar31
Old Jul 21, 2015, 10:31 AM
Joined Jul 2015
Sorry guys..
Can the admin move my post to electric heli section? Thanks
Can I tell the ghz by looking at the radio?
Old Jul 21, 2015, 11:00 AM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Sorry guys..
The way you do that is to "report" the first post using the button, and one of the option is to move it.
In general, give the helicopter a good visual check, get a good battery, lube up the bearings(!) and fire it up with the blades removed, and check if the electronics are still alive. After 9 years in storage, it's highly likely the servos have failed. I don't know what happens to them, but they don't like to sit around and not be used.
Please post detailed photos if you're not confident in your own assessment. Yes, if you post a photo or brand name and model number, we can tell you exactly what radio you have.
jasmine2501 is offline Find More Posts by jasmine2501
Old Jul 21, 2015, 12:27 PM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Yeah, the battery will be scrap. If it's been stored in a heated dry place then the rest of the heli should be fine. I've had stuff stored for a lot longer which has always worked ok.
If it's been in somewhere cold and damp then likely the electronics will be damaged by corrosion.
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Jul 21, 2015, 02:21 PM
dteel is offline
Find More Posts by dteel
I failed to crash a heli once!
dteel's Avatar
United States, CA, El Cajon
Joined Mar 2014
I haven't much to add to the advice already provided. I wish you success in getting that bird back in the air where it belongs.
Happy flying!
dteel is offline Find More Posts by dteel
Old Jul 21, 2015, 03:13 PM
BoxCar31 is offline
BoxCar31's Avatar
Joined May 2015
Long antenna
Sorry guys..
If the antenna is more than a foot long, it's not a 2.4.
Old Jul 21, 2015, 03:54 PM
dteel is offline
dteel's Avatar
Joined Mar 2014
I'm sure it's posted somewhere on the transmitter. Even the ancient Tx my father gave me (over 35 years old) was prominently marked 72MHz!
Old Jul 21, 2015, 04:08 PM
Rocket Programmer
Joined Jul 2007
It is by law actually...
https://www.fcc.gov/encyclopedia/rad...-radio-service
An R/C station must be certified by the FCC. A certified R/C device has an identifying label placed on it by the manufacturer.
Old Jul 21, 2015, 06:16 PM
BoxCar31 is offline
BoxCar31's Avatar
Joined May 2015
Type Acceptance
A type acceptance label means the device is certified to operate within specific parameters across its designed frequency range. The label does not indicate what frequency range, only that it does not radiate more than specific amounts of energy outside of the ranges authorized. Which, when boiled down, doesn't say anything about what frequencies only how well the unit was designed for its specific purpose. Most transmitters don't mention their frequency range anywhere on the device, just in the material sent with it.
Old Jul 21, 2015, 06:30 PM
Rocket Programmer
Joined Jul 2007
Hmm, maybe you're right... unfortunately I can't check the back of this one right now... but I could swear they were labeled not only with the band, but with the channel as well...
Old Jul 22, 2015, 08:34 AM
BoxCar31 is offline
BoxCar31's Avatar
Joined May 2015
Don't mix fruit here
The FCC type acceptance label is only required to show the registration number. Any added data such as frequency range and channels is not required but included at the manufacturer's option.
Old Jul 22, 2015, 08:09 PM
Rocket Programmer
Joined Jul 2007
OK that's cool, but I swear all my 72MHz radios have a label with the frequency on it. A few of them have the crystal in the front with the channel marked on that. Can't hurt to look.
Old Jul 23, 2015, 06:36 AM
Brutus1967 is offline
Find More Posts by Brutus1967
I convince things to work
The Netherlands
Joined Nov 2009
the presence of a crystal also indicates it is not 2.4 GHz....
But to my knowledge, at least the frequency band should be indicated on the device, at least on the HF module if the transmitter has a separate module.
At least, all my transmitters did....
Brgds, Bert
Brutus1967 is offline Find More Posts by Brutus1967
Discussion New to 6S RC Quick question LoadingError Batteries and Chargers 3 Jul 02, 2015 10:41 AM
Discussion new to quadcopters, quick fpv question! snirunner24 Multirotor Talk 3 Jun 22, 2015 12:05 PM
Question New Member - Introduction and Spirit 2m Question twall3 Sailplane Talk 19 Jun 18, 2015 01:02 PM
Discussion New member with a noob question JumperPastlife Sailplane Talk 7 May 16, 2015 10:45 AM
Discussion New member with a quick question 2.8-350TBI Power Systems 1 Apr 10, 2010 04:38 AM
