View Poll Results: can it be done, scale transition with this design 3BSM?
yes 4 100.00%
no 0 0%
Voters: 4. You may not vote on this poll
Old Jan 12, 2016, 01:37 AM
DB7 is offline
DB7
Find More Posts by DB7
DB7
Joined Jan 2015
Great work Joel!!! Really coming along there :-)
DB7 is offline Find More Posts by DB7
Old Jan 12, 2016, 04:25 AM
Joel_Vlashof is offline
Find More Posts by Joel_Vlashof
Joined Nov 2012
Originally Posted by DB7 View Post
The CAD drawing is available over on Turbosquid, http://www.turbosquid.com/3d-models/...c-model/876966
Really great price too!!
It saves a LOT of work
Jungs (the CAD Designer) did a great job but there are some areas that need some work for true scale as Joel said in an earlier post.
Indeed cool model but it needs Some extra scale work..i used this as an basic model and upgraded it, I designed for example the battery bays and doors..the upper liftfan door..ect
Joel_Vlashof is offline Find More Posts by Joel_Vlashof
Old Mar 12, 2016, 02:57 AM
Joined Nov 2012
2016
I have Some time to work on this project again with help of a friend. The design is done for a 120mm setup. There are Some inprovements. The edf120 is lightweight and gives me 6kg+ thrust instead of 2,8kg thrust. But ok i need 10s instead of 6. But the f35B is bigger and wil be made fully out of Carbon to be continued!!
Old Mar 15, 2016, 04:30 PM
Brandano is offline
Find More Posts by Brandano
That's some impressive craftsmanship in that carbon duct and fairing.
Brandano is offline Find More Posts by Brandano
Old Mar 15, 2016, 04:56 PM
v22chap is offline
Find More Posts by v22chap
v22chap's Avatar
United States, IN, Granger
Joined Jan 2003
Joel
Will the 120 take 12 S ... then just use two of your 6 S packs .... should get more power with 12S
v22chap is offline Find More Posts by v22chap
Old Mar 16, 2016, 05:32 AM
Brandano is offline
Hmm, and there might be space for a split pack behind the intakes, where the real one has the missile launcher bay doors.
Old Mar 17, 2016, 06:16 AM
louisjunior is offline
Find More Posts by louisjunior
United States, VA, Virginia Beach
Joined Apr 2013
What's the weight of that 120mm? I'm battling with 2 here weighing over 1kg and putting out 7 and 8kg at 12S.
louisjunior is offline Find More Posts by louisjunior
Old Mar 18, 2016, 05:32 AM
Joined Nov 2012
I let you know this weekend
Old Mar 19, 2016, 02:52 PM
Joined Nov 2012
702 grams
Also bought a new printer
Old Mar 23, 2016, 11:19 PM
Joined Apr 2013
702g putting out 6+ that's pretty good.
Old Apr 12, 2016, 11:12 AM
Joined Nov 2012
Update
Still working on my new house but i have Some time to work on a 120 version..i tested it..Omg never seen that power!! Cait wait to hover it. Ps i got a new record from the roll nozzles. I reached 170grams each Side from a 90mm...now from the 120mm i have +550grams each side..and more then 3,8kg from the bsd on 8S. Next test will be on 10S. To be continued
Old Apr 14, 2016, 07:47 AM
Joined Nov 2012
Originally Posted by Brandano View Post
You could try and see if a thrust augmenter will work. You are picking up the airflow right behind the impeller, maybe there's some pressure that can be traded for air volume.
[edit] This is what I mean:
hmmm good point on this brandano i didn't understand then but now i see the benefits of this...good job
Old Apr 21, 2016, 03:44 PM
Joined Nov 2012
Update
Working on the test frame for the 120mm setup. I use the schubeler 120 and 90mm high voltage setup. Total flying weight will be around 4kg but Total thrust is theoretic 125Newton...i really hope to have more flying time and thrust to do transition after almost 4 years of work on this project the flight controller is same as always, the kk 2.1 for hover and pixhawk for stabelize and normal flying.
Old Apr 21, 2016, 04:06 PM
Mtn_Commando is offline
Find More Posts by Mtn_Commando
Mtn_Commando's Avatar
United States, CA, Dublin
Joined Sep 2008
That looks facking hot! Great work!
Mtn_Commando is offline Find More Posts by Mtn_Commando
Old Apr 21, 2016, 09:26 PM
Joined Apr 2013
Looks great man. Wish I had time to work on my project.
