Old Jan 06, 2016, 07:41 AM
AntDX316 is offline
Find More Posts by AntDX316
AntDX316's Avatar
Joined Sep 2014
Originally Posted by TomC View Post
I never needed to add any reinforcing to my fx-61 wings so I'm not sure what you mean by all this.
What kind of flying wing are you flying?
FX-61, lol
I use the FX-61. Make sure you get digital metal gear servos. My plastic ones started to strip and I didn't know until I was having flight computer failure from a bad USB. I have the Fy-605 and it sends a bad signal to the device or some other problem.
Everytime it blinks it makes the servos move. I can't wait to test out the pathing feature. I have to wait for a new FPV camera as the FPV camera I use seems to make the OSD not work. I tried the other camera on the Fy-DOS M Fy-Hornet OSD on the hexa and it works.
When it crashed because prob servos.. the camera I had on it broke.
AntDX316 is offline Find More Posts by AntDX316
Old Jan 06, 2016, 08:34 AM
TomC is online now
Find More Posts by TomC
Gold Coast Coolangata, Australia
Joined Nov 2003
Ya good quality metal geared servos are best. Good Analogs are ok because the 41ap only drives servos at~50hz anyway. Sometimes digital servos can cause interference problems.
TomC is online now Find More Posts by TomC
Old Jan 08, 2016, 04:53 PM
Guyzza is offline
Find More Posts by Guyzza
Australia, NSW, Lavington
Joined Jan 2015
Originally Posted by BigTradioman View Post
Good luck with this. I had to try 4 different machines before I found one to work the program. I saw something about this earlier. Try running the machine in safe mode and then try. Also disable your anti virus
I had the same problem and I finally managed to get this to work on my laptop with windows 10. I had to select compatibility mode and use XP service pack 3.
To do this right click on the file and select compatibility.
Guyzza is offline Find More Posts by Guyzza
Old Feb 03, 2016, 12:53 PM
MrPnut is offline
Find More Posts by MrPnut
United States, CA, Alameda
Joined May 2012
I've got my FY41-AP working, mostly. In 3D, ABM and RC mode it works exactly as expected. When I flip it into RTH mode, it completely cuts the throttle and rolls hard to the left putting the plane into a dive. I have to switch out of RTH to recover. I have tried with and without the airspeed sensor connected.
What am I missing?
MrPnut is offline Find More Posts by MrPnut
Old Feb 03, 2016, 01:08 PM
raptor357 is offline
Find More Posts by raptor357
United States, MI
Joined Jan 2013
reverse throttle in OSD, try again also might be reverse on ailerons
raptor357 is offline Find More Posts by raptor357
Old Feb 13, 2016, 07:51 PM
Q8Tsy is online now
Find More Posts by Q8Tsy
Joined Oct 2015
hello
guys i want ask you how is the max currnt of Power management module can read on fy-41 ap lite ?
bucoe on full thurottle %100 its read 37 amp
i change the motor with biger wat and also read same 37 amp maax !!
its thes normly or my mote pull more amp and the sensor cant read it
thank you
Q8Tsy is online now Find More Posts by Q8Tsy
Old Feb 13, 2016, 10:35 PM
United States, MI
Joined Jan 2013
do you have a watt meter to check it against? I think the new ones are 30 or 40 amp max reading
Old Feb 13, 2016, 10:49 PM
TomC is online now
Joined Nov 2003
Originally Posted by Q8Tsy View Post
hello
thank you
My 41ap lite is only rated at 25 amps max. I think that FY was selling 50 amp upgrades but I'm not sure if they still are or not.
I just use my lite on fairly low draw e-gliders (~15 amp max) and flying wings (~25amp max).
Old Feb 17, 2016, 06:42 PM
Q8Tsy is online now
Joined Oct 2015
ok how about the line and path mode on Lite
can you tell me how the modes work ?
WHAT MEAN PATH + LINE MODE AND WHAT (i use for)
if you have some video for thes modes pleas add on here
Old Feb 17, 2016, 06:53 PM
United States, MI
Joined Jan 2013
Line is for heading and altitude lock, lite version does not have path. RC, RTL, Line, 3D, ABM. you can substitute line for circle if you want.
Old Apr 06, 2016, 06:01 AM
jabu32 is online now
Find More Posts by jabu32
Who put that tree there?!?!
jabu32's Avatar
Indianapolis, IN
Joined Jan 2011
Does this flight controller record flight logs for playback/analysis later?
jabu32 is online now Find More Posts by jabu32
Old Apr 06, 2016, 06:21 AM
TomC is online now
Joined Nov 2003
The flight controller itself does not record flight logs but you can use a dvr to record your fpv flight and this will then include all the OSD info.
Old May 02, 2016, 10:52 AM
mrorange26 is offline
Find More Posts by mrorange26
Joined Nov 2015
On the Feiyu Tech FY-41AP Lite.Do you have to have the airspeed sensor for RTL to work.
mrorange26 is offline Find More Posts by mrorange26
Old May 02, 2016, 02:01 PM
TomC is online now
Joined Nov 2003
RTH and ACM Nav modes work fine without the airspeed sensor. Target airspeed is then the GPS ground speed. You need to take this into consideration if you fly in very windy conditions.
Old May 02, 2016, 04:00 PM
Joined Nov 2015
Ok thanks for info.
New Product Fy-41AP OSD & autopilot system is coming RC4YFPV FPV Equipment 319 Apr 06, 2016 06:02 AM
Question Is fy-31ap and the Hornet OSD compatible with fy-90qpro? mgs0098 FPV Equipment 1 Sep 23, 2013 03:15 AM
Question Is fy-31ap and the Hornet OSD compatible with fy-90qpro? mgs0098 Power Systems 1 Jan 11, 2013 03:47 PM
Idea FY-21AP/FY-31AP and OSD FY Extender hefest FPV Talk 6 Nov 05, 2012 04:45 PM
New Product FY thread: FY20A/FY21AP/FY3ZT/FY31AP/FY90Q/FY91Q/FY-Frame/FY-GCS/FY-OSD/FY-Dataradio yiny0730 FPV Talk 316 Sep 19, 2011 01:30 PM
