Old May 16, 2015, 05:26 PM
manuel v is online now
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
I have a test on a FMS F4 with a 70mm EDF 8blade.
My battery only gave 13.59V, somewhat low for 4slipo.
Motor FMS 2845-3000, 69A, 938W, 4s2440, 35c.
manuel v is online now Find More Posts by manuel v
Old May 18, 2015, 12:08 AM
capt soap is online now
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Ive got a 8 blade in my habu2. 4 flights so far. Sounds good in the air.
capt soap is online now Find More Posts by capt soap
Old May 18, 2015, 04:45 AM
bps is offline
bps
Find More Posts by bps
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
I am using two FMS 8B fans in my ME262. Amp draw settles in at 52 amps each using two 3.3 4s 50c pacs. It took me a while to get these balanced but they are sweet fans with a decent sound. Not as whooshie as 12 or 14b but a lot better than the 5b fans.
bps is offline Find More Posts by bps
Old May 18, 2015, 01:23 PM
manuel v's Avatar
Joined Aug 2004
My reading 3slipo is very consistent with the 4s.
I'm really surprised, this fan 8b, motor load almost like on 12b fan
Inside plane.
4s2450, 35C, 69A, 13.59v, 938 watts.
3slipo. 45.13A, 10.41 volts, 470 watts.
Old May 18, 2015, 01:35 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Are they giving the same thrust to watts as the 10 - 14 blades fans?
tia
erh7771 is offline Find More Posts by erh7771
Old May 18, 2015, 02:16 PM
manuel v's Avatar
Joined Aug 2004
erh7771.
I have not tried, but I hope that is within the standards. Input 1000W, for 1450 to 1650 grams of thrust.
Old Yesterday, 03:45 AM
christian0007 is offline
Find More Posts by christian0007
Germany, HE, Frankfurt
Joined Nov 2013
Does someone have a idea for a 4s setup and ca. 2kg thrust and ca. 1200watt? which motor should i choose?
regards
Chris
christian0007 is offline Find More Posts by christian0007
Old Yesterday, 04:39 AM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
I am not sure if it's possible, with realistic current (amps), to achieve 2Kg.
I got near 1.9Kg with a Cyclone Power 3300kv outrunner at 98amps.
The HET 1W-40 is another option.
Your best bet however is to go 5/6s.
anlucas is offline Find More Posts by anlucas
Old Yesterday, 05:16 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
1W40 will do it, I tested it on 4s, when I get onto the regular PC will look up the figures, it was around 96 amps or so from memory.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Yesterday, 02:04 PM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
I got 6lbs+ @ 220 mph on a 65c 5s CS12 1W40 on my Ergo! Got it into the 180's
ApexAero is offline Find More Posts by ApexAero
Latest blog entry: no comment
Discussion Change Sun 10 blade 70mm (Test Results Consolidated) 901racer Electric Ducted Fan Jet Talk 193 Feb 24, 2015 12:34 PM
Discussion Change Sun 70mm 10 blade EDF SpaceAviation Electric Plane Talk 8 Jan 22, 2013 04:06 AM
For Sale NEW! EXTREME CNC ALLOY Change Sun 10 BLADE 70mm FAN rlc2052 Aircraft - Electric - Jets (FS/W) 1 Nov 01, 2012 02:24 PM
Sold Change Sun 70mm 10 Blade EDF TreeFlyer Aircraft - Electric - Jets (FS/W) 5 Mar 01, 2012 03:50 PM
Sold New Change Sun 70mm 10 blade fan. TreeFlyer Aircraft - Electric - Jets (FS/W) 4 Feb 29, 2012 05:59 PM
