Old Feb 10, 2015, 05:21 AM
United Kingdom, London
Joined Feb 2012
LemonRX/Orange Satellite as receiver for Naze32/AfroNaze?
Been using one of these with an AlienWii FC for a couple of days and it occurred to me to be one of the cheapest/lightest RXs I've ever used. De-cased, it weighs next to nothing, and I am assuming it outputs PPM?
I have an AfroMini already, the only rub is that it needs PPM, and my current PPM RX is several times the weight/size as the controller!
Does anyone have any experience with these as a main receiver for a Naze32 based setup?
DebianDave is online now Find More Posts by DebianDave
Old Feb 11, 2015, 07:30 PM
soccerj4y's Avatar
United States, VA, Chesapeake
Joined Aug 2013
I've got one with my flip32 but I cant get it to work, once i figure out what's wrong with the signal I'l get a more definitive answer.
soccerj4y is offline Find More Posts by soccerj4y
Old Feb 11, 2015, 08:05 PM
Sunnyvale, CA, USA
Joined Apr 2000
The fact that it does not put out ppm may be your issue.
teamdavey is offline Find More Posts by teamdavey
Old Feb 11, 2015, 08:34 PM
soccerj4y's Avatar
Joined Aug 2013
Really? So on the naze how do you set it up? Disable ppm? That might explain it, mine also goes into bind mode every time I power it on even if I disable bind in the software
Old Feb 12, 2015, 12:23 AM
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
It works like a Spektrum satellite receiver, using Spektrum serial protocol. Presumably that's what the Alien is set up to use. Quite different from PPM.
Daedalus66 is online now Find More Posts by Daedalus66
Old Mar 04, 2015, 09:29 PM
aka Fast Forward
paladindg's Avatar
United States, KY, Versailles
Joined Feb 2005
I could use some help setting up one of these Lemon satellite Rx on my Naze32 FC. I bought the Lemon Starter kit from FreeBirdRC.com. I am able to get the Rx to bind and it functions no problem using a spare servo, but when I connect to the Naze FC, I get nothing, not even a blinking LED.
I have soldered the three wires for the Rx to the GND and #4 pad, then pulling power from the 3V pad next to the FC LEDs. I must be doing something wrong, but can figure it out.
In Cleanflight on the "Ports" tab, I have UART2 set to Searial RX
On the "Configuration" tab, receiver mode is set to RX_Serial and the Serial Receiver Provider is set to "SPEKTRUM1024"
On the "Receiver" tab I have the channel map set to "TAER1234"
I found this info at - http://www.helifreak.com/showthread.php?t=683925
paladindg is offline Find More Posts by paladindg
Old Mar 04, 2015, 10:06 PM
Sunnyvale, CA, USA
Joined Apr 2000
No experience with the NAZE but my suspicion is that the Lemon DSMX sat is 2048 not 1024 - if that is what you have.
Also you say 3 volts - did you mean 3.3 for the sat?
Old Mar 04, 2015, 10:35 PM
aka Fast Forward
paladindg's Avatar
Joined Feb 2005
I have tried 2048 and 1024, but no response from the rx
There is a 3v pad on the Naze32 board, but I believe you are right, it is 3.3v
Sold NEW Spektrum AR8000 8 Ch. DSMX Receivers (no satellite) As low as $40 each! HobbyOverstock Aircraft - General - Radio Equipment (FS/W) 9 Oct 20, 2014 05:50 PM
For Sale NEW Spektrum AR8000 8 Ch. DSMX Receivers (no satellite) As low as $40 each! HobbyOverstock Aircraft - General - Radio Equipment (FS/W) 3 Aug 21, 2014 12:26 PM
Sold NEW Spektrum AR8000 8 Ch. DSMX Receivers (no satellite) As low as $40 each! HobbyOverstock Aircraft - General - Radio Equipment (FS/W) 1 Aug 12, 2014 06:39 PM
Sold New LemonRX 10-CH DSM2 Receiver w Satellite RX bobbysbrother Aircraft - General - Radio Equipment (FS/W) 4 Jun 07, 2014 12:28 PM
Sold DX6i never used as good as new. Also Orange Rx + Satellite Jacopo Aircraft - General - Radio Equipment (FS/W) 16 Oct 06, 2012 01:06 PM
