Old Jan 05, 2015, 09:11 AM
United States, OH, Racine
Joined Oct 2014
Starting DLE 30
I have 2 DLE 30's that run great. My only problem is that if they have set a while, say a week or two, they are hard to start. I end up having to use a starter the first time. After that they will start the first or second flip. My question is when you choke the cold engine, where do you set your throttle. I always set mine at idle. I'm thinking that is my problem.
Gtarman52 is offline Find More Posts by Gtarman52
Old Jan 05, 2015, 09:46 AM
United States, FL, Citrus Springs
Joined Aug 2008
Just off the idle here. I start them the same way (just off the idle).
Choke plate centered in carb bore, allowing it to close completely? The screw that secures them has been kown to loosen. Have you considered soldering the hole in the choke plate for better fuel draw?
ahicks is offline Find More Posts by ahicks
Discussion New DLE 30, no start Mikes145 Engines 13 Jul 29, 2014 03:23 AM
Discussion DLE 30 starting issue bill34207 Engines 21 Oct 07, 2013 05:32 PM
Found WTB DLE-30 or DLE-35RA sdstick Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 04, 2013 10:54 PM
Discussion Flip Starting DLE 30 ognolman Engines 77 May 26, 2013 10:43 AM
Question DLE 30 what for this fuel Tank for on DLE 30 Johnsmith122 Engines 5 Jan 09, 2013 03:18 PM
