Old Dec 02, 2014, 10:16 AM
Joined Aug 2014
Use FS-T6 with Simulator
Hello, I have a FlySky FS-T6 transmitter and I was hoping I could hook it up to my pc using this cable http://hobbyking.com/hobbyking/store...USB_Cable.html
Is this possible? In my research it seems it is but I've been having trouble. Some sources leave me under the impression that using ppjoy I can make it work? However I am having trouble installing PPJoy. It tells me it needs PPJoyBus.sys installed.
Any ideas how I can make it work?
Thanks!
musiman93 is offline Find More Posts by musiman93
Old Dec 02, 2014, 01:26 PM
Bit-Twiddler and Flyer
USA, VA, Chantilly
Joined Apr 2002
With the USB sim cable for the transmitter, you do not need PPJoy. Setup a model name on your transmitter for the sim that is for an airplane. It will work with airplanes, quads and helis.
Windows should recognize the USB device when you plug in. If not, you may need to download and install a driver for the USB cable.
Once the cable is recognized by Windows, calibrate the "joystick" in Windows before using it in a simulator.
ggunners is offline Find More Posts by ggunners
Old Dec 02, 2014, 01:58 PM
Joined Aug 2014
thanks for your response. I don't believe that this is actually a simulator cable. it's actually a programming cable for the t6 but I was under the impression that maybe I could use it?
Old Dec 02, 2014, 03:42 PM
USA, VA, Chantilly
Joined Apr 2002
Try this cable:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Discussion Micro Receiver compatible with Flysky FS-T6 gummyworms Radios 3 Nov 23, 2014 11:09 PM
Help! Problem with FS-T6 and FS-R6B Lucas Golino Radios 0 Nov 14, 2014 09:04 PM
Discussion FLY-SKY FS-T6 unable to get left aileron to operate using FS R6B REC. plane crasher2 Radios 2 Nov 11, 2014 03:14 PM
Help! Need Help with KK2 Self Level Aux Switch With Flysky FS-T6 ecpilot Multirotor Electronics 6 May 31, 2014 10:28 PM
Discussion RC Helicopter with FlySky FS-T6 hgedikli Electric Heli Talk 1 Dec 29, 2013 03:49 AM
