Old Aug 21, 2014, 10:24 AM
NashVegas is online now
Find More Posts by NashVegas
Jus 1 more plane is all I need
NashVegas's Avatar
United States, TN, Nashville
Joined Mar 2013
Skyline Yak 55m 60"
Decided to start this thread for two reasons:
1) I've never started a thread
2) I couldn't find any information on a 60" Skyline Yak on RC Groups
I purchased this Yak from General Hobby just for the heck of it as an economical plane to throw in my truck for the occasional flight during my lunch hour. I figured at $158 bucks for the airframe, why not.
Here are some pics of the unboxing, and the build log will follow.
The airframe was packaged nicely, and everything arrived within 5 days undamaged. Hardware looks good and it includes a carbon fiber wing tube.
Stay tuned for more.
NashVegas is online now Find More Posts by NashVegas
Old Aug 21, 2014, 10:56 AM
strat10 is offline
Find More Posts by strat10
strat10's Avatar
United States, CA, Huntington Beach
Joined Jan 2013
Looking forward to the progress. Thinking about getting one of these myself.
What motor/servo's are you going to use?
strat10 is offline Find More Posts by strat10
Old Aug 21, 2014, 12:04 PM
NashVegas's Avatar
Joined Mar 2013
I'm on a budget for this plane having just completed a very expensive Extreme Flight 91" Yak. No regrets there, it's awesome.
Even though I'm on a budget, I will be using proven brands at a discount.
Motor will be a Tacon Bigfoot 46 (670kv) and I will be running it on 6s LiPo
Servos will be similar specifications as the Hitec 5245MG
I have an 80amp ESC laying around somewhere, so I will repurpose that
Old Aug 21, 2014, 01:06 PM
Eddge is offline
Find More Posts by Eddge
Hey y'all!!! Watch this!!!
Eddge's Avatar
United States, VA, Gloucester
Joined Jul 2007
Might want to check that motor on 6s. Usually, 6s setups run a lot lower kv, as in 500. You can do it, but not with a 15" prop.
Eddge is offline Find More Posts by Eddge
Old Aug 21, 2014, 01:38 PM
NashVegas's Avatar
Joined Mar 2013
Good point. I will look into that as I would like to use a 16x7 or 15x8
Old Aug 21, 2014, 11:23 PM
Chuck is online now
Find More Posts by Chuck
Balsa to the Wall
Deep in the East Texas Piney Woods
Joined Dec 2001
If you're running a 15x8 on 6S, I recommend a 400 - 440kv motor.
Chuck
Chuck is online now Find More Posts by Chuck
Old Aug 22, 2014, 05:41 AM
NashVegas's Avatar
Joined Mar 2013
Motor Update
Okay, I went ahead and ordered tha Tacon Bigfoot 60 (400kv). This is a 1200 watt motor with similar specs and size to the Hacker A50 14XS that I run in my 64" Extreme Flight MXS. The difference is the Bigfoot costs about a $100 dollars less
Anyways this will be a fun experiment. Hope to post some build pics this weekend. Thanks again for the input guys!
Richard
Old Aug 23, 2014, 11:21 AM
RKevinEstes is online now
Find More Posts by RKevinEstes
RKevinEstes's Avatar
Joined Jan 2013
Clean your build table!!!
Looking forward to this build!
RKevinEstes is online now Find More Posts by RKevinEstes
Old Aug 23, 2014, 11:56 AM
NashVegas's Avatar
Joined Mar 2013
You weren't supposed to see this thread! I know, I know....."friends don't let friends buy cheap planes"!!!
I promise not to fly this one in front of you
Old Aug 23, 2014, 07:01 PM
Joined Jan 2013
No shame! J/K. I can't wait to try to fly the wings off of it! Literally!
Old Aug 23, 2014, 10:04 PM
NashVegas's Avatar
Joined Mar 2013
The kit provides 5 Mylar hinges per aileron. My other 60" plane had 4 each.
I also like the fact that each hinge has two holes exactly at the mid way point. This allows for perfect alignment of each hinge, and additional flexibility.
Old Aug 23, 2014, 10:41 PM
NashVegas's Avatar
Joined Mar 2013
Landing gear
The kit did not provide a typical stainless wheel axle. It provides a black shoulder bolt with two nylock nuts. I had to add a washer to hold the wheel pants up against the gear leg.
The landing gear looks to be a blend between aluminum and carbon fiber. It is cool to the touch like aluminum, but has a grain to it similar to carbon fiber. Either way it is light and strong.
I do like the balsa box used to cover the landing gear mounting plate. Makes a clean installation.
Old Aug 27, 2014, 08:33 PM
NashVegas's Avatar
Joined Mar 2013
I've hit a couple of speed bumps:
1) the servo openings in each wing are HUGE! I purchased Solar brand servos which are the exact same size (and similar specs) as the HiTec 5245's that I run on my Extreme Flight 64" MXS. They literally fall into the holes on these wings. I will have to modify the opening (shrink it) or order Standard size servos which I believe are overkill for this size plane. Opinions welcomed.
2) the plane comes with split elevators. Again a choice. I can either install two individual servos for each half, or use the provided wooden joiner bar per the instructions and use one servo.
Old Aug 28, 2014, 08:07 PM
Joined Jan 2013
Should have waited for the EF 60" Yak! J/K . Just glue in some light ply pieces on each end of the holes and use the joiner on the elevator. Can't see using two elevator servos on a 60"er.
Contest NEW!!! OMP Yak 55M 60" Electric Sukhoikid 3D Flying 5 Aug 21, 2014 03:15 PM
For Sale Skyline Yak 55M 70 60'' Aerobatic RC Airplane ARF richyan Aircraft - Electric - Airplanes (FS/W) 0 Aug 04, 2014 05:20 AM
For Sale Bill hempel yak 55m palmsp9 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 21, 2013 03:16 PM
For Sale Bill Hempel Yak-55M 50CC palmsp9 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 18, 2013 02:19 PM
