Old May 22, 2015, 09:34 PM
Nucc10 is offline
Find More Posts by Nucc10
United States, FL, Orlando
Joined Jan 2013
MYFLYDREAM IN THE MYTWINDREAM. GREAT COMBO. AUTOLAUNCH mode in slo mo.
Mytwindream launch slo mo (0 min 22 sec)
Nucc10 is offline Find More Posts by Nucc10
Old Today, 12:22 AM
Eastcoast78 is online now
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Originally Posted by schumixmd View Post
Answer: to solve your "problem" you have to increase PLANE SETTINGS -> ROLL TRIM and PITCH TRIM. Increase it by one unit at a time.
Is it normal for the increment to be in 5 points and stop at 10? I re calibrated everything flat on the floor. Went into plane settings and noticed it pitch was at 2. (the wing sits flat on the floor with a nose up attitude). So i moved to adjust it up a bit and it went to 7, then when i pushed it again it went to 10 and that was it. Is that normal? Im sure i played with this before and it moved in 1 increments.
Eastcoast78 is online now Find More Posts by Eastcoast78
Old Today, 02:30 AM
reedevil is offline
Find More Posts by reedevil
Russia, Saint Petersburg, SPB
Joined May 2013
Your CH5 was probably switch in mid or high position during setting.
Moving CH5 in menus to MID or HIGH position increase increment value. For example in CH5 LOW it will add only 1 point per move, in MID it will add 5 points, in HIGH it will add 10 points per move.
It useful for big range values like circle radius, cruise speed etc.
7 or 10 is to high for trim.
reedevil is offline Find More Posts by reedevil
Old Today, 09:49 AM
schumixmd is offline
Find More Posts by schumixmd
schumixmd's Avatar
Moldova
Joined Jun 2010
That's very true, the only correction is: it is CH6 that changes the increment value, not CH5.
schumixmd is offline Find More Posts by schumixmd
Old Today, 10:10 AM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
Ok awesome. Missed this info in the manual.
Old Today, 03:08 PM
reedevil is offline
Joined May 2013
Got a very windy flight on my Sky Cruise with MFD. Wind was 5-8 m/s with gust to 12-14.
It was sweaty flight, ALT mode could not handle the wind with ascending, sometimes droping ground speed to 1-5 km/h and starting to tacking ( got 70% of throttle allowed for AP). So i went to STB mode, so i can control throttle. With proper power it flew much more easier, stabilisation worked realy well even on hard wind gusts.
And im pretty sure i would not land it so easy without STB mode. Wind near the ground was unpredictible.
Windy Sky Cruise 2400 (2 min 54 sec)
I'm satisfied with how AP handled this realy unconfortable flight conditions. At least now i know, it will handle it if the weather will change drastically during flight, wich on this plane could be more then 2 hour.
Build Log Build your own autopilot/flight controller for a quadcopter drgowen Scratchbuilt Multirotors 8 Apr 13, 2015 06:36 PM
Discussion MyFlyDream Autopilot: AWESOME! brifa FPV Equipment 33 Sep 07, 2014 04:16 AM
Discussion Multicopter autopilot controlling a Single Rotor Heli? Dimitris76 UAV - Unmanned Aerial Vehicles 2 Jul 22, 2013 07:39 PM
For Sale DJI WK-M Wookong Flight Control System with GPS Autopilot - $825 obo WildLookout Aircraft - Electric - Multirotor (FS/W) 0 Jun 18, 2013 04:03 PM
Controlling General Aviation Autopilot Servos with an UAV autopilot board? rdf0011 Radios 3 Jun 15, 2005 05:58 PM
