Old Aug 18, 2014, 07:25 PM
Joined Apr 2014
First off, awesome instructions, thanks.
I've attempted a REALLY cheap helical ($4 in parts) and gotten rather poor results. Was wondering how large the error margin allowances might be.
1280mhz
Vee antenna on 400mw Tx
4awg cu
All measured as close to your measurements as I could although it doesn't look pretty...
Unfortunately I don't have any wave testing equipment but I'm getting a similar ~1000ft range from the stock whips, Vee + whip, Vee + helical. Tests are done the same way and all on the ground.
I haven't gotten my T-connector yet and using 2.4ghz control; no notch filter; so no air tests yet. How much farther would air tests be?
Any and ALL help/advice/guidance is HUGELY appreciated. Thank you!
eatkabab is offline Find More Posts by eatkabab
Old Yesterday, 05:47 AM
Another one bites the Dust
United States, GA, Savannah
Joined Mar 2013
1280mhz
4awg cu
What's the spaceing between the reflector and the element? Looks kinda large.
shadowolfs is online now Find More Posts by shadowolfs
Old Yesterday, 10:39 AM
Joined Apr 2014
The very end of it is almost exactly 1cm or a bit under a 1/2 in. Don't remember reading what it's supposed to be or measuring it....
Old Yesterday, 11:22 AM
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
This is surely a big problem. For the frequency you are aiming to, it should be 2.2mm above the reflector. See this online calculator. Try to stick to these measures and your result should be quite ok.
http://jcoppens.com/ant/helix/calc.en.php
HTH
Markus
markus123456 is offline Find More Posts by markus123456
Discussion Circular-polarized Patch Antenna for 5,8 GHz Lonestar78 FPV Talk 22 Oct 15, 2011 04:46 PM
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 44 Jun 04, 2011 06:41 PM
For Sale 2.4 gh 8 dbi patch antenna $10 norberto83 FPV Equipment (FS/W) 1 Dec 03, 2010 07:44 PM
Question 30 dBi Grid Antenna matyou FPV Talk 7 Nov 14, 2010 10:32 PM
Discussion Anyone tried building a helical antenna for FPV? Bill Sanford FPV Talk 20 Nov 04, 2010 06:48 PM
