Old Apr 29, 2015, 04:54 PM
EJWash1 is offline
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Throttle Servo Moves w/Rudder Input?
Hi All,
I have a Futaba FG12 (set-up Mode 2). When I move the rudder, the throttle servo moves a little (plus/minus 8 points on the servo monitor screen on Tx). Rudder is Channel 2, Throttle Channel 3.
Normal? Remedies?
Thanks!
EJ
P.S.: Radio was sent to Futaba and given a clean bill of health last November. Haven't flown it since it came back.
EJWash1 is offline Find More Posts by EJWash1
Old Apr 29, 2015, 05:53 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
Is this on a clean model with ACRO model type selected? Make sure you do not have any mixes enabled.
ivanc is offline Find More Posts by ivanc
Old Apr 29, 2015, 06:21 PM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Thanks.
No, I checked the mixes, all at are "Inhibited". Under "Model Type", I have the selection of "Airplane", Helicopter", or Glider". "Airplane" is selected.
EJ
Old Apr 29, 2015, 07:20 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
You could try increasing the tension on the throttle stick.
I fly smooth throttle and I just went out to the work bench and put my 8FG in servo monitor. I was hard pressed to keep my rudder to throttle interaction that low
To test the gimbals, don't directly touch the stick with your fingers or thumb (me). Take something like a little screwdriver and use it to move the stick in the rudder axis while looking at the servo monitor, and see if you still get any coupling. With my 8FG throttle stick centered at 0%, if I move the throttle plus or minus 8% there is no visible movement in the analog display, I need to hit about 10% to see the bar move off center on the display, though your display may have better resolution than my 8FG.
I'll stay tuned for your update
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Apr 29, 2015, 07:41 PM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Thanks Pete.
The throttle tension is moderate, and the travel is indexed (tick-tick-tick). Because of the indexing, throttle does not wander when rudder inputs are made.
I just checked my elevator/aileron servo movement (right stick) and while there's a twitch of movement of the opposite servo, it's not near as much as the throttle servo movement, when the rudder is moved. BTW, there is no rudder servo movement when changing the throttle setting.
EJ
Old Apr 29, 2015, 09:42 PM
ivanc is offline
S.A.D. member
ivanc's Avatar
Joined Dec 2004
Have you tried to calibrate the gimbals?
Old Apr 29, 2015, 09:48 PM
BHOFM is offline
Find More Posts by BHOFM
Kimbers Keeper.
Joined Nov 2014
Hold the throttle all the way down and move the rudder. Still Doing it?
It is hard to move one without the other moving just a tad.
BHOFM is offline Find More Posts by BHOFM
Old Apr 29, 2015, 11:05 PM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Yep. Went to the menu and selected "Neutral", which centered all the servos. Interestingly, when I exit the page, the rudder offsets a little.
Once again, I sent the radio in for a check-up last November, and it was given a clean bill of health. Maybe this is normal? I really never paid this much attention to this behavior in my last radio (JR), so I can't relate experience-wise.
EJ
Old Apr 29, 2015, 11:06 PM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Yep.
EJ
Old Apr 30, 2015, 12:03 AM
BHOFM is offline
Kimbers Keeper.
Joined Nov 2014
Originally Posted by EJWash1 View Post
Yep.
EJ
I would take the back off the transmitter and look for something loose. the pots
or bad bearings.
Old Apr 30, 2015, 12:30 AM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
or bad bearings.
New radio. Worth a look though.
EJ
Old Apr 30, 2015, 05:34 AM
Ken Myers is online now
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
How to set up the stick tension and length to avoid interaction is described in this video
Tactic TTX650 set up video 2 (19 min 39 sec)
While the video uses the Tactic TTX650 for demonstration, it applies to all transmitters.
I've been flying RC for a gazillion years, 55 or more in human years, and always had my sticks too long for the way my wrist rolls with my hand.
The video could have used a bit more editing, but it is certainly worth the view.
The setup procedure does indeed translate into smoother flying with little or no interaction of the stick's axises.
Ken Myers is online now Find More Posts by Ken Myers
Old Apr 30, 2015, 05:52 AM
Jet_Flyer is online now
Find More Posts by Jet_Flyer
AKA 8178
Jet_Flyer's Avatar
Joined May 2004
I got my old mode 2 12FG that I seldom use anymore because I have a Taranis Plus telemetry system now and tested the rudder throttle. As expected there is absolutely no interaction between the rudder and throttle or any other control.
The 12FG was a great radio in its day, but Futaba let it die and has never replace it with a newer system with the same powerful features unless you buy a 18MZ.
Jet_Flyer is online now Find More Posts by Jet_Flyer
Help! Throttle servo moves about 1/8th when powering on. p3arljam Radios 3 Apr 02, 2015 06:29 PM
Discussion when moving rudder control ailerons are moving slightly Patrick10am Electric Plane Talk 15 Feb 16, 2015 09:14 AM
Discussion Throttle input also moves Rudder on Naza M V2 RedfishHex Multirotor Electronics 3 Feb 09, 2015 12:22 PM
Discussion does the elavator servo move up and down with rudder inputs MSR user0125 Micro Helis 9 Mar 13, 2010 02:07 AM
Throttle servo moves when elevator servo is moved chris8105 Fuel Plane Talk 22 Jan 10, 2007 02:53 PM
