Old Today, 04:37 AM
Brainstorm is online now
Find More Posts by Brainstorm
WarpSquad: practice, practice!
Côte d'Ivoire
Joined Jun 2012
Originally Posted by jroodnick View Post
hmm so im getting all the controls responding on my GUI when I move them on my transmitter, but I was a little confused about how the receiver should be connected so maybe this is the problem. I have a lemon RX and its corresponding satalite, I connected the lemon RX main to (g) (v) (ppm), do i need to use the satalite at all or is this enough?
If the four controls are responding correctly in the GUI, that means TX signals are getting through to the MotoWii FC. So that's a good thing.
Interesting that you got this to work with the main (big) Lemon RX. Most of us use the small Sat RX, and use the big RX only for binding. If stick movements are getting through alright, this may not be your problem. But I would try to connect the Sat RX instead. You never know...
My only other thought is that maybe stick travel isn't adjusted properly. You have to calibrate the TX signal to make sure it goes low enough (on throttle and rudder) for the FC to receive and properly interpret the Arm and Disarm stick commands. Can you Arm and Disarm properly? (Props off, as always!) I believe this is something that shows up in the GUI as well.
Hoping that our electronics gurus Moto Moto and Waltr can chime in here. Beyond what I wrote above, I'm at a loss, unfortunately.
Brainstorm is online now Find More Posts by Brainstorm
Old Today, 06:10 AM
Blackjohnson is online now
Find More Posts by Blackjohnson
Joined Mar 2015
Solder the lemon sat to the sat pins. S,g,v not the ppm
I'm assuming your using a motowii board tho
Blackjohnson is online now Find More Posts by Blackjohnson
For Sale Qx9 carbon fiber acro fpv quad awdspider Aircraft - Electric - Multirotor (FS/W) 14 Jun 06, 2014 05:12 PM
New Product Phoenix Flight Gear 242 Carbon Fiber Flight Ring for Acro/FPV Z06 Tony Mini Multirotors 13 Apr 14, 2014 08:34 PM
Sold Warpquad 230mm Acro nate25j Aircraft - Electric - Multirotor (FS/W) 2 Apr 14, 2014 06:25 AM
New Product Phoenix Flight Gear 328 Flight Ring Carbon Fiber Frame For FPV/Acro Z06 Tony Multirotor Talk 3 Jan 22, 2014 07:50 PM
Discussion Quadcopter with FPV in Acro or Level Mode ? dezeubby Multirotor Electronics 10 Dec 15, 2013 08:13 AM
