Jim,
I would definetly go with a laser setup for the type of cuts you are looking for in foam a CNC machine is nice but to get the fine detail cuts you will need will not be able to be done easily with a CNC machine setup. Here is link to a company out of Las Vegas that has the machine that is built in China and is cleaned up here in the States, ships from the states and has it's warranties in the states. All for less than 2k. http://fslaser.com/40wbasic DT |
Brian, Thank you, I might just do that one day as my wife and I are always down in El Dorado County buying wine. We usually stay in the Best Western off of Missouri Flat Rd. I will extend an invite to you if you ever come up to Reno I will show you my CNC machine. I am currently setup in the garage but I got the OK from the wife to build a shop in the back yard near my other large shed and dog run. After I get the new shop built I can then finish my larger CNC machine and get the rest of my tools setup in a more permanent setting. Tom |
Wichita, Kansas, USA
Joined Jul 2003
Might want to consider a CNC mill for cutting Depron. Much better cuts with a router than with a laser on Depron.
Jimmy |
Latest blog entry: Ultrabatic BD-5J
United States, MN, Orono
Joined May 2011
Thanks for all the help, guys.
![]() I appreciate the thoughts and input. I know about 10X more than I did just two days ago. The real problem I have is that I would be starting a business by doing this, and therefore I would need to at least break even if I invest in my own machine. The trouble is, I don't think I will be able to break even by selling depron kits for a long time if I invest in a $2,000 USD machine... I think I am going to start this thing off with a cutting service, simply because I don't want to pay for a new machine and not sell many planes. However, if there is enough interest and I think I can break even (which is very possible), then I may invest in my own cutting device. On that note, does anyone have any idea on what it will cost to cut a certain number of 2mm depron pieces. Again, I am looking for the lowest possible cost while still providing quality pieces. Thanks in advance, Jim |
United States, PA, Greensburg
Joined Oct 2009
IMO I would not do buisness with FSE. you can read about them on other forums if you would like. If you would like me to quote your parts I would be happy to do so, just PM me. |
Joined May 2011
Thanks for the responses, guys.
To narrow down the search, I am looking for a CNC machine that has about a 24 inch x 12 inch bed (anything smaller will not work), and I would like to do this for under $2,000. Even if it is used. It doesn't need to be able to cut 3D, it doesn't need to have fancy buttons or a cup holder. It just needs to be capable of safely cutting depron and light balsa. That's it. Surely a such product must exist. If anyone sees something that fits this description, then please, don't hesitate to let me know. Thanks, Jim |
Joined May 2011
How about this?:
http://www.carving-cnc.com/cnc6040-s...g-machine.html It's $1500 USD and has a 58 cm x 40 cm bed, which, although is not huge, should be large enough for my project. Does it look like it is of reasonable quality? It comes from Hong Kong, but the website seems very thorough and professional. Thanks, Jim |
United States, CA, Cameron Park
Joined Jan 2004
That doesn't seem like too bad of a machine.
Did you check out the $400 + for shipping? You're going to need a controller program and at least an older(ish) desktop pc. Emc2 is free and it'll work if you're okay with Linux. Mach3 is about $170 for Windows (32 bit only). There may be others, however,I haven't kept track of them. You're also going to need a CAM program like CamBam. This will take your CAD files and generate g-code which is executed by the controller program. I think CamBam is in the $150 range. Again there are other programs and some of them might be free. Finally, you need to buy some end-mills. These are sort of like drill bits but they can cut sideways. I'm not trying to discourage you! I just want you to be aware of the costs. By the way, In general these costs are pretty much the same for a laser cutter. Regards, Brian |
| Thread Tools | |
| For Sale CNC Laser Cutting Service | johnorama | Aircraft - General - Miscellaneous (FS/W) | 6 | Jan 22, 2013 12:20 AM |
| Discussion laser cutting | vicsrc | Balsa Builders | 3 | Jan 03, 2013 11:49 AM |
| Discussion Scaling down plans for CNC laser/router cutting | Fossil1977 | The Builders Workshop | 2 | Jun 07, 2009 11:52 PM |
| Discussion Looking 4 a laser cutter or cnc cutting service | Stealth Assassin | The Builders Workshop | 6 | Mar 25, 2009 04:15 PM |
| Kit Cutting - Laser/CNC | twopper | The Builders Workshop | 7 | Apr 25, 2004 03:42 PM |
