Old Jan 17, 2015, 11:41 PM
BJ64 is offline
Find More Posts by BJ64
The wheels touch down FIRST??
BJ64's Avatar
Australia, VIC, Melbourne
Joined Jun 2009
That what I was looking for, Allan - the FLAP SYSTEM menu in ACRO mode.
Is it not available at the moment because I have the FLAP [OUT] set to ACT instead of SYS?
Will set it to SYS and see what I can find
Not sure what you mean by "The only disadvantage to using the FLAP SYSTEM is that you will probably end up using only a portion of your flap servo's potential travel." Are the throws not able to be set to 100% on the 3Pos switch?
BJ
BJ64 is offline Find More Posts by BJ64
Old Jan 17, 2015, 11:49 PM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
PS - interestingly enough, as it is right now with FLAP [OUT] set to ACT and using the 'AUX2' 3Pos switch (the one just to the right of the Ele Dual Rates 2pos switch), I actually get 3 flap positions - Up, center (neutral), and Down... but only the Up and Down have parameters that I can change in the Travel Adj' menu.
As I was trying to explain earlier, Pos0 is only ever 'Up' - configurable from 100% down to 0%. Pos1 is center, and can't be adjusted at all. And Pos2 is only ever 'Down' - again configurable from 100% down to 0%.
I seem to recall that on my DSX9, I got to a menu somehow that allowed me to configure all 3 switch positions to anything I liked - 'Up' 100% down to 0%, and then the variable changed to 'Down' from 0% to 100% i.e. I could roll the percentages/direction Up or Down to 100% going through 0% (U 100% to 0, then then it switched to D and started to go from 0 to 100%)
I'm hoping that changing FLAP [OUT] to SYS on the 11X will allow me to do the same thing..
BJ
Old Jan 18, 2015, 01:37 AM
Petem is offline
Find More Posts by Petem
If it flies - I want one!
Petem's Avatar
Australia, VIC, Werribee
Joined Jul 2008
What we have here ...
BJ,
I'm not sure we have full two-way communication here.
What I was trying to say is that you have what you want right now, except for the neutral point - you want Up to be clean/faired/zero flap, then two stages down from there, yes?
The easiest way to achieve that is by moving the whole flap range downwards till Up flap is level with the wing section - either by winding the clevises in/out, moving the servo arm on the splines, putting in a bunch of Down sub-trim on the flap servos, or a combination to suit your setup.
Do that till the middle, fixed position is your desired half flap, then set throw up and down to get Clean in the Up position, and your desired full flap in the Down.
Dunno if any of that helps - too many words.
Cheers,
Pete
Petem is offline Find More Posts by Petem
Old Jan 18, 2015, 01:40 AM
AWorrest is online now
Find More Posts by AWorrest
Lincoln, NE
Joined May 2005
When any channel's [DEVICE] is a three-position switch and its [OUT] is ACT, you get the travel adjustments high position, the subtrim position, and the travel adjustment low position. The FLAP SYSTEM menu is only visible if the FLAP [OUT] is SYS. I don't know about the DSX9 but it's that way on the 9303 and the 11X.
To have use of the flap servo entire travel, I've seen the flap system set up such that the NORM position is U100%, MID is 0% (or some other value of your choosing), and LAND is D100%. Then the linkage is adjusted so the flap is neutral when the switch is in NORM. It is nearly equivalent to what you were trying to do. The problem with using the subtrim and the travel adjustment method is that the subtrim affects the travel adjustment values. As you increase the subtrim, the high and low end points move. If you use the FLAP SYSTEM, the three adjustments are independent.
Allan
AWorrest is online now Find More Posts by AWorrest
Old Jan 18, 2015, 02:01 AM
Lincoln, NE
Joined May 2005
As you are programming in ACRO, the flap system menu is easiest. However, if you were using GLID and wanted to use a three-position switch instead of a lever for flap control, Pete's post #93 would be the way to go.
Allan
Old Jan 18, 2015, 06:50 AM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
Originally Posted by Petem View Post
...The easiest way to achieve that is by moving the whole flap range downwards till Up flap is level with the wing section - either by winding the clevises in/out, moving the servo arm on the splines, putting in a bunch of Down sub-trim on the flap servos, or a combination to suit your setup....Pete
I got what you meant the first time.
But this is a $600+ radio - surely I don't have to dodge curve-balls around corners and have to fudge my Servo arm positions just to appease the Tx ??
60 dollar radio gear can do all that stuff these days...
BJ
Old Jan 18, 2015, 06:58 AM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
Originally Posted by AWorrest View Post
..The FLAP SYSTEM menu is only visible if the FLAP [OUT] is SYS...
Allan
Didn't get a chance to try it yet - spent all day fitting out the new 'hobby shed'.
I hope get get a chance to try that method sooner rather than later ...but I have to fix the ASW29 now that I managed to stove it in dead-center prop on the only soccer goal-post within 3 freakin miles...
BJ
Old Jan 18, 2015, 04:14 PM
Petem is offline
Petem's Avatar
Joined Jul 2008
BJ, agree all - I grumble incessantly when trying to convince my quite expensive, but slightly dated radio to do things that the new stuff does in its sleep!
But if the aim is to go flying with a setup that works as you want ...
Old Jan 18, 2015, 09:00 PM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
I'm pretty stubborn Pete, so I guess I'll persevere with the 'JR way' on the 11X.
A lot of things are doable, but getting to comprehend them isn't all that easy via the Manual - it tends to be written at a level that assumes you already know what it is that you want to do. Still, at least there is a Manual that's written in readable English. It's just a pity that it's not written for doofusses like me to understand.
With the help of you guys, I reckon I'll get close to what I want to do. It gets a bit embarrassing asking dumbarse questions all the time...
BJ
Old Jan 19, 2015, 07:58 AM
alexhallmalta is offline
Find More Posts by alexhallmalta
Malta & Newport
United States, RI, Newport
Joined May 2010
Hi BJ, been away, so just caught up with your dilemma. If its any help I have some time over the next few days, so I ll try programming a model in ACRO and will try to gget the flaps to act on a switch.
Quick question, you do have each wing surface on a separate channel don't you?
alexhallmalta is offline Find More Posts by alexhallmalta
Old Jan 19, 2015, 04:05 PM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
Yep.
11X model set to ACRO.
2 Aileron servos and 2 Flap servos.
Starboard Aileron is in Ail Ch (2), Port Aileron is in Gear Ch (5).
Both Flaps are running into a Y-lead and plugged into Aux1 Channel (6).
Wing Type set to Normal.
Device Select FLAP set to AUX2 SW, ACT (which I'll change to SYS as per previous recommendations).
DUAL - AILE - is mated to Gear.
BJ
Old Feb 03, 2015, 07:28 AM
mutha is online now
Find More Posts by mutha
RC Airplane (Recently Crashed)
mutha's Avatar
Joined Jan 2011
Originally Posted by BJ64 View Post
...oh yeah... and whose idea was it to take the second aileron control (when available) from the GEAR channel instead of AUX1?
That little gem nearly did my head in when trying to get the 'Dual Aileron' setup to work under ACRO...
BJ
BJ look here ....
http://www.flyinggiants.com/forums/s...ad.php?t=68099
BTW can help you now I ken understand the things and differences ...
edit: BTW if you have a 7 channel or more Rx use it and put flaps in 2 channels ... also use Glid mode ... Lots of benefits with this setup
mutha is online now Find More Posts by mutha
Help! dlg programing for jr11x skylerraver Hand Launch 0 Jan 13, 2011 05:46 PM
Mini-HowTo Programming Futaba 14MZ for Full-House Sailplanes fnnwizard Sailplane Talk 28 Dec 15, 2010 05:19 PM
Found Radio Programming Clinic for sailplanes orbitone Aircraft - Sailplanes (FS/W) 1 Aug 06, 2008 12:02 PM
