Old Jan 31, 2016, 04:54 PM
JaggySnake is offline
Find More Posts by JaggySnake
United Kingdom, Hebburn
Joined Jan 2016
Hot wire cutter help
I bought a 12 volt 6 amp car battery charger with the intent to use it as a hot wire cutter attached to a wooden bow and some nickel coated electric guitar string (E). However the charger refused to create the circuit when all attached and would just turn off, unfortunately i bought a car charger with reverse polarity protection which is what I think is causing it.
I've taken it apart in the hope I can recycle some of the components into a working power supply however I lack the knowledge to do this alone.
Any help or suggestions would be greatly appreciated!
JaggySnake is offline Find More Posts by JaggySnake
Old Jan 31, 2016, 06:20 PM
Granted is offline
Find More Posts by Granted
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
Remove the circuit board, connect the battery clip wires to the transformer output wires and add a light dimmer 'tween the transformer and mains.
Be careful, pay attention.
Granted is offline Find More Posts by Granted
Old Feb 01, 2016, 11:05 AM
Joined Jan 2016
Thank you, really appreciate the help!
Old Feb 03, 2016, 08:45 AM
chinger is offline
Find More Posts by chinger
Joined Dec 2009
Have to notice something... where is the fuse? It should be on the board, on the place marked with F1. Try with car fuse, 10A.
chinger is offline Find More Posts by chinger
Old Feb 03, 2016, 04:25 PM
elewon is offline
Find More Posts by elewon
elewon's Avatar
United States, CA, Sacramento
Joined Feb 2013
This thread might be more suitable for DIY electronics forum.
The battery charger I have has a battery sense circuit along with short circuit protection. The output will not turn ON unless the leads are connected to a battery and that almost makes it useless for hot wire cutter. I'm assuming your battery charger does not have these "features"
Are you sure the transformer is not dead? Have you measured output voltage at the transformer? It could be that the transformer is OK and that you blew off the fuse?
If the transformer indeed is OK and is rated for 12V/6A, using a dimmer might be the easiest solution. In which case, you don't even need the bridge rectifier.
However, if you plan to use a brushed ESC for current control I'd think you'll need the bridge.
You might also want to pay attention that the total power draw should not exceed 72W.
elewon is offline Find More Posts by elewon
Old Feb 05, 2016, 05:21 AM
Joined Jan 2016
Hi chinger yes you are precisely right and I had already taken the fuse out to take it apart, it was a 7.5 amp fuse i think.
Thanks for the info elewon, I took a gamble because it was cheap and I'm supporting my girlfriend through university right now so money is tight especially when hobbies are concerned! So I have to work with what I have i guess. My work gets a heck of a lot of these big polystyrene boxes so I thought i'd try my luck making a plane. As far as I know its all working and the plan is to attach a dimmer as soon as I find one suitable for it.
Again, thank you guys I really appreciate the replies and support.
Sold Hot wire foam cutter cnc 4 axis GORT000 Aircraft - General - Miscellaneous (FS/W) 4 Sep 18, 2015 09:18 AM
For Sale Table Top Foam Hot Wire Cutter AJ750 Aircraft - General - Miscellaneous (FS/W) 0 Jul 20, 2015 07:32 PM
Help! My first CNC hot wire foam cutter HELP Wa7sh CAD/CAM 28 Jun 16, 2015 07:43 AM
Idea Foam Hot Wire Cutter rudes Foamies (Scratchbuilt) 4 May 09, 2015 11:46 PM
