Old Yesterday, 10:10 AM
Duane
Wazmo's Avatar
No. VA
Joined Nov 2004
TinyG CNC Controller
Has anyone used a TinyG CNC Controller? What was your experience with it? Looking for something inexpensive to drive a four-axis hot-wire cutter. The acceleration planning is very cool, but probably not necessary for hot-wire.
Product Details
The TinyG is a hardware and firmware project that is a multiple-axis motion control system. It is designed for small CNC applications and other applications that require highly controllable motion control. TinyG is meant to be a complete embedded solution for small/medium motor control.
  • Up to 6 axis (XYZ + ABC rotational axes) control with drivers for 4 axes on board.
  • Working Voltage: 12-30VDC (24 is Ideal)
  • Stepper drivers can deliver up to 2.5 amp per winding.
  • Selectable micro-stepping up to 1/8.
  • Acceleration planning performed using constant jerk motion equations (3rd order S curves) for very smooth and fast motion transitions for lines and arcs
  • Full, integrated motion control system with embedded microcontroller (Atmel ATxmega192) and 4 stepper motor drivers (TI DRV8818) integrated on a ~4 inch square board
  • Accepts Gcode from USB port and interprets it locally on the board
  • Easily upgraded by the user with a few commands through the USB port.
  • RoHS compliant.
TinyG is open source. The documentation can be found here.
Wazmo is offline Find More Posts by Wazmo
For Sale CNC controller mach3 stepper drivers topforce Non R/C Items (FS/W) 1 Feb 03, 2014 11:54 AM
For Sale Complete Turnkey CNC Controller Package storm2313 Aircraft - General - Miscellaneous (FS/W) 0 Jan 19, 2014 03:51 PM
Sold DJI Phantom Gopro 3 CNC Metal Brushless Camera Gimbal with Motors & Controller daskim Aircraft - Electric - Multirotor (FS/W) 3 Dec 26, 2013 10:59 PM
For Sale 55cm custom CNC quadcopter frame ARF with kk2.0 Flight controller tav31 Aircraft - Electric - Multirotor (FS/W) 4 Oct 30, 2013 02:47 PM
For Sale 550mm custom CNC quadcopter frame ARF with kk2.0 Flight controller tav31 Aircraft - Electric - Multirotor (FS/W) 0 Oct 12, 2013 04:36 AM
