Old May 30, 2013, 11:40 AM
Joined Feb 2013
One quadcopter motor slower than others
Hello, I have built a quadcopter with the MultiWii PRO Flight Controller w/MTK GPS Module. I calibrated the ESC's and I did all the other calibrations I could think of, but my back left motor runs slower than the others at all times. I've attached screenshots. Shen I first power up, they spin evenly at 0 throttle, but when I increase throttle, they spin up evenly except for the back left. I tried flying and it flipped over and crashed. Is this a bad ESC or something?
coombs is offline Find More Posts by coombs
Old May 30, 2013, 03:31 PM
United States, IA, Grimes
Joined Mar 2005
Swap it with another motor on your quad. If it still does the same thing in a different spot, it's probably the motor. If it spins up and the motor you swapped it with is now the slow one, it's probably the ESC.
wraith0078 is offline Find More Posts by wraith0078
Old May 30, 2013, 05:13 PM
OzBlueDragon's Avatar
Australia, QLD, Loganlea
Joined Feb 2012
Coombs I've been looking at the same board set up. Is that the software you get with it or download? Is it easy to set up or do you need an engineering degree? I'm new into multirotors mate.
Try what wraith said too
OzBlueDragon is offline Find More Posts by OzBlueDragon
Old Jun 04, 2013, 07:05 AM
Joined Feb 2013
The firmware is MultiWii and the GUI in the screenshots is MultiWii GUI hosted here: http://code.google.com/p/mw-wingui/
Pretty easy to set up.
Old Jun 04, 2013, 07:06 AM
Joined Feb 2013
I swapped out all the motors and it does the same thing. I guess I'll try switching the ESC's around. I have new ones on the way from HobbyKing because I wanted ones I can flash with SimonK, so I'm replacing all of them. Hope it helps!!
Old Jun 04, 2013, 04:34 PM
Joined Jun 2013
I also have a multiwii, and my rear left motor also lags behind the other three. The front left and rear right start at the same time, then the front right shortly after, but the rear left doesn't start until I give it 20% throttle. It has to be a software issue, but I can't find where to change this.
soulcopter is offline Find More Posts by soulcopter
Old Jun 04, 2013, 07:36 PM
Jack
USA, ME, Ellsworth
Joined May 2008
I'm new to this and have a question. Does the controller have any way to monitor the actual RPM of each motor? I think not, it is actually just varying the PWM rates for each motor to correct the reading from the sensors, right? So unless all the motors have the same Kv there is going to be a variation in the RPM from one motor to another.
And the actual Kv's of motors is seldom, if ever, the number of the Kv that they are advertised as having. Some of them can vary by hundreds of RPM from the advertised values. It you want to see examples of the variations, you can look up motors at flybrushless.com and, in many cases, see actual Kv of the motor tested:
http://www.flybrushless.com/search
To tell if the Kv listed on the test data pages is the advertised Kv or one that was measured during testing, look at the values under the Constants heading. If the have 0's there the Kv is the advertised Kv, if there are values for the constants the value seen is the actual Kv. The vlaues for a typical tested motor would look like this:
Constants
kV: 2800
Rm: 0.08
Io: 1.55
The numbers will often be rounded off to the nearest 50 or 100 RPM increment.
If you want to test your own motors, you can get a "raw" Kv reading by running the motor at full throttle without a prop on it and reading the RPM and voltage at the same moment in time. The RPM divided by the voltage is is the raw Kv. And that will be accurate to within one or two percent of the actual Kv.
When you have a data logger attached that will monitor RPM and voltage you can look at the full throttle data for a 5 second or so period of time and that will even out the variations and give you a better number.
So if you did that for all motors in a set, it might point out a motor with wide variation from the others.
@coombs,
What motors are you using?
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jun 04, 2013, 08:56 PM
Joined Jun 2013
I'm using 2830-11s, 1000KV. I've switched out the rear left motor for others, and even when the motors aren't attached the multiwii GUI shows the rear left as lagging significantly behind the other three. It seems pretty clear that this is a multiwii issue, but I'm not able to fix it by recalibrating the ESCs.
Old Jun 06, 2013, 08:40 AM
Joined Feb 2013
I also switched my motors out for a new set and the same happens. Also, if I rotate the motors, the same position always lags. I would rotate the speed controllers, but that would require some major disassembly. Guess I should try it though.
Old Jun 14, 2013, 12:56 PM
Joined Feb 2013
Well, I replaced all the motors with DT750's and replaced all the ESC's with HK 30A flashed with SimonK and the back-left motor still spins slower than the rest. Guess I'll take it outside and test it out again to see if it flips over. If it does, this flight controller is going in the garbage. I have a KK2 on the way right now, but it hasn't arrived yet.
Old Aug 25, 2013, 06:20 PM
Joined Apr 2013
same problem
Did you ever find a fix for this Coombs? I have the same problem with my multiwii.
StewieGriffin is offline Find More Posts by StewieGriffin
Old Aug 29, 2013, 07:31 PM
Joined Apr 2013
Found the problem
So, I'm using the Spectrum Dx6i transmitter and found that in order to get my motors to balance I had to adjust my sub trim throttle to -100. Other minor adjustments had to be made through Travel Adj and PID settings.
Old Aug 29, 2013, 07:37 PM
Arkansas
Joined Jul 2008
Coombs would you might be from Kentucky?
WyDiablo is online now Find More Posts by WyDiablo
Old Dec 12, 2013, 10:02 PM
Joined Feb 2011
faster rpms on right front!?
I have the multiwii with the gps also and the front Right RPMs are faster when I throttle up but the same at 0 throttle. It sounds like I have the opposite problem.
Did anyone find out how to fix this? is it a sub trim thing or the board? I have changed the esc and motors and it has the same problem.
thanks
mbe575s is offline Find More Posts by mbe575s
Old Jan 13, 2014, 09:07 PM
Joined Aug 2013
Solved
thanks
There is a new DEV Version of the firmware that solved this for me.
.code.google.com/p/multiwii/downloads/detail?name=MultiWii_dev_2014_01_14__r1648.zip&can =2&q=
Signet is offline Find More Posts by Signet
Discussion Quadcopter, 1 motor runs a lot faster than other 3 golden77 Multirotor Talk 14 Jan 17, 2014 12:00 PM
Cool One Quadcopter Throws, The Other Catches James Frolik Multirotor Talk 1 Feb 26, 2013 06:24 AM
Discussion One motor draws more amps than the other three dmcquinn Power Systems 8 Jan 01, 2011 04:24 AM
Question Motor feels "gritty", spins slightly slower than other 3 at same throttle setting bob4432 Power Systems 7 Sep 12, 2010 08:57 PM
Question Motor feels "gritty", spins slightly slower than other 3 at same throttle setting bob4432 Electric Motor Design and Construction 0 Sep 11, 2010 11:20 PM
