Old Oct 30, 2015, 09:07 PM
caineroad is offline
Find More Posts by caineroad
Joined Apr 2013
How to seal the hatch?
I have a ft009, i keep getting water inside, how do you seal it??
I am going to put a go pro on so it will be weighted down, so i need not only to be splash proof but leak proof as well in case water flows on top.
caineroad is offline Find More Posts by caineroad
Old Oct 30, 2015, 10:02 PM
savage0102 is offline
Find More Posts by savage0102
Joined Jun 2012
Hi! I have ft012 which is a brushless version with the same issue. I found out that the water comes in through the rear coners of the deck & hull joint.
So I took out the servo and the battery tray, and then put silicone with a cotton swap from the inside of the hull. Now after each run, my boat is dry all the time. I hope it hels!
savage0102 is offline Find More Posts by savage0102
Discussion How to make hatch seal on sewer pipe sub? HugoW Submarines 16 Sep 08, 2015 05:57 AM
Help! Cowl/Hatch bowing up in the middle, will not seal properly. TeeShark Dock Talk 6 Sep 07, 2015 03:46 AM
Discussion Sealing a hatch Si2 Sailboats 6 Jan 19, 2015 11:55 AM
Discussion Sealing the radio hatch md6364 Sailboats 2 Aug 19, 2014 11:01 AM
Help! How to Seal My Hatch kilo2018 Dock Talk 20 Apr 27, 2010 03:26 PM
