Old Jan 27, 2016, 08:14 PM
hangtheman is offline
Find More Posts by hangtheman
Kid at heart..
United States, TX, Houston
Joined Apr 2014
Originally Posted by da.arbib View Post
Hey.
I wanted to ask you for help to ask two questions.
1. The following video can see that I was pushing the car forward instead to travel so properly is stumbling forward like trying to decide whether to travel forward or stop (it seems to him there is a problem with the gears - how do I validate it?). There is also a very strong noise of metal stuck or something.
2. I changed it today a receiver- cable that connects to the battery and servo . but then the instead to go forward and i push forward- she goes backward and when i push backwad she goes forward. i change the plus and minus cables and it's work out but it's forward goes slowly ike it's backward and back goes fast like it forward.
can any one help me please?
https://drive.google.com/file/d/0B-T...ew?usp=sharing
thanks for all
Make sure the Throttle switch for Rev/Nor is set correctly on the remote.
Here's what you need to do.
If your car is going forward much slower than reverse, it means your motor is wired backwards. Just switch any two motor cables out of the three and it will be oriented in the right direction.
Once you make sure the Rev/Nor switch for the throttle is setup correctly and the motor wires correctly, that will solve your issue. Note, most remotes should have the Throttle switched to the "Rev" position.
As for setting the throttle calibration on the ESC, if you can show which model/brand the EDC is, I can help you with how to do it.
hangtheman is offline Find More Posts by hangtheman
Old Jan 28, 2016, 11:45 PM
Silok is offline
Find More Posts by Silok
Joined Jul 2015
huh there is no Rev/Nor throttle switch on the wltoys transmitter. Only a throttle trim wich is not the same thing.
Silok is offline Find More Posts by Silok
Old Jan 29, 2016, 09:01 AM
Kid at heart..
Joined Apr 2014
Oh, I had thought the OP has switched out electronics and is no longer using the WLToys remote/electronics. He did mentioned he changed out the receiver and such..
Old Jan 29, 2016, 04:18 PM
Silok is offline
Joined Jul 2015
Yeah he replace the receiver but that all and this is because he tough it was broken so he probably just bought the same wltoys receiver, at least i think. He is not clear with what he got and what he did. He talk about the L202, that why he got the brushless kit (bought it like that) but i dont think he change the electronics for customs ones.
Mini-Review WLtoys V912 4-Channel Fixed Pitch Helicopter Mini-Review FyreSG Micro Helis 8981 Feb 05, 2016 03:59 AM
Data HiSKY FBL100 / Turnigy FBL100 / WLToys V922 vs. mCP X Parts Compatibility sparkyjohn Micro Helis 118 May 10, 2015 04:31 AM
Mini-Review WLtoys V959 Quad (with Video Recording Function) Mini-Review FyreSG Mini Multirotors 1314 Feb 19, 2015 10:45 PM
Mini-Review MJX F45 VS F46 ,WLtoys V912 VS V913 Aaron qin Micro Helis 132 Jan 18, 2015 05:16 PM
Discussion WLtoys V949 UFO Quad fierce Hot Online Deals 5 Jan 09, 2013 10:07 AM
