Old Nov 25, 2015, 12:42 PM
John_Edward is offline
Find More Posts by John_Edward
Darwin of quadcopter canopies
John_Edward's Avatar
Finland, Espoo
Joined Jun 2011
Originally Posted by martin555 View Post
what connector the q-bot has for power?
is this battery good for replacement?
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Yes, BUT!
That battery has reversed polarity, you HAVE TO switch the red and black wires around.
Double triple quadruplecheck that you connect red to red and black to black, the quad can survive reverse polarity right around a millisecond.
And get the 45 to 90C, much more punch.
John_Edward is offline Find More Posts by John_Edward
Old Nov 25, 2015, 01:22 PM
martin555 is online now
Find More Posts by martin555
http://www.nemesikle.hu
martin555's Avatar
Hungary, Baranya, Pécs
Joined Jul 2011
Mister John_Edward,
making me aware of the polarity.. THANK you man!!!!
martin555 is online now Find More Posts by martin555
Old Dec 04, 2015, 01:37 PM
martin555's Avatar
Joined Jul 2011
oh my.
I have turnigy 9x, modded completely to er9x (sound backlight and so on)
I was trying to searc this thread honestly but found just this solution for me:
http://www.rcgroups.com/forums/showp...34&postcount=1
I was hoping on a simpler plug and play solution, what do you ppl say?
Old Dec 05, 2015, 06:34 AM
martin555's Avatar
Joined Jul 2011
solved
The module antenna and quad antenna need to be within 2 or 3 cms from each other. Plug module into transmitter but dont turn on, connect battery to craft then turn on module, should bind ok.
Old Feb 25, 2016, 02:26 AM
martin555's Avatar
Joined Jul 2011
please if somebody has already discovered replacement parts to HOBBYKING Q-Bot micro, please share the link with us
with what products is the HK q-bot micro 1:1 compatible?
1 of my motors (front left) has already worn out, will not spin.. also a good source of props would be needed. and maybe I need a whole replacement main board too.
nothing remains only the HK replacement parts? they sell parts more expensive than ebay/aliexpress.
http://www.hobbyking.com/hobbyking/s...cro_Parts.html
Old Feb 25, 2016, 03:21 AM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
As The Hobbyking Micro Q-Bot is just a rebrand of the HiSky FF120 / HMX120 (its newer name) all their hardware parts are identical and exchangeable.
For motors any 0720 sized ones will do, regardless of branding - Hubsan, Chaoli, Micro Motor Warehouse, UDI, JJRC, you name it.
You have to splice in the plug again after a motor change, though.
Prop wise its basically the same situation.
Most similar to stock ones, but a tad better in quality: Walkera QR Ladybird props.
Very good and better than stock: clear Hubsan styled props or OEM Hubsan ones.
Have Fun!
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Feb 25, 2016, 04:18 AM
martin555's Avatar
Joined Jul 2011
Danke Schön!
Old Mar 03, 2016, 05:07 PM
ganante is offline
Find More Posts by ganante
Joined Oct 2015
compatible with flysky fs-i6 transmitter ?
Originally Posted by IanPellant View Post
The FlySky protocol does not work with the Turnigy Micro Q-Bot. It comes with the (HiSky) HT8 adapter which is best connected to a TX via a Futaba trainer port. The Futaba port supplies power from the TX to the adapter module. The alternate JR stereo plug trainer does not readily supply power (I had no luck with the Turnigy 9X)
Binding with the HiSky protocols is mostly by powering up the TX module then simply turn on the RX. The RX will find and bind to the strongest rf signal it finds.... the TX must be as close to the quad as possible if there is a chance of anyone else using a compatible RF within range.
The HT8 adapter works with the Turnigy / HiSky FBL100 (WL Toys V922) and the HiSky HCP 100. It does not work with the WL Toys V911.
By adding the back-stand accessory to the Turnigy 9XR, the HT8 adapter fits neatly between the stand legs. I have the FlySky module plugged in at the same time. No conflicts. See pic
hello , my transmitter flysky fs-i6 is compatible ? it doesn't have the trainer ports JR style 3.5mm or Futaba style 6-pin. i have to use the cable adapter in this kit ?http://www.hobbyking.com/hobbyking/store/__63756__T
urnigy_TGY_i6_Flight_Simulation_Cable.html
to convert the sinal to trainer port of my transmitter . thanks
i read this in other comment :
" Philippe 6 points - 10/08/2015
I wish to use it with a FlySky FS-CT6A ( or Hobbyking HK-T6A) 6 channels 2,54Ghz. Is it compatible ??Thanks.
Jason 3 points
I'm not sure if this would work, but the Turnigy i6 Simulator cable (PRODUCT ID: 114000022-0) has an adapter that plugs into the training port at the back, and converts from the 4 pin socket in the transmitter to a 3.5mm female socket. Considering that works with controlling simulator software, then I would be assuming it would send the same signal to the module on this. "
it's possible to work ?
thanks
ganante is offline Find More Posts by ganante
Old Mar 03, 2016, 05:34 PM
Germany, Berlin
Joined Jun 2012
Will work.
The DIN connector has the needed outputs - PPM and GND.
You'd need just the part: Female 3.5mm to Male DIN 4p adapter
The USB part isn't needed for your purpose.
You have to use the inbuilt HT8 battery, too.
You can build an adapter DIN to servo connector from a S-Video cable.
See DIN pinout from TX for reference and servo pinout in my blog.
Old Mar 10, 2016, 02:49 AM
martin555's Avatar
Joined Jul 2011
this works to q bot micro?
http://www.banggood.com/Clover-Prope...-p-963635.html
Old Mar 10, 2016, 03:05 AM
Germany, Berlin
Joined Jun 2012
no, they won't as they are meant for a even smaller quad with 6mm motors.
There are some 3 bladed props for Hubsan sized quadrocopters out there that would fit to the micro Q-Bot, but they didn't provide any benefits compared to stock props as far as my experience goes.
Old Mar 10, 2016, 08:20 AM
limmacslim is offline
Find More Posts by limmacslim
limmacslim's Avatar
United Kingdom, London
Joined Jun 2012
I agree with Mike's earlier prop recommendation. I personally preferred the way the Ladybird props flew on this quad with the Hubsan props being a close second although I have not tried the clear version, only the white ones.
limmacslim is offline Find More Posts by limmacslim
Old Apr 04, 2016, 09:36 AM
martin555's Avatar
Joined Jul 2011
for testing I also put on 3 blade props, friends like it, I did not had the WOW effect..:
http://www.banggood.com/Hubsan-Upgra...-p-970384.html
Old Apr 04, 2016, 09:50 AM
Germany, Berlin
Joined Jun 2012
I told you so
Old Apr 23, 2016, 07:31 AM
bongmasta is offline
Find More Posts by bongmasta
Joined Apr 2016
are these the best akkus for our q-bot:
http://www.hobbyking.com/hobbyking/s..._Mini_CP_.html ?
+ i mounted a Quanum Elite Micro Cam - powered with an Y-cable - does that cable drain power and i should solder it onto the board?
thx!
bongmasta is offline Find More Posts by bongmasta
New Product BNF Spectrum/JR DSM2-DMSS compatible REDCON HiBiRD Mini 120mm Quadcopter richos Mini Multirotors 37 Oct 25, 2014 05:20 AM
Sold $60 Shipped -- FlySky CT-6B Tx and Six 6-Channel Rx's (Compatible with 9X) Cobra68 Aircraft - General - Radio Equipment (FS/W) 2 Feb 09, 2013 11:00 AM
Sold Hobby King 2.4 ghz Spektrum compatible Receiver = $18 shipped shawn595 Aircraft - General - Radio Equipment (FS/W) 3 Aug 07, 2010 02:35 PM
