Old Oct 22, 2014, 01:41 PM
microhelidude's Avatar
Joined Dec 2007
Here's a good thread on real vs fake Imax:
http://www.rcgroups.com/forums/showthread.php?t=1872511
microhelidude is online now Find More Posts by microhelidude
Old Oct 22, 2014, 01:47 PM
mihcmac's Avatar
United States, HI, Keaau
Joined Aug 2013
I have been experimenting with a skeg blade mounted to hull just forward of the transom. the ones in the photo below are about the 5th that I have made out of thin polycarbonate used for packaging (the kind that is almost impossible to open).. working on getting the height right for the least amount of drag and minimize rudder interference..
I have shattered a few skegs from hitting submerged rocks but they have also saved my prop a few times.. I have also moved the lock nut ahead of the prop effectively moving the prop back farther into the water about 3/16"..
anyway my current skeg blade is made out of 5 layers of laminated polycarbonate.. in the first photo its about an inch tall the second its been shortened and rounded to about 3/4" which seems to have better performance..
my last run it seems to be working well with less side slipping on sharp turns.. also it seems more stable on slightly choppy water able to get higher speed without too much bobbing all over the place..
mihcmac is offline Find More Posts by mihcmac
Old Oct 22, 2014, 04:32 PM
Joined Dec 2007
Very nice!!!!
Just got a el chepo esc from ebay again. $13 bucks. Works well with my 3700kv motor. No stutter of motor like it did with the original 30a esc i had. I'll waterproof n liquid cool iy next now.
Description:
Old Oct 22, 2014, 04:46 PM
Joined Dec 2007
Got it waterproofed now with liquid tape! This esc don't have reverse.
BTW, feeling pretty buzzed smelling this stuff!!!! wow.
Description:
Old Oct 22, 2014, 05:28 PM
mihcmac's Avatar
Joined Aug 2013
thinking of trying this turnigy 7.4v 2s 2200mAh 40c 80c burst lipo on my stock ft009.. it should work without frying the rx or motor.. as long as I don't get the rx too hot from pushing 40c, twice as many milliamps as stock through rx to the motor.. I may need to add some water cooling to the power FET's though.. this battery would also require a traxxas to Tamiya adapter..
http://www.hobbyking.com/hobbyking/s...6_models_.html
Specs:
Capacity: 2200mAh
Voltage: 2S1P / 2 Cell / 7.4V
Discharge: 40C Constant / 80C Burst
Weight: 119.6g (including plug & case)
Dimensions: 87 x 19 x 34mm
Discharge Plug: TRX plug
has anyone used a similar 2s with very high "C" discharge rate on a stock ft009?
Old Oct 22, 2014, 11:02 PM
Joined Dec 2007
thinking of trying this turnigy 7.4v 2s 2200mAh 40c 80c burst lipo on my stock ft009.. it should work without frying the rx or motor.. as long as I don't get the rx too hot from pushing 40c, twice as many milliamps as stock though rx to the motor.. I may need to add some water cooling to the power FET's though.. this battery would also require a traxxas to Tamiya adapter..
Specs:
Capacity: 2200mAh
That can work if u can make it fit
Old Oct 22, 2014, 11:40 PM
Joined Oct 2014
Originally Posted by microhelidude View Post
Very nice!!!!
Attachment 7214967
A non watercooled esc? Are you not afraid that it will overheat?
kristofera is offline Find More Posts by kristofera
Old Oct 22, 2014, 11:56 PM
Australia, VIC, Melbourne
Joined May 2014
Specs:
Capacity: 2200mAh
Yes I have, they will just fit in the same way as the org. but you need to
1/ remove the battery holder and trim off the lipped end and file smooth
2/ remove with great care.....not removing the seal lip....by filing off a tiny bit along were the battery's end hits boat edge
3/ put some insulation tape over each end of the battery to stop it catching skin on one end and to hold wires down on the other
4/ I all so cut off the lumpy ends of the battery holders for less pressure, or remove
one or both and use a Velcro tie
great 2000mAh + battery .....have fun
Shaky Shot is online now Find More Posts by Shaky Shot
Old Yesterday, 01:17 AM
Joined Dec 2007
I got it watercooled also now.
Old Yesterday, 10:20 AM
Windy Heap's Avatar
Joined Apr 2014
So with the 5 layer laminate of polycarb, are you bonding them together with CA glue, or hot glue,
and you're hot gluing the skeg to the hull?
great idea.
Mahalo for sharing!
have some fresh Poke' for me.
Windy Heap is offline Find More Posts by Windy Heap
Old Yesterday, 02:38 PM
mihcmac's Avatar
Joined Aug 2013
great idea.
Mahalo for sharing!
actually using super glue gel..
the way my skeg is laminated, leaving a hollow, it is able to fit over the short stumpy blade on the hull.. which provides a very good anchor point..
edit note: ... my first skeg's were 2 layers thick and shattered leaving behind the pieces of polycarbonate that was glued to the "stumpy blade", which the remaining polycarbonate had to be cut off to install a new skeg..
fresh poke' is always good.. mahalo..
Old Yesterday, 05:58 PM
mihcmac's Avatar
Joined Aug 2013
Specs:
Capacity: 2200mAh
I decided not to buy this from hobbyking because the only shipping available to me was fedex pushing the total cost to almost $50..
instead I ordered a ZIPPY Traxxas 2200mAh 2S1P 30C LiPo TRA2820, from ebay for $25.90 with free shipping..
http://www.ebay.com/itm/ZIPPY-Traxxa...item1c4676eb15
this one has the same physical dimensions but is a 30c.. I was a little nervous about using a 40c pushing too much amperage for the ft009 and frying something.. the zippy being a 30c will still put out almost 2X the sustained amperage that the stock ft009 stock battery will...
Spec.
Traxxas part no: 2820
Capacity: 2200mAh
Voltage: 2S1P / 2 Cell / 7.4v
Discharge: 30C Constant
Weight: 120g (including wire, plug & shrink wrap)
Dimensions: 87x34x19mm
Balance Plug: JST-XH
Discharge Plug: TRX Plug
I also ordered a traxxas to Tamiya adapter plug
Discussion Skywalker 2014 - 1800mm - FPVModel - Spanish Review Japanx FPV Aircraft 9 Dec 14, 2013 09:48 PM
Mini-Review Turbodrone Micro Quad review stallion explosi Multirotor Talk 0 Nov 22, 2013 08:27 AM
New Product Vitality H36's Brother Vitality H39 2.4G 4-axis RC Quadcopter With camera RTF Aaron qin Mini Multirotors 14 Sep 18, 2013 09:02 AM
