Old Nov 29, 2014, 02:59 PM
Dmehalko is offline
Find More Posts by Dmehalko
Joined Feb 2011
Great Planes Spirit Aero Towing with Carbon Cub
Just wanted to share some flying we did, first go at aero-towing, with a Spirit that doesnt have ailerons, was tough, but a good time!
Great Planes Spirit 2M Aerotow with Carbon Cub (2 min 45 sec)
Dmehalko is offline Find More Posts by Dmehalko
Old Nov 29, 2014, 05:34 PM
hasselblad7 is offline
Find More Posts by hasselblad7
USA, CA, Roseville
Joined Aug 2006
Love the covering job! what covering material did you use for the blue/purple?
hasselblad7 is offline Find More Posts by hasselblad7
Old Nov 29, 2014, 07:27 PM
Dmehalko is offline
Joined Feb 2011
Thanks! I used Monokote through the whole process, Transparent Violet, Flour Green, and White of course. I like covering airplanes
Old Nov 29, 2014, 07:29 PM
Dmehalko is offline
Joined Feb 2011
Here are a few more pictures
Old Dec 06, 2014, 03:57 PM
Dmehalko is offline
Joined Feb 2011
Looking at building another wing with ailerons, and without the second dihedral in the outer wing bays. The aerotowing is too much fun!
Old Dec 25, 2014, 10:59 PM
Pilatuspc12 is offline
Find More Posts by Pilatuspc12
Onward and upward.
Pilatuspc12's Avatar
Joined Oct 2006
It is addictive, isn't it?
Pilatuspc12 is offline Find More Posts by Pilatuspc12
Old Dec 26, 2014, 08:14 AM
Bariboy is offline
Find More Posts by Bariboy
United States, NY, Kingston
Joined Feb 2006
My understanding of aerotowing is that the ailerons are not needed, rather you use rudder. Could be wrong, I'm just getting into it myself. Scott
Bariboy is offline Find More Posts by Bariboy
Old Dec 26, 2014, 09:52 AM
dayhead is offline
Find More Posts by dayhead
SlingWinger
San Bernardino, California, United States
Most of my Spirit flying was on the slope, although I did use Hi-Starts and a winch a few times.
I've only aero-towed a ASK-21 behind a Carbon Cub a couple of times, it was interesting and a welcome challenge.
I've never felt the need for ailerons on a Spirit. I do build them with an extra inch of dihedral in the outboard wing panels, and the rudder is built with an extended trailing edge, about a half or 3/4 inch I guess, and the top third of the fin cut away and added to the rudder, to aerodynamically balance it a little. I think doing that helps relieve loads imposed on the servo and pushrod, and is likely a good thing due to the added area of the trailing edge.
These mods result in a very snappy response to rudder control, and allow smaller amounts of rudder deflection, probably only 25 or 30 degrees.
My Spirits often amazed those accustomed to ailerons, I could perform very fast rolls, and performing true axial rolls with an R/E glider is very challenging and, for me anyway, more satisfying than rolling with ailerons, which is just too easy, in my not-so-humble opinion.
dayhead is offline Find More Posts by dayhead
Old Dec 26, 2014, 12:22 PM
SpeedsterDEN is online now
Find More Posts by SpeedsterDEN
DS will change your life
SpeedsterDEN's Avatar
Danmark, Nordjylland, Sæby
Joined May 2010
In my Club, when we are towing RES planes, we put the tow line a bit back and under the fuselage, ....as I also see that you use.
This make the glider much more stable when towing, allmost as a soft highstart
Keep up the good spirit
Soren
SpeedsterDEN is online now Find More Posts by SpeedsterDEN
Old Apr 20, 2015, 07:27 AM
Dmehalko is offline
Joined Feb 2011
I've only ever heard the opposite, don't tow an aileron-less glider haha.
Sold Great Planes Spirit RTF Version Free Shipping bodman Aircraft - Sailplanes (FS/W) 0 Oct 27, 2014 08:17 AM
Sold Great Plane ELECTRI-CUB With Rare CZ-A .12 R/C nitro engine Outlawtjet Aircraft - Fuel - Airplanes (FS/W) 2 Oct 19, 2014 06:11 AM
Sold Relist Great Planes Spirit RTF bodman Aircraft - Sailplanes (FS/W) 0 Oct 15, 2014 07:32 PM
Sold Relist Great Planes Spirit RTF bodman Aircraft - Sailplanes (FS/W) 1 Oct 03, 2014 01:31 PM
Sold Great Planes Spirit Two Meter RTF bodman Aircraft - Sailplanes (FS/W) 4 Sep 22, 2014 09:23 PM
