Old May 11, 2014, 10:05 PM
plane crasher extrordinaire
microairman1's Avatar
United States, IL, Waukegan
Joined Sep 2012
Question
3dhs 70" AJ Slick setup help
hey there guys, i recently got a 3dhs slick and have been working on setting it up. im not a hardcore 3d guy just general stunts and some mild 3d. but i need to figure out what servos to use,rx,and ubec to power the rx and all. my motor is a firepower 1.60 running 8s on a 20x8 prop with a 100 amp opto esc.
for servos i have been looking at tactic tts65s and hitec hs-805mg.
any suggestions would be great. i want something that will be good for most general flying but i dont really wanna spend more then $200(a little over is fine)
for rx i am using a dx6i and soon to be dx6.
for ubec and all i am not sure. havent really used them but in gliders with 2 servos, so any tips and advice would be very very helpful with it all.
hoping to get it done by joe nall eweek. so let me know what you guys all think. thanks for the help.
microairman1 is offline Find More Posts by microairman1
Old May 11, 2014, 10:22 PM
cedarville's Avatar
USA, OH, Cincinnati
Joined Nov 2010
Take a look in the 71" Slick tread (all 30,000 posts ). The 70 and 71 are almost identical airframes. You will find there just about every combination of motor, esc and servos tried, and what work best.
http://www.rcgroups.com/forums/showthread.php?t=1102219
Or take a look at the 3DHobbyShop site for their recommendations for the 71" Slick.
cedarville is offline Find More Posts by cedarville
Old May 11, 2014, 10:26 PM
Joined Sep 2011
I would think you might be disappointed in those hs-805's. Non digital and kind of slow.
The XQ-4013, 16 or 20's will smoke the 805s. About $40 ish each. I think you can get a discount on 5 servos. from RedwingRC
Buy from them if you want killer support.
mchadwick63 is offline Find More Posts by mchadwick63
Old May 11, 2014, 10:29 PM
Joined Sep 2012
Ok I will look at that thread. Thanks. I will also take a look at those xq servos. 40ish each sounds good. Here is my slick sitting in the corner.
Old May 11, 2014, 10:31 PM
cedarville's Avatar
USA, OH, Cincinnati
Joined Nov 2010
Just as an FYI,
In my 70" Slick
6S 5000's
Motrofly 4325-380 motor
Hacker X-80 Opto Pro 3D ESC
4 Align DS610 servos
In my 71" Slick (Setup for IMAC)
8S (2 x 4S) 4000's
Motrolfly 4325-280
ICE 100, BEC Pro
Hitec HS-7954SH Digital Servos
Very happy with both.
Old May 11, 2014, 10:38 PM
Joined Sep 2012
Just looked at those xq servos. And I think that is what I am gonna do. They look good for it have a good price. And nice speed. Thank you for that.
Now I just need to figure out how to power them.
Old May 11, 2014, 11:18 PM
United States, AR, Paragould
Joined Nov 2010
Hey man if your gona go with the xq from redwing. You might as well pick you up one 2100 life batt fro. Redwing also. TH
hey are easy to maintain and charge super fast on top of that no need for a regulator on life Batts
bbrown2828 is online now Find More Posts by bbrown2828
Old May 11, 2014, 11:32 PM
Joined Sep 2012
Ok. So that just plugs into a spare port and that is all you need?
Old May 11, 2014, 11:49 PM
Why am I addicted!!!
DonQ8401's Avatar
United States, IL, Columbia
My XQ 4013 are sick as hell! I am running them on my 30CC MXS-R from Redwing RC. I think they are worth it!
Only down fall I found is that they are loud at humming, but when the hell are you going to hear it when your motor is running or flying.
Speed awesome and centering perfect.
Cheers
DonQ
DonQ8401 is offline Find More Posts by DonQ8401
Old May 12, 2014, 07:10 PM
Whatever goes up must go BOOM
joker24458's Avatar
United States, OH, Kent
Joined Mar 2012
Another option is to run the RX/servos directly off of a 2S Lipo (8.4V)......but you will need HV servos that can operate at that voltage.
-Andres
joker24458 is online now Find More Posts by joker24458
Old May 12, 2014, 07:20 PM
Joined Sep 2012
Yeah, I have looked at that. But looking at a PowerBook but not sure if that is what I want. Although the extra battery in case would be good.
Old May 12, 2014, 08:48 PM
Joined Sep 2011
Go to the XQ-4113, 16 or 20 for high voltage. Not much more cost..
Old May 19, 2014, 08:45 AM
Joined Sep 2012
ok,so if i am running high voltage servos on a 2s lipo. does the esc need to be lowered vvoltage? or does it work with 2s lipo for signal? DONT WANNA BURN IT OUT OR MESS IT UP?
Old May 19, 2014, 10:01 AM
USA, AK, Anchorage
Joined Nov 2005
I'm running two bec pro set at 8.5v for my two 30cc planes. I disconnect/remove the red wire from the Esc so only the signal and ground are seen by the rx and Esc. The internal bec is taken out of the equation and not nessasary. Works great for me Just make sure your rx can handle the higher voltage.
olds455 is online now Find More Posts by olds455
Old May 19, 2014, 10:26 AM
United States, IL, Granite City
Joined Dec 2013
I love my 4013 servos I have them in my 3dhs 74 edge I would highly suggest them to anybody
JStermer is offline Find More Posts by JStermer
For Sale 3DHS 70" AJ SLICK Phantom Blue Color Scheme - Price Reduced - Will Ship! scharck Aircraft - Electric - Airplanes (FS/W) 3 Mar 10, 2014 10:31 AM
For Sale 3DHS 70" AJ Slick Phantom Blue Color Scheme scharck Aircraft - Electric - Airplanes (FS/W) 3 Mar 01, 2014 04:32 PM
Sold CF Straight Leg Gear, Fits 3DHS 68" Velox, 70" AJ Slick, 71" AJ Slick bob_nj Aircraft - General - Miscellaneous (FS/W) 2 Nov 12, 2013 11:23 AM
Sold Price reduced. 70" 3DHS AJ Slick (8S Setup) egiraldo911 Aircraft - Electric - Airplanes (FS/W) 3 Nov 24, 2010 11:12 AM
Discussion 3DHS 70" AJ Slick Setup ?? SEAL 3D Flying 16 Jan 11, 2010 02:39 PM
