Old May 17, 2015, 08:53 PM
Hornetnz is offline
Find More Posts by Hornetnz
Grand Rapids, MI
Joined Jun 2005
Gas throttle cut & ignition Tx setup?
When setting up my transmitter, do I need to have throttle cut and ignition on separate switches? I initially set it up on the same switch, so when in POS 0, throttle was -130% (no stick movement will move throttle) and ignition is off. POS 1 has normal throttle movement and ignition on. But not sure that's the correct way? Does throttle need to move with ignition off for choking?
Hornetnz is offline Find More Posts by Hornetnz
Old May 17, 2015, 09:32 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Normally the throttle kill is on a spring loaded momentary switch. Ignition kill should be on a normal on/off switch.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old May 18, 2015, 05:03 AM
exf3bguy is online now
Find More Posts by exf3bguy
exf3bguy's Avatar
Joined Oct 2011
No real wrong way to do this as long as you are comfortable. I personally dont use the throttle servo to shut down the engine, its really rough on servos. My setup is the ignition switch is on the left side slider. I have an idle up switch that I use to switch between taxi/land idle and a higher flight idle. I can still shut the engine down with idle trim if need be but the failure mode of an IBEC is ignition power open.
exf3bguy is online now Find More Posts by exf3bguy
Old May 19, 2015, 01:08 PM
600Bob is online now
Find More Posts by 600Bob
United States, OR, Canby
Joined Aug 2011
Generally you open the throttle when choking but the ignition is on too. Some people prime the engine with the ignition off first.
I have the throttle cut on a momentary switch and the ignition on the throttle hold/mix switch.
600Bob is online now Find More Posts by 600Bob
Old May 19, 2015, 10:06 PM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
I use the same switch on my 9C
kerwin50 is offline Find More Posts by kerwin50
Sold PTE36R Gas Engine with new ignition and alloy throttle arm planebldr Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jul 14, 2014 11:35 AM
Question throttle cut vs throttle hold? Green Darner Radios 3 Feb 28, 2014 07:44 AM
Discussion Throttle cut on dx7s for differential throttle mix Flight Quack Radios 1 Nov 18, 2013 04:26 AM
Discussion throttle cut on dx7s for differential throttle mix Flight Quack Electric Warbirds 0 Nov 17, 2013 09:39 PM
