Old May 15, 2015, 03:49 PM
Jon.M.Barter is online now
Find More Posts by Jon.M.Barter
United States, CA, Garden Grove
Joined Apr 2012
Originally Posted by Squirrel_D View Post
Does anyone have an 'issue' with the left stick basically, sticking? It's like the springs just aren't strong enough..
Has anyone come up with a fix for this?
Also, what batteries are you all using for the TX?
Open it up and make sure there are no wires in the way of the gimbals (remove gimbals and rubber grip pads. Also, there is a screw that adjusts how tight the gimbals will feel.
I use eneloop rechargeable batteries, have had no issues.
Jon.M.Barter is online now Find More Posts by Jon.M.Barter
Old May 17, 2015, 08:10 PM
Squirrel_D is offline
Find More Posts by Squirrel_D
X5C-1, WL 959, Ladybird
Squirrel_D's Avatar
United States, PA, Levittown
Joined Feb 2015
Thanks, gimbals? Not sure what you mean...
Squirrel_D is offline Find More Posts by Squirrel_D
Old May 18, 2015, 05:39 AM
Joined Apr 2012
Pic example. Open your radio by removing the five necessary screws. And rubber grips. Check and make sure wires are not interfering with the motion of your sticks. Tighten or loosen the screws on the metal band that puts pressure against your throttle stick as necessary
Old May 18, 2015, 10:36 AM
Squirrel_D's Avatar
Joined Feb 2015
Ok, thanks - that's what I kind of thought you meant but when you said Gimbal, I guess I got a bit cornfused! (That happens easily to me!)
I've actually already had it opened up and installed the module for the Syma protocol (NRF something or other) and while I was in there I checked for anything in the way - nothing seemed to be interfereing with the sticks from what I could see... Yet still, my throttle stick seems to stick instead of going back to center so my quad continues to yaw in whatever direction the stick is 'stuck' in.
Old May 18, 2015, 11:54 AM
Joined Apr 2012
I would still double check and rule that out if i were you, especially if you installed an nrf24l01 chpi as the extra wires could have been pushed while you were closing. Aside from that i have no idea what would make it stick unless You spilled orange juice or glue into the gimbals.
Old May 18, 2015, 02:55 PM
Squirrel_D's Avatar
Joined Feb 2015
Thanks, I'll do that. I just remember somewhere in the first ? 50 pages of this thread that someone else had this issue right out of the box (as did I - it's actually better now that I installed the module and checked stuff out.
I'll open her up again, I just don't want to mess anything up that my huge hands can't fix! I'm not good with tweezers and I need reading glasses so I'm not so good with small stuff if you know what I mean - especially in confined areas!
Old May 18, 2015, 03:02 PM
Joined Apr 2012
the devo 7e and devo 6s have a spine on their back half of the tx that pushes wires to the side. When I modified my first devo 7e, the throttle would feel jammed. I opened it up and realized it was a pinched wire from my mods interfering. Cleared it up, it was back to business as usual.
If that is not the case, and you feel confident, you could go ahead and remove the gimbal thats giving you issues and check it out and see what is going on.
For someone with poor eyesight and big hands, I would highly recommend you get a Devo 8s. Its leaps and bounds better than the 7e, easier to use, bigger screen, better range, more switches, better everything. The only thing that the 7e is better at is being smaller for people with smaller hands.
Old May 18, 2015, 04:07 PM
Squirrel_D's Avatar
Joined Feb 2015
I've had my eye on the Devo 10 for a while now.. So I'll probably go for that - eventually..
The way my 7E is functioning now isn't terrible. I can live with it, but I do like a 'strong' spring back to center - makes me feel more confident so if I get any quads that are more expensive, I'm probably not going to fly them with my 7E unless I can fix the throttle / Yaw stick.
Old May 18, 2015, 04:36 PM
Joined Apr 2012
Devo 10 is a good choice, however, devo 8s is still slightly better in ease of use (you are not mashing the buttons all over the place to select values, the stylus pen really does make for a better experience).
However, devo 10 definitely a major step up from devo 7e.
hope you fix that problem
cheers
New Product New Devo 7E Radio from Walkera!! thwaitm Radios 3 Jul 17, 2012 01:41 AM
For Sale $ 1.00 NIB Walkera Devo 12S Radio With Telemetry Module (WK-CTL01-D) Aurora9 Aircraft - General - Radio Equipment (FS/W) 4 May 10, 2012 11:07 AM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 12:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 11:38 AM
New Product Walkera V18G01 with optional Devo 12 radio zadaw Fuel Heli Talk 11 Jun 10, 2011 10:01 PM
