Old Jun 13, 2015, 06:43 PM
brokenspar is offline
Find More Posts by brokenspar
The dog ate my clearance
brokenspar's Avatar
Joined Jan 2004
Build Log
Guillow's Spitfire for Complete a Project 2015
This has been a work in progress for about 4 years. Maybe this will be the year for completion? This kit is from the Guillow's "400" series (first kitted in 1962), with a span of 27 3/4".
Changes I'll be making:
Modified wing airfoil
Plug-in landing gear
Paper mache engine cowl
Laminated leading and trailing edges
Electric power, with three channels of RET
brokenspar is offline Find More Posts by brokenspar
Old Jun 13, 2015, 07:59 PM
Pilatuspc12 is offline
Find More Posts by Pilatuspc12
Onward and upward.
Pilatuspc12's Avatar
United States, CO, Hotchkiss
Joined Oct 2006
Looks good, Pete. I made one of these many years ago, converted it for Control line ops. It flew very well until a gust blew it into me and the lines went slack. I converted it to a Mk-IX. It was the first time I had used silkspan for covering. It will be interesting to see how you finish it.
Randy
Pilatuspc12 is offline Find More Posts by Pilatuspc12
Old Jun 13, 2015, 08:38 PM
JohnAV8R is online now
Find More Posts by JohnAV8R
Canada, ON, Hamilton
Joined Oct 2005
Nice start. There's lots to build in a Guillows kit. For all the weight a pair of 5g servos would add, I'd have ailerons .
JohnAV8R is online now Find More Posts by JohnAV8R
Old Jun 13, 2015, 09:24 PM
Edubarca is offline
Find More Posts by Edubarca
Edubarca
Edubarca's Avatar
Colombia, South America
Joined Oct 2009
Why change airfoil section??
Edubarca is offline Find More Posts by Edubarca
Old Jun 14, 2015, 04:08 AM
Sundancer is online now
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Nice project Pete, I'll post your entry and hopefully this will help with the impetus to complete it.
Sundancer is online now Find More Posts by Sundancer
Old Jun 14, 2015, 06:14 AM
Paul_BB is offline
Find More Posts by Paul_BB
Paul_BB's Avatar
France, IdF, Lagny-sur-Marne
Joined Feb 2007
The new airfoil looks better than the old one. I'm sure the airplane will gain from it. Sharp leading edges are not recommended. Good luck.
-Paul
Paul_BB is offline Find More Posts by Paul_BB
Old Jun 14, 2015, 07:47 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
The original section, totally flat right to the front with a very sharp LE looks to me as if it might have rather "sudden" stall characteristics which, coupled with the elliptical wing might well produce rather "interesting" (not interesting in a good way!) handling in a radio model. I think bs is very wise to thicken the LE up slightly and add a touch of Phillip's entry, it certainly won't make the resulting model any worse and it might well make it quite a bit better.
As an aside I have done exactly the same thing on my current build, the Lulu which also had this type of LE. Worked fine on the very light (3 ounce) F/F version but I feel my change, plus turbulator spars will produce better results in an R/C one weighing twice as much.
Old Jun 14, 2015, 08:00 AM
rabidrue1 is offline
Find More Posts by rabidrue1
Blueplaidcanard flyer
sdy. ny
Joined May 2007
Yup a sharp L/E makes for nasty stalls.
rabidrue1 is offline Find More Posts by rabidrue1
Old Jun 14, 2015, 09:54 AM
brokenspar's Avatar
Joined Jan 2004
Thanks, all.
Oops, I meant aileron, elevator, throttle, not RET. A pair of tiny servos will drive the ailerons.
The sharp wing leading edge is definitely something to avoid. There's a lot of discussion on it here:
http://www.rcgroups.com/forums/showthread.php?t=827861
Old Jun 14, 2015, 11:23 AM
Guizzo 17 is online now
Find More Posts by Guizzo 17
Guizzo 17's Avatar
Joined Sep 2007
Definitely a good move, IMO however the new foil now is positioned at a greater AOA.
Possibly it is worth to rise the TE or lower the LE a bit.
Nice model. Subscribed!
Guizzo 17 is online now Find More Posts by Guizzo 17
Old Jun 15, 2015, 01:39 AM
Paul_BB is offline
Paul_BB's Avatar
Joined Feb 2007
I have computed the polars of the original Clark Y and a flattened version for two Reynolds numbers: 70k and 50k, Reynolds numbers the Spit should encounter in flight. I don't know if the following analysis is correct but here goes.
Note: the flattened Clark Y has been normalized (length = 1) but not derotated.
The airfoils stall characteristics seem close (I'm not sure the Xfoil program captures well the stall characteristics) whereas the behavior of the flat airfoil is not very smooth for small AoAs (high speed).
Beyond that the polars are quite similar, especially the lift coefficient CL versus alpha curves. So the flight attitude (fuselage incidence) should be the same if the two airfoils are set at the same angle.
The main difference is the Neutral Point moment coefficient Cm: that of the original Clark Y (smooth leading edge) is 20% (absolute value) smaller and so requires a little less trimming (up elevator).
I would leave the wing incidence as it is and maybe change slightly the incidence of the stabilizer or leave it as it is and trim with the radio.
Old Jun 15, 2015, 05:15 AM
Guizzo 17's Avatar
Joined Sep 2007
Originally Posted by Paul_BB View Post
I have computed the polars ..........................................
....................I would leave the wing incidence as it is and maybe change slightly the incidence of the stabilizer or leave it as it is and trim with the radio.
Ok. I see that your airfoil analysis has more solid bases than my guesstimation. Go for it!
Old Jun 15, 2015, 05:37 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
..........whereas the behavior of the flat airfoil is not very smooth for small AoAs (high speed).
Yep, that's what I meant by "sudden" - all the rest passed 2 feet over my head but it is always nice when the theory agrees with what actually happens!
Old Jun 15, 2015, 08:58 PM
JeffMac is offline
Find More Posts by JeffMac
I'd rather be flying.....
JeffMac's Avatar
United States, IA, Story City
Joined Oct 2013
hi BS-
nice project I like it !
best regards,
jeff
JeffMac is offline Find More Posts by JeffMac
Old Jun 16, 2015, 08:40 PM
Edubarca is offline
Edubarca
Edubarca's Avatar
Joined Oct 2009
Understood, George. I also agree about the LE on any model. Thanks!!
Discussion Great News for Complete a Project in 2015 Build Off albertofkent Vintage & Old-Timer Designs 47 Aug 15, 2015 02:34 AM
Build Log Revisiting the Humbug - 2015 Complete a Project Build Off (finished) Paul_BB Vintage & Old-Timer Designs 120 Jul 07, 2015 10:55 PM
Discussion Ben Shereshaw 1937 "Champion" - Complete-A-Project 2015 cpmcgraw Vintage & Old-Timer Designs 214 Jun 15, 2015 09:10 PM
Build Log Dick Korda "DIAMOND " 55inch 1939 rc Conversion - Complete A Project 2015 JeffMac Vintage & Old-Timer Designs 0 May 23, 2015 04:43 PM
Build Log Guillows 172 Skyhawk, Complete a Project in 2014 Build Off JohnAV8R Vintage & Old-Timer Designs 3 Mar 20, 2014 12:53 AM
