Old Feb 12, 2014, 06:43 PM
ribotero is offline
Find More Posts by ribotero
Colombia
Joined Sep 2005
Help!
Rhino Surfaces
I am trying to smooth out the creases and/or ridges that are in the canopy area of this Saab Safari. So far I have tried all the tricks up my sleeves, joining the surfaces, smoothing, point editing (nudging) and so far I am not pleased with the results.
I want to get one continuous smooth surface that I can work from to start designing the internal structure, it would be a built up type structure.
Help appreciated!
ribotero is offline Find More Posts by ribotero
Old Feb 13, 2014, 06:47 AM
Prop-er is offline
Find More Posts by Prop-er
Launchpad McQuack
Prop-er's Avatar
Netherlands, Moordrecht
Joined Sep 2004
Hope these help:
http://www.foundation3d.com/forums/s...d.php?p=125210
http://www.rcgroups.com/forums/showthread.php?t=971672
Prop-er is offline Find More Posts by Prop-er
Old Feb 13, 2014, 12:15 PM
ribotero is offline
Colombia
Joined Sep 2005
thanks, great info. Im looking at it now.
Old Feb 13, 2014, 03:38 PM
mcg is offline
mcg
Find More Posts by mcg
mcg
Joined Jul 2005
Quite impressed by the tutorial on the former-less Bearcat. I'd like to try this technique.
It looks like he was using an early version of Rhino, maybe Rhino 3.
In any event, it was not clear to me how to do the most important step, attached. He has circled some points in red, but the procedure and commands he is suggesting are not familiar to me.
Maybe "start pulling highlighted points in line with..." means "into alignment with"? Or does he mean points that are recognizable because they are in line with ... something?
Are the highlighted points the selected points? The circled points?
Can't seem to puzzle out this instruction. Maybe if I understood what he intends to achieve by pulling on the points it would all suddenly make sense.
Thank you for your insights and help.
Michael
mcg is offline Find More Posts by mcg
Old Feb 14, 2014, 02:21 AM
Prop-er is offline
Launchpad McQuack
Prop-er's Avatar
Joined Sep 2004
The surface shown is just build from the side and topview of the Bearcat plan.
Because there are no formers, the surface section resembles half a diamond shape.
In the next step, the half fuselage surface will be mirrored. He wants the section to represent half an oval, so that after the mirror command no hard visible edge will be visible on the top and bottom of the fuselage.
The action he takes is turn on surface control points, goes to the front view (which he calls side view, in any case, it's the XZ plane). There he pulls the red circled surface control points in the Z direction, to achieve the oval shape.
Hope this explains the step. If not, ask again.
Old Feb 14, 2014, 10:08 AM
mcg is offline
mcg
mcg
Joined Jul 2005
@ Prop-er. Thank you. I will set up a 3-view and experiment with this technique. In my experience the fewer the formers, the smoother the fuselage. Reducing the number of formers to zero should produce perfection, theoretically...? That will be the day.
@ribotero. A command that is sometimes helpful in smoothly assembling a collection of different surfaces is BlendSrf. Also, if you search this site there is a complete short course/ tutorial by Harpye on modeling a fuselage in Rhino3D. I think the complete .pdf can still be downloaded from his own web site. IIRC he used a Network of Curves command to create the fuse surface. Michael
Old Feb 14, 2014, 02:33 PM
jumo004 is offline
Find More Posts by jumo004
jumo004's Avatar
Joined Apr 2010
I'm interested in checking out the Harpeye tutorial on the fuselage construction but his name doesn't show up in an advanced search.
Does anybody have a link ?
Thanks.
jumo004 is offline Find More Posts by jumo004
Old Feb 14, 2014, 02:49 PM
Prop-er is offline
Launchpad McQuack
Prop-er's Avatar
Joined Sep 2004
http://www.rcgroups.com/forums/showthread.php?t=1357922
Old Feb 14, 2014, 04:46 PM
mcg is offline
mcg
mcg
Joined Jul 2005
Sorry, misspelled Harpye. In addition to the thread referenced by Prop-er, the author's website is here:
http://www.modellbauwahn.de/
If you navigate on his site to CAD Engineering, there are some files you can download for the tutorial.
Old Feb 16, 2014, 01:47 AM
Treeline is offline
Find More Posts by Treeline
Joined Oct 2010
I wanted to take a look at his work on the subject, but there is only one good link to anything relevant on that page, and that's a PDF that's 54 pages long.
All the other links on that same page are videos that make no sense at all.
I guess he's dropped all those "Unit" links for whatever reason.
Treeline is offline Find More Posts by Treeline
Old Feb 16, 2014, 03:58 PM
mcg is offline
mcg
mcg
Joined Jul 2005
I think the narrative line of that presentation is in the 54 page .pdf. It was a "live" tutorial here on the forum, but I think you can get the basic ideas, strategies and commands from reading that .pdf. You might send Harpye a PM if you have questions.
Old Feb 17, 2014, 02:00 PM
dpot is offline
Find More Posts by dpot
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
i did the tutorial that harpye put together and it certainly help me.
you have the pdf but it came with drawings named as 1 to 8 units witch we had to complete before we could go no to the next
if you pm me i could let you have them,
i hope this will not upset Harpye
dpot is offline Find More Posts by dpot
Old Feb 22, 2014, 02:05 AM
dpot is offline
dpot's Avatar
Joined Dec 2005
how are you getting on with the tutorial
Old Feb 22, 2014, 12:15 PM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
Here you can get the whole tutorial with all the drawings ( please use the lo Res Version of the drawings )
-> English section
-> Cad Engineering
-> link @ Bottom of the page
Files Cad Workshop 2010 2011
Have fun !
Hansjoerg
Harpye is offline Find More Posts by Harpye
Old Feb 22, 2014, 12:18 PM
Harpye is offline
Harpye's Avatar
Germany
DPOT - You did build her???!??!? - Pictures/ Videos please - I'm so curious!!!
Hansjoerg
( I'm rather off modelling since 2012 - took a break - but lastet longer than I wanted.. recently I'm busy with other stuff!) - it's not that space consuming!!!
Question Learning to design a F3K with Rhino leroyo CAD/CAM 3 Nov 14, 2013 01:22 PM
For Sale Rhino 4s 2250 (10 total) with deans flyordie33 Aircraft - Electric - Batteries & Chargers (FS/W) 4 Oct 28, 2013 03:38 PM
For Sale Rhino 1050mAh 3S 11.1v 20C Lipoly Pack ED3 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Sep 25, 2013 01:08 AM
Sold Rhino 6S 3700 mAh 25C LiPo NEW $40 shipped Sgt Ski Aircraft - Electric - Batteries & Chargers (FS/W) 2 Sep 22, 2013 04:00 PM
Discussion odd surfaces in Rhino. vintage1 CAD/CAM 6 Feb 04, 2010 08:45 PM
