Old Sep 07, 2011, 06:19 PM
reefpilot is offline
Find More Posts by reefpilot
reefpilot's Avatar
New Zealand, Canterbury, Christchurch
Joined Aug 2009
Help!
Sopwith Camel 1/5 scale scratch
Hi I have started builing a Sopwith camel but the plans I am using are not the best for details. Traplett plans.
So while I am cutting all the bits and pieces and as I am looking at the plans they do not show much about the rigging ie flying wires tailplane rigging etc.
Maybe somebody can steer me in the right direction to get hold of all that info please.
Regards Paul
reefpilot is offline Find More Posts by reefpilot
Old Sep 08, 2011, 11:20 AM
Mike Denest is offline
Find More Posts by Mike Denest
Brighto?
Mike Denest's Avatar
United States, DE, Newark
Joined Dec 2003
Everything you need to know here:
http://thevintageaviator.co.nz/
Mike Denest is offline Find More Posts by Mike Denest
Old Sep 08, 2011, 05:20 PM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
http://www.finemodelworks.com/arizon...mel/Camel.html
rick.benjamin is offline Find More Posts by rick.benjamin
Old Sep 09, 2011, 05:04 PM
reefpilot's Avatar
Joined Aug 2009
Hi Mike and Benjamin thanks for those pictures that just about tells you everything you need to know.
Amazing where all the info comes from thanks again.
Paul
Old Mar 06, 2012, 03:17 AM
reefpilot's Avatar
Joined Aug 2009
Making steady progress with the Camel the asp 91 should be big enough to pull this thing along?
Old Mar 06, 2012, 09:46 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
I don't know what size that is, but my Sterling Stearman, at 64" upper wing, flies just great with an OLD OS91, if that helps.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Mar 06, 2012, 02:24 PM
reefpilot's Avatar
Joined Aug 2009
Hi Les, its a Traplett plan 1/5 scale 66" and I am hooking a OS 91 on it so that sounds allright Thanks for that.
Paul
Old Mar 07, 2012, 10:09 AM
LesUyeda is offline
LesUyeda's Avatar
Joined Dec 2004
It'll do just fine. Cruise at 1/2 throttle.
Les
Old Mar 13, 2012, 05:34 AM
reefpilot's Avatar
Joined Aug 2009
Made some further progress decided to make the cowling as it is almost impossible to to purchase one anywhere. Took a while, made a polug out of plystyrene foam covered it with plastic of some sort and started glassing it with polyester resin.
Not a good idea as the polyester just attacks the foam I found out, learning all the time anyway got it done in the end.
Just one request I would like to put in a dummy radial you guys have any idea where to get a decent one. 1/5 scale opening in cowling 140mm
Rgds Paul
Old Mar 13, 2012, 10:02 AM
LesUyeda is offline
LesUyeda's Avatar
Joined Dec 2004
Williams Brothers. Won't cost you any more than a two stroke large enough to handle the plane:-)))))))))))))))
Les
Old Mar 14, 2012, 11:43 PM
reefpilot's Avatar
Joined Aug 2009
Hi ,I put a coat of epoxy primer undercoat on the cowling what top coat do you guys use to stop the nitro fuel stripping it.
Paul
Old Mar 15, 2012, 10:12 AM
LesUyeda is offline
LesUyeda's Avatar
Joined Dec 2004
"Hi ,I put a coat of epoxy primer undercoat on the cowling what top coat do you guys use to stop the nitro fuel stripping it."
Remember that you seldom, if ever get raw fuel on the cowling. I painted the Sterman prop with Model Masters enamel, and the only black showing now, years later, is from wear, not fuel.
Les
Old Apr 03, 2012, 03:58 PM
reefpilot's Avatar
Joined Aug 2009
Hi guys making steady progress with the camel, looks like i will need about 1.8 pounds of weight to get the CG to balance does that sound about right?
Paul
Old Apr 03, 2012, 04:06 PM
epoxyearl is online now
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
Paul
Yeah thats possible ...I used 22 oz in a Stearman 1/5 scale.it's gotta balance!
epoxyearl is online now Find More Posts by epoxyearl
Old Apr 06, 2012, 10:22 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
For a model of that size I think you did admirably at building the tail light to get away with only 1.8 lbs in the nose.
BMatthews is online now Find More Posts by BMatthews
Build Log Ultra Micro Sopwith F.1 Camel deadbird Scratchbuilt Indoor and Micro Models 16 Apr 22, 2012 03:14 PM
Sold Model Airways 1:16th Scale Sopwith Camel F.1 ssg.perkins Aircraft - General - Miscellaneous (FS/W) 1 Dec 03, 2010 06:46 PM
Cool AP with a 1:5 scale Sopwith camel. Lynxman Aerial Photography 18 Apr 04, 2008 12:01 AM
